Bond Home Issue with Ceiling Fan
Wed May 25, 2022 3:15 pm
boisy offline
Hi all,
I just got my Bond Hub setup and working. With the Bond app, I can control the ceiling fan, turn up speed, down, etc.
With the Indigo plug-in, I've setup both a Bond Bridge device and a Ceiling fan as a Bond device. I setup the On Command to SetSpeed and the Off Command to Stop.
When I attempt to start or stop this device, I see this in the event log:
type: 400 Client Error: Bad Request for url: http://10.0.0.201/v2/devices/0f74783d/actions/SetSpeed
Any ideas on why the error 400 is happening?
Wed May 25, 2022 3:17 pm
Re: Bond Issue with Ceiling Fan
Turn on debug logging and try it again, and post the log.
Also, moving this to the correct forum.
Wed May 25, 2022 5:16 pm
boisy offline
Re: Bond Home Issue with Ceiling Fan
Thanks Joe. Sorry about the wrong forum.
I cranked up the logging in the plugin configuration. Here's what I have when I reloaded the plugin and tried to control the device:
Screen Shot 2022-05-25 at 6.15.03 PM.png (215.12 KiB) Viewed 2111 times
Wed May 25, 2022 5:43 pm
Please copy and paste. I can't read the screenshot.
Wed May 25, 2022 6:02 pm
boisy offline
Sure Joe. Here is the raw text:
May 25, 2022 at 6:14:38 PM
   Reloading plugin "Bond Home 2022.0.0" using API v3.0
   Stopping plugin "Bond Home 2022.0.0" (pid 48021)
   Bond Home                       Bond Bridge: Stopping bondBridge Device 569790961
   Bond Home                       Sunroom Ceiling Fan: Stopping bondDevice Device 1774690323
   Bond Home                       Stopping BondHome
   Stopped plugin "Bond Home 2022.0.0"
   Starting plugin "Bond Home 2022.0.0" (pid 85912)
   Bond Home Debug                 logLevel = 5
   Started plugin "Bond Home 2022.0.0"
   Bond Home                       Starting BondHome
   Bond Home                       Bond Bridge: Starting bondBridge Device 569790961
   Bond Home Debug                 BondHome __init__ address = 10.0.0.201, token = ff59c099f82e8647
   Bond Home Debug                 Bond Bridge: Bond version: {'target': 'zermatt', 'fw_ver': 'v2.28.0', 'fw_date': 'Tue Nov  2 19:07:06 UTC 2021', 'uptime_s': 7612, 'make': 'Olibra', 'model': 'BD-1000', 'branding_profile': 'OLIBRA_BD1000', 'bondid': 'ZZEI43594', 'upgrade_http': True, 'api': 2, '_': '51eee1ba'}
   Bond Home Debug                 Bond Bridge: Bond info: {'name': 'My Bridge', 'location': 'My Room', 'bluelight': 255, 'frequencies': [[38, 38], [300000, 321500], [336000, 399500], [410500, 450000]], '_': '519761e7'}
   Bond Home Debug                 get_device_list: {'_': '6a05a205', '0f74783d': {'_': '4ff61826'}}
   Bond Home Debug                 Bond Bridge: known_devices:
{'ZZEI43594': {'0f74783d': {'name': 'Ceiling fan', 'type': 'CF', 'location': 'Sunroom', 'template': 'D1x', 'actions': ['SetSpeed', 'TurnOff', 'ToggleUpLight', 'ToggleDownLight', 'StartUpLightDimmer', 'StartDownLightDimmer', 'ToggleDirection', 'Stop', 'TogglePower', 'TurnOn', 'IncreaseSpeed', 'DecreaseSpeed', 'SetDirection', 'ToggleLight', 'TurnLightOn', 'TurnLightOff', 'TurnUpLightOn', 'TurnUpLightOff', 'TurnDownLightOn', 'TurnDownLightOff'], '_': '4ff61826', 'commands': {'_': '6038fc7d'}, 'state': {'_': 'ed2d83fd'}, 'properties': {'_': '7726f8ad'}, 'skeds': {'_': 'f919e4cd'}}}}
   Bond Home Debug                 udp_start() socket listener started
   Bond Home                       Sunroom Ceiling Fan: Starting bondDevice Device 1774690323
   Bond Home Debug                 Sunroom Ceiling Fan: doDeviceStartup: bondDevice (0f74783d)
   Bond Home Debug                 Sunroom Ceiling Fan: Updating Device info:
   Bond Home Debug                 Ceiling fan (0f74783d): Device states: {'power': 1, 'speed': 1, 'direction': 1, 'light': 1, 'up_light': 1, 'down_light': 0, '_': 'ed2d83fd'}
   Bond Home                       Ceiling fan (0f74783d): Stopping bondDevice Device 1774690323
   Bond Home                       Ceiling fan (0f74783d): Starting bondDevice Device 1774690323
   Bond Home Debug                 device_action, url = http://10.0.0.201/v2/devices/0f74783d/actions/SetSpeed, payload = {}
   Bond Home Error                 Error in plugin execution ExecuteAction:
  File "plugin.py", line 332, in actionControlDevice
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/BondHome.indigoPlugin/Contents/Server Plugin/bondhome.py", line 96, in device_action
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 960, in raise_for_status
Wed May 25, 2022 6:10 pm
Use the menu command "Write Device Information to Log" and post the output.
I'm sure the problem is that the SetSpeed command requires a parameter, but the basic config dialog doesn't provide for that. SetSpeed is set up for the "Send Device Command" Action.
Wed May 25, 2022 6:26 pm
boisy offline
Sure. Here is the output:
May 25, 2022 at 7:25:51 PM
   Bond Home
    "ZZEI43594": {
        "0f74783d": {
            "_": "4ff61826",
            "actions": [
                "SetSpeed",
                "TurnOff",
                "ToggleUpLight",
                "ToggleDownLight",
                "StartUpLightDimmer",
                "StartDownLightDimmer",
                "ToggleDirection",
                "Stop",
                "TogglePower",
                "TurnOn",
                "IncreaseSpeed",
                "DecreaseSpeed",
                "SetDirection",
                "ToggleLight",
                "TurnLightOn",
                "TurnLightOff",
                "TurnUpLightOn",
                "TurnUpLightOff",
                "TurnDownLightOn",
                "TurnDownLightOff"
            "commands": {
                "_": "6038fc7d"
            "location": "Sunroom",
            "name": "Ceiling fan",
            "properties": {
                "_": "7726f8ad"
            "skeds": {
                "_": "f919e4cd"
            "state": {
                "_": "ed2d83fd"
            "template": "D1x",
            "type": "CF"
Wed May 25, 2022 6:44 pm
So try the TurnOn and TurnOff commands for the basic device configuration.
Wed May 25, 2022 6:55 pm
boisy offline
That seems to work:
May 25, 2022 at 7:54:11 PM
   Bond Home Debug                 getDeviceConfigUiValues, typeId = bondDevice, devId = 1774690323, pluginProps = UiValuesDict : (dict)
     SupportsStatusRequest : true (bool)
     address : 0f74783d (string)
     bond_type : CF (string)
     bridge : ZZEI43594 (string)
     off_command : Stop (string)
     on_command : SetSpeed (string)
   Bond Home Debug                 device_action, url = http://10.0.0.201/v2/devices/0f74783d/actions/TurnOn, payload = {}
   Bond Home Debug                 device_action, resp = <Response [200]>
   Bond Home Debug                 device_action, url = http://10.0.0.201/v2/devices/0f74783d/actions/TurnOff, payload = {}
Is there something additional I must do to provide the parameter to SetSpeed?
Wed May 25, 2022 7:09 pm
You'll have to set up an Action Group to use the SetSpeed command, and you can provide the speed parameter there. But I would try using the Increase and Decrease commands first, as they don't require a parameter.
You can read the API docs here: http://docs-local.appbond.com/#section/Introduction
The plugin really isn't very smart about what commands need what parameters. There's so many possible devices and command combinations that I couldn't figure out an efficient way to do it.
Mon Feb 27, 2023 10:32 pm
vvrangler offline
Hi Joe,
I seem to be hitting this issue whenever I try to use the IncreaseSpeed function for any of my Fan devices, any idea what the issue might be?
Bond Home Debug device_action, url = http://192.168.1.94/v2/devices/5c04f768 ... reaseSpeed, payload = {}
File "plugin.py", line 379, in actionControlDevice
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/BondHome.indigoPlugin/Contents/Server Plugin/bondhome.py", line 84, in device_action
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/models.py", line 960, in raise_for_status
type: 400 Client Error: Bad Request for url: http://192.168.1.94/v2/devices/5c04f768 ... reaseSpeed
Tue Feb 28, 2023 3:39 am
Please repost using the CODE tags. The forums software is reformatting the lines. Also turn on debug logging before you do that,
Tue Feb 28, 2023 8:55 am
vvrangler offline
   Starting plugin "Bond Home 2022.0.4" (pid 75825)
   Started plugin "Bond Home 2022.0.4"
   Bond Home                       Bond Hub: Starting bondBridge Device 486527038
   Bond Home Debug                 BondHome __init__ address = 192.168.100.194, token = ab8c06a614cc3b85
   Bond Home Debug                 get_bridge_version
   Bond Home Debug                 Bond Hub: Bond version: {'target': 'zermatt', 'fw_ver': 'v3.8.4', 'fw_date': 'Thu Nov 10 15:16:25 UTC 2022', 'uptime_s': 36946, 'boot_patch': 'not first boot', 'make': 'Olibra', 'model': 'BD-1000', 'branding_profile': 'OLIBRA_BD1000', 'bondid': 'ZXFHX23X4', 'upgrade_http': True, 'api': 2, '_': 'd017ff70', '__': 'd017ff70'}
   Bond Home Debug                 get_bridge_info
   Bond Home Debug                 Bond Hub: Bond info: {'name': 'Bond', 'location': 'Home', 'bluelight': 2, 'frequencies': [[38, 38], [300000, 321500], [336000, 399500], [410500, 450000]], '_': '5xbx6x9c', '__': '5xbx6x9c'}
   Bond Home Debug                 get_device_list: {'_': 'bx9ex7ax', '__': '00000000', '5c0x47x83xa69x58': {'_': '17x3xdxb'}, '72x56x7fx11xebxa': {'_': '21x2xbx7'}, '9x2xbx6x4x4xdx91': {'_': '4x14x7bx'}, 'e3x6ex3fx86xebx9': {'_': '4x2ex0ax'}}
   Bond Home Debug                 get_device: 5c0x47x83xa69x58
   Bond Home Debug                 get_device: 72x56x7fx11xebxa
   Bond Home Debug                 Service ZXFHX23X4._bond._tcp.local. of type _bond._tcp.local. state changed: ServiceStateChange.Added
   Bond Home Debug                 Found BondBridges: {'ZXFHX23X4._bond._tcp.local.': 'ZXFHX23X4.local.'}
   Bond Home Debug                 get_device: 9x2xbx6x4x4xdx91
   Bond Home Debug                 get_device: e3x6ex3fx86xebx9
   Bond Home Debug                 Bond Hub: known_devices:
{'ZXFHX23X4': {'5c0x47x83xa69x58': {'name': 'Office Fan', 'type': 'CF', 'location': 'Home', 'template': 'C2', 'actions': ['DecreaseSpeed', 'IncreaseSpeed', 'SetSpeed', 'StartDimmer', 'Stop', 'ToggleLight', 'TogglePower', 'TurnLightOff', 'TurnLightOn', 'TurnOff', 'TurnOn'], '_': '17x3xdxb', '__': '188695e6', 'commands': {'_': 'b68b0984'}, 'state': {'_': '87752b7d'}, 'properties': {'_': 'c23bc46d'}, 'skeds': {'_': '00000000'}}, '72x56x7fx11xebxa': {'name': 'Family Room Fan', 'type': 'CF', 'location': 'Home', 'template': 'A1', 'actions': ['DecreaseSpeed', 'IncreaseSpeed', 'SetDirection', 'SetSpeed', 'StartDimmer', 'Stop', 'ToggleDirection', 'ToggleLight', 'TogglePower', 'TurnLightOff', 'TurnLightOn', 'TurnOff', 'TurnOn'], '_': '21x2xbx7', '__': '539e81fd', 'commands': {'_': '55cb208e'}, 'state': {'_': '7969c7fd'}, 'properties': {'_': 'b69cddd5'}, 'skeds': {'_': '00000000'}}, '9x2xbx6x4x4xdx91': {'name': 'Guest Room Fan', 'type': 'CF', 'location': 'Home', 'template': 'C2', 'actions': ['DecreaseSpeed', 'IncreaseSpeed', 'SetSpeed', 'StartDimmer', 'Stop', 'ToggleLight', 'TogglePower', 'TurnLightOff', 'TurnLightOn', 'TurnOff', 'TurnOn'], '_': '4x14x7bx', '__': '493a3ba0', 'commands': {'_': '95258868'}, 'state': {'_': '87752b7d'}, 'properties': {'_': '7fcc4eea'}, 'skeds': {'_': '00000000'}}, 'e3x6ex3fx86xebx9': {'name': 'Workout Room Fan', 'type': 'CF', 'location': 'Home', 'template': 'C2', 'actions': ['DecreaseSpeed', 'IncreaseSpeed', 'SetSpeed', 'StartDimmer', 'Stop', 'ToggleLight', 'TogglePower', 'TurnLightOff', 'TurnLightOn', 'TurnOff', 'TurnOn'], '_': '4x2ex0ax', '__': '47bcf3ed', 'commands': {'_': 'd931abe0'}, 'state': {'_': '86b7414a'}, 'properties': {'_': 'c4ce42ae'}, 'skeds': {'_': '00000000'}}}}
   Bond Home                       FamilyRommFanSpeed: Starting bondDevice Device 964348453
   Bond Home                       OfficeFan: Starting bondDevice Device 1988890919
   Bond Home                       OfficeFanLight: Starting bondDevice Device 266586765
   Bond Home                       OfficeFanSpeed: Starting bondDevice Device 612019617
   Bond Home Debug                 FamilyRommFanSpeed: doDeviceStartup: bondDevice (72x56x7fx11xebxa)
   Bond Home Debug                 FamilyRommFanSpeed: doDeviceStartup: using bond_id = ZXFHX23X4
   Bond Home Debug                 FamilyRommFanSpeed: Updating Device info:
   Bond Home Debug                 get_device_state: 72x56x7fx11xebxa
   Bond Home Debug                 Family Room Fan (72x56x7fx11xebxa): Device states: {'power': 1, 'speed': 1, 'direction': -1, 'light': 0, '_': '7969c7fd', '__': '7969c7fd'}
   Bond Home Debug                 OfficeFanSpeed: doDeviceStartup: bondDevice (5c0x47x83xa69x58)
   Bond Home Debug                 OfficeFanSpeed: doDeviceStartup: using bond_id = ZXFHX23X4
   Bond Home Debug                 OfficeFanSpeed: Updating Device info:
   Bond Home Debug                 get_device_state: 5c0x47x83xa69x58
   Bond Home Debug                 Office Fan (5c0x47x83xa69x58): Device states: {'power': 0, 'speed': 1, 'light': 1, '_': '87752b7d', '__': '87752b7d'}
   Bond Home                       Family Room Fan (72x56x7fx11xebxa): Stopping bondDevice Device 964348453
   Bond Home                       Family Room Fan (72x56x7fx11xebxa): Starting bondDevice Device 964348453
   Bond Home                       Office Fan (5c0x47x83xa69x58): Stopping bondDevice Device 612019617
   Bond Home                       Office Fan (5c0x47x83xa69x58): Starting bondDevice Device 612019617
   Bond Home Debug                 device_action, url = http://192.168.100.194/v2/devices/5c0x47x83xa69x58/actions/DecreaseSpeed, payload = {}
   Bond Home Debug                 device_action, url = http://192.168.100.194/v2/devices/5c0x47x83xa69x58/actions/IncreaseSpeed, payload = {}
type: 400 Client Error: Bad Request for url: http://192.168.100.194/v2/devices/5c0x47x83xa69x58/actions/IncreaseSpeed
Tue Feb 28, 2023 12:32 pm
So decreasing speed works, but increasing does not. Hmmm.
Tue Feb 28, 2023 5:02 pm
vvrangler offline
Yes, and I looked at the API docs and it definitely appears to be the correct command.
I also tried it on t different fan models just in case and got the same result for both.
