"Smart by Bond" devices don't work with new plugin version
Mon Mar 29, 2021 9:21 am
katiaf offline
FYI, the latest plugin update broke my device and bridge. I tried opening and saving the bridge and device and when that didn't work I tried creating as new but nothing worked. I believe it may not have my device as an option (I have one of those fans with the integrated "smart by bond" bridge). I reverted to the previous plugin and everything works now, but I wanted to let you know.
Mon Mar 29, 2021 9:23 am
Re: New Plugin - Bond Home
Can you turn on debug logging, switch to the new plugin, use the "write device information to log" menu command, then switch back. And then post the log.
Mon Mar 29, 2021 4:53 pm
katiaf offline
I was not able to follow the instructions fully (could not find the "write device information to log"), but here is the log after activating debug mode.
Mar 29, 2021 at 6:46:41 PM
   Bond Home Debug                 closedPrefsConfigUi, logLevel = 5
Mar 29, 2021 at 6:49:07 PM
   Bond Home Debug                 getDeviceConfigUiValues, typeId = bondDevice, devId = 484200233, pluginProps = UiValuesDict : (dict)
     address : 1 (string)
     bond_type :  (string)
     bridge : 798899409 (string)
     off_command :  (string)
     on_command :  (string)
   Bond Home Debug                 get_action_list: typeId = bondDevice, targetId = 484200233, filter = , valuesDict = UiValuesDict : (dict)
   Bond Home Error                 Error in plugin execution GetUiDynamicList:
  File "plugin.py", line 299, in get_action_list
KeyError: (u'798899409',)
   Bond Home Debug                 get_bridge_list: typeId = bondDevice, targetId = 484200233, filter = , valuesDict = UiValuesDict : (dict)
   Bond Home Debug                 get_bridge_list adding: Office Fan Bond
  File "plugin.py", line 258, in get_bridge_list
KeyError: key bondid not found in dict
   Bond Home Debug                 get_device_list: typeId = bondDevice, targetId = 484200233, filter = , valuesDict = UiValuesDict : (dict)
  File "plugin.py", line 269, in get_device_list
   Bond Home Debug                 validateDeviceConfigUi, typeId = bondDevice, valuesDict = UiValuesDict : (dict)
     address :  (string)
     bridge :  (string)
   Bond Home                       Office Fan through plugin: Stopping bondDevice Device 484200233
   Bond Home Debug                 Office Fan through plugin: Skipping bondDevice device
   Bond Home                       Office Fan through plugin: Starting bondDevice Device 484200233
   Bond Home Error                 Error in plugin execution ServerReplacedElem:
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
  File "plugin.py", line 134, in deviceStartComm
KeyError: (u'',)
Mon Mar 29, 2021 5:00 pm
It's a menu command:
Screen Shot 2021-03-29 at 6.58.48 PM.png (285.73 KiB) Viewed 5069 times
Mon Mar 29, 2021 5:01 pm
katiaf offline
Ok, if I do that I only get this:
Mar 29, 2021 at 6:57:56 PM
   Bond Home
Here is some more logs after restarting the plugin:
Mar 29, 2021 at 6:56:55 PM
   Reloading plugin "Bond Home 0.1.2"
   Stopping plugin "Bond Home 0.1.2" (pid 62292)
   Bond Home                       Office Fan Bond: Stopping bondBridge Device 798899409
   Bond Home Error                 exception in deviceStopComm(Office Fan Bond): 'key bondid not found in dict'
   Bond Home                       Office Fan Change Direction: Stopping bondRelay Device 516262
   Bond Home Error                 Office Fan Change Direction: deviceStopComm: Unknown device type: bondRelay
   Bond Home                       Office Fan Light Brightness: Stopping bondRelay Device 1621741078
   Bond Home Error                 Office Fan Light Brightness: deviceStopComm: Unknown device type: bondRelay
   Bond Home                       Office Fan Light On/Off: Stopping bondRelay Device 273526006
   Bond Home Error                 Office Fan Light On/Off: deviceStopComm: Unknown device type: bondRelay
   Bond Home                       Office Fan On/Off: Stopping bondRelay Device 18599189
   Bond Home Error                 Office Fan On/Off: deviceStopComm: Unknown device type: bondRelay
   Bond Home                       Stopping BondHome
   Stopped plugin "Bond Home 0.1.2"
   Starting plugin "Bond Home 0.1.2" (pid 25732)
   Bond Home Debug                 logLevel = 5
   Started plugin "Bond Home 0.1.2"
   Bond Home                       Starting BondHome
   Bond Home                       Office Fan Bond: Starting bondBridge Device 798899409
   Bond Home Debug                 BondHome __init__ address = 192.168.1.100, token = *********
   Bond Home Debug                 get_bridge_version()
   Bond Home Debug                 Office Fan Bond: BondHome version: {u'uptime_s': 17901, u'branding_profile': u'MINKA_F747L', u'target': u'breck-spitfire', u'make': u'Minka', u'fw_date': u'Thu Oct 22 18:39:59 UTC 2020', u'fw_ver': u'v2.15', u'api': 2, u'model': u'F747L', u'bondid': u'KSMWTCE82430', u'_': u'9664b0f7', u'upgrade_http': True}
   Bond Home Debug                 get_bridge_info()
   Bond Home Error                 exception in deviceStartComm(Office Fan Bond): 404 Client Error: Not Found for url: http://192.168.1.100/v2/bridge
   Bond Home                       Office Fan Change Direction: Starting bondRelay Device 516262
   Bond Home Error                 Office Fan Change Direction: deviceStartComm: Unknown device type: bondRelay
   Bond Home                       Office Fan Light Brightness: Starting bondRelay Device 1621741078
   Bond Home Error                 Office Fan Light Brightness: deviceStartComm: Unknown device type: bondRelay
   Bond Home                       Office Fan Light On/Off: Starting bondRelay Device 273526006
   Bond Home Error                 Office Fan Light On/Off: deviceStartComm: Unknown device type: bondRelay
   Bond Home                       Office Fan On/Off: Starting bondRelay Device 18599189
   Bond Home Error                 Office Fan On/Off: deviceStartComm: Unknown device type: bondRelay
   Bond Home Error                 exception in deviceStartComm(Office Fan through plugin): u''
Mon Mar 29, 2021 5:05 pm
Please disable (uncheck the "Comm Enabled" column) for all the Bond devices except the bridge itself, then restart the plugin. Then enable ONE device. Post the complete log starting from the plugin restart. Thanks.
Mon Mar 29, 2021 5:21 pm
katiaf offline
Starting plugin "Bond Home 0.1.2" (pid 36521)
   Bond Home Debug                 Office Fan Bond: BondHome version: {u'uptime_s': 19226, u'branding_profile': u'MINKA_F747L', u'target': u'breck-spitfire', u'make': u'Minka', u'fw_date': u'Thu Oct 22 18:39:59 UTC 2020', u'fw_ver': u'v2.15', u'api': 2, u'model': u'F747L', u'bondid': u'KSMWTCE82430', u'_': u'9664b0f7', u'upgrade_http': True}
Mar 29, 2021 at 7:19:42 PM
Mon Mar 29, 2021 5:59 pm
So you don't have a bridge device at all, just the fan with a built in Bond interface? And this worked with the older plugin?
Mon Mar 29, 2021 6:15 pm
katiaf offline
Yes. You can find my message from 12/18/2019 in this same thread:
I was able to add my Minka Aire fan with integrated BOND (by first adding the bridge, then the fan as a device). It works well and I can do what I did with the curl commands. Thanks!
It has been working fine for over a year.
Mon Mar 29, 2021 6:17 pm
OK, I see what's going on. I'll have something for you to test tomorrow, I think. I'm going to split this to a separate thread, since it's specific to the "Smart by Bond" devices.
Mon Mar 29, 2021 6:26 pm
Re: "Smart by Bond" devices don't work with new plugin vers
All this because I added API calls to control the blue light on the bridge, which don't work with your device. Oops.
Mon Mar 29, 2021 10:02 pm
katiaf offline
No problem, thanks for the help. I will revert again to the previous version temporarily.
Tue Mar 30, 2021 2:51 pm
This issue is now being tracked on GitHub: https://github.com/FlyingDiver/Indigo-BondHome/issues/5
I've got two choices to fix this, I think. First is a simple fix to the bridge device, so it'll work as before, but it still will require two Indigo devices - one for the bridge, another for the fan. The other choice is to combine them both into the same Indigo device. The first is easier, but the second is probably better for the end user. Hmmm.
Tue Mar 30, 2021 5:44 pm
katiaf offline
The setup is a one time thing, so I don't mind the easy way. However, if you'd like to go for the more challenging way that is fine too - my fan is running fine with the previous version so it can wait.
Thanks again
Tue Mar 30, 2021 6:02 pm
Can you run the device info menu command using the old plugin and post the log?
