Oh sorry I didn’t see your post regarding it! My system is all disconnected at the moment as I’m doing a big upgrade but as soon as that’s done I’ll take it for a spin!
Occupatum Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 68, in runConcurrentThread
type: name 'device' is not defined
Occupatum Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Stopped plugin "Occupatum 2022.0.3"
Debugging plugin "Occupatum 2022.0.3" (pid 24931)
Started plugin "Occupatum 2022.0.3"
Downgrading plugin Occupatum to older version 2022.0.2 (previous version moved to trash)
Loading plugin "Occupatum 2022.0.2" using API v3.0
Starting plugin "Occupatum 2022.0.2" (pid 24940)
Started plugin "Occupatum 2022.0.2"
tazswe wrote:When you cancel the timer in a action group it will only show “cancel timer for zone” but it will not show which zone in the list that show all the actions. It should be nice if it also showed the zone.
I can see that there is the same problem with the timed devices plugin so I’m not sure if it’s a problem in the plugin or in Indigo.
Londonmark wrote:What is the difference between an occupancy zone and an activity zone?
Occupatum Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 56, in deviceUpdated
File "plugin.py", line 174, in checkSensors
File "plugin.py", line 174, in <listcomp>
type: key id 1951874049 not found in database
