Elgato Stream Deck plugin - early test release
Fri Aug 13, 2021 12:36 pm
Re: Elgato Stream Deck plugin - early test release
0.0.3 is the latest, but I'm not sure it's working properly. 0.0.2 was the version that supported StreamDeck and Indigo on different machines.
Wed Mar 30, 2022 5:16 pm
amannone offline
I can confirm 0.0.3 works on multiple machines. I have a Stream Deck Mini attached to the Indigo Server Mac and a Stream Deck XL attached to my work MBP.
However, I had the damndest time getting things working on the remote MBP. But, it turns out the indigo server field expects an IP address. I had been trying to use the host name (in my case it was indigo.local). After I switched to using the IP address of the indigo machine, everything works on the remote MBP. Would it be possible for the Indigo Server field to use a host name in addition to an IP address?
Just as an aside, I know this thread has been dormant for a while, but I am beyond thrilled for this plugin. Thank you so much for your efforts! I would be glad to help test new features and/or donate monetarily towards the development of the plugin.
Thanks again!
Cheers.
-Andrew
Wed Mar 30, 2022 5:56 pm
Someone who actually knows javascript would probably have to figure out why that's not working. I just barely got it working based on the posted examples. It LOOKS like it should take a hostname, but I don't know if an mDNS name (*.local) is resolvable by that code.
Maybe after the Indigo 2022.1 firedrill is over I can find someone to help debug that part of the code.
Wed Mar 30, 2022 6:15 pm
One more thing - please create an issue describing the problem (and your setup) here: https://github.com/FlyingDiver/Indigo-streamdeck/issues
