Well would you look at that!
I checked again and not sure what changed, but the device is now available to me. Amazing! thanks
Bond Home Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Reloading plugin "Bond Home 0.2.0"
Stopping plugin "Bond Home 0.2.0" (pid 79998)
Stopped plugin "Bond Home 0.2.0"
Starting plugin "Bond Home 0.2.0" (pid 43498)
Started plugin "Bond Home 0.2.0"
Error device "Bond Home" state key brightnessLevel not defined (ignoring update request)
Bond Home Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 244, in runConcurrentThread
File "plugin.py", line 191, in doDeviceStartup
KeyError: (u'1993245836',)
ryanbuckner wrote:Just upgraded to v0.2.0 and started getting these errors:
FlyingDiver wrote:ryanbuckner wrote:Just upgraded to v0.2.0 and started getting these errors:
Upgraded from what version? You need to edit all your devices going to 0.2.X to set the device types.
type: Bond Home
Model: Bond Device
FlyingDiver wrote:Yeah, this is probably a bug that I haven't been able to fix yet. The most straightforward solution is to delete all the Bond devices and recreate them.
Aug 20, 2021 at 1:54:34 PM
Stopping plugin "Bond Home 0.2.0" (pid 9980)
Starting plugin "Bond Home 0.2.0" (pid 11558)
File "plugin.py", line 199, in doDeviceStartup
UnicodeEncodeError: 'ascii' codec can't encode character u'\u2019' in position 5: ordinal not in range(128)
Received INSTEON "Basement Bathroom Motion Sensor" off (button 1)
File "plugin.py", line 201, in doDeviceStartup
ValueError: NameNotUniqueError
FlyingDiver wrote:That looks like a unicode bug. Please submit an issue in GotHub for it. In the mean time, make sure all your devices (in Indigo and the bond app) are plain ASCII, no unicode characters (include fancy quotes).
spiv wrote:I think this is straightforward. Can I use the Lutron plugin "linking to another device" or do I set this up with button triggers for every Pico keypress? Looking for recommendation on how to set this up before I dive in and do it.
Users browsing this forum: hamw and 4 guests
