Different Computers wrote:For those of us who may not realize how much we need this, could you describe a use case?
FlyingDiver wrote:Different Computers wrote:For those of us who may not realize how much we need this, could you describe a use case?
Not me. I'm doing this one on request. I don't have a use case.
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import socket
import struct
message = u"Unicode Message é î ø ó á å"
multicast_group = ('224.3.29.71', 10000)
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
ttl = struct.pack('b', 1)
sock.setsockopt(socket.IPPROTO_IP, socket.IP_MULTICAST_TTL, ttl)
sock.sendto(message.encode('utf-8'), multicast_group)
sock.close()
Starting plugin "UDP Listener 0.0.3" (pid 8397)
UDP Listener Debug logLevel = 5
Started plugin "UDP Listener 0.0.3"
UDP Listener Starting UDP Listener
UDP Listener Debug Daikin Listener: Device Current Version = 0
UDP Listener Debug Daikin Listener: Device Version is up to date
UDP Listener Debug Daikin Listener: Starting device (udpListener)
UDP Listener Debug Daikin Listener: UDP msg from: ('192.XXX.XX.XXX', YYYY), data: c0:25:06:bd:4b:3b:04:3d:07:d0:00:00:0a:5d:0b:f9:0d:11:54:69:6d:65:20:4e:4f:54:20:53:45:54:00:00:77:69:66:6c:79:2d:45:5a:58:20:56:65:72:20:34:2e:30:30:2e:31:2c:20:41:70:72:20:31:39:44:61:69:6b:69:6e:41:43:3a:31:30:36:32:34:30:35:39:34:00:00:00:00:00:00:00:00:00:00:00:00:00:00:f5:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
Error XML Parse Error: not well-formed (invalid token)
Error On character 580 of line number 1.
mclass wrote:Here's the event log with the error appearing every 6-8 seconds - the period that the Daikin AC sends the message. Only the IP and port numbers have been changed to protect the innocent!!
- Code: Select all
UDP Listener Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 107, in runConcurrentThread
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc5 in position 8: ordinal not in range(128)
UDP Listener Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Starting plugin "UDP Listener 0.0.4" (pid 99716)
Started plugin "UDP Listener 0.0.4"
UDP Listener Debug BETA RakoListener: Device Current Version = 0
UDP Listener Debug BETA RakoListener: Device Version is up to date
UDP Listener Debug BETA RakoListener: Starting device (udpListener)
UDP Listener Error exception in deviceStartComm(BETA RakoListener): 'key multiGroup not found in dict'
