Roomba Plugin Broken
Sun Feb 12, 2017 4:46 pm
iRobot release version 2.0.0-34 of the Roomba firmware, which changed the network protocol used to communicate with the robot. As a result, the plugin is unusable until the new protocol is reverse engineered.
Progress is being made on this (not by me), and as soon as a working implementation is available, I will update the plugin. If you're interested in following progress on this, go to https://github.com/koalazak/dorita980/issues/10
Tue Feb 14, 2017 4:27 pm
Re: Roomba Plugin Broken
Well, the new API has been reverse engineered, but the only implementation is in JavaScript, and it uses the MQTT protocol (instead of HTTP). So it's going to take a few days to get it ported to Python.
Wed Feb 15, 2017 6:10 pm
GlennNZ offline
Good luck!
I can't stand javascript.
(I did look at script to convert from javascript to python - which seemed to work but produced the most unreadable code I have ever seen and didn't really seem like a good solution.)
Glenn
Thu May 25, 2017 9:56 pm
GlennNZ offline
Hi Joe,
I have rewritten plugin/used it as base to work with new firmware and mqtt protocol.
See here:
viewtopic.php?f=222&t=18426
Glenn
