Purple Air sensor plugin
Fri May 27, 2022 6:34 pm
wikner offline
Re: Purple Air sensor plugin
FlyingDiver wrote:
Hmm. I thought I worked around that issue. Let me work on it. That's why it's a pre-release.
I could delete my devices. Unfortunately that would also delete my triggers based on them. But those are fairly simple; I could rebuild them. I'll just wait a while. The air is pretty clear here in Denver right now. No wildfires affecting us just yet...
Fri May 27, 2022 6:35 pm
Better yet, delete the prefs file. That should force the config dialog to come up before it actually starts the plugin.
Fri May 27, 2022 6:37 pm
wikner offline
What prefs file? Where?
Fri May 27, 2022 6:38 pm
Here:
Screen Shot 2022-05-27 at 8.38.16 PM.png (275.84 KiB) Viewed 1912 times
Fri May 27, 2022 6:47 pm
wikner offline
Alas, that did not help.
Shut down server
Found & removed prefs file
Restarted server.
 miniPurple Error                API Read Key must be specified in Plugin Config
   Started plugin "Pushover 2022.0.0"
   Started plugin "WeatherSnoop 3.2.0"
   miniPurple Error                Error in plugin execution InitializeMain:
  File "plugin.py", line 39, in __init__
type: ('api_key_type',)
   Stopping plugin "miniPurple 2022.1.0" (pid 59880)
   Waiting for external plugins to initialize
   Stopped plugin "miniPurple 2022.1.0"
   Starting triggers and schedules
May 27, 2022 at 6:44:33 PM
   Connected to PowerLinc 2413U interface on port usbserial-A6008aaV
   PowerLinc address 14.84.E8, firmware version 9.2
May 27, 2022 at 6:44:51 PM
   Reloading plugin "miniPurple 2022.1.0" using API v3.0
   Starting plugin "miniPurple 2022.1.0" (pid 59893)
   Stopping plugin "miniPurple 2022.1.0" (pid 59893)
Fri May 27, 2022 6:48 pm
OK, I'll have to recode that section to deal with API key.
Fri May 27, 2022 6:54 pm
Fri May 27, 2022 11:35 pm
wikner offline
That appears to be working. To quote Firesign Theater (I Think We're all Bozos on this Bus): "Well, you're a wizard, WHOEVER you are!"
Norman
