New Plugin - Bond Home
Fri Oct 16, 2020 4:01 am
jamesm offline
Re: New Plugin - Bond Home
using a bond bridge and the iOS app to control a ceiling fan and fireplace.
looking to integrate the bond bridge into indigo then HomeKit via the HomeKit bridge...
i found the device ip address, but where do i find the local token?
after the plugin is properly set up - how do i then integrate the commands currently set up to the bond bridge onto the HomeKit bridge?
in other words, im guessing the bond functions won't auto populate as a device i can simply add to a HomeKit bridge..
many thx
Fri Oct 16, 2020 4:18 am
jamesm offline
scratch the part on the local token, found that in the app.
Fri Oct 16, 2020 5:30 am
Set up the Bond Home Bridge device with the IP address and token. The plugin retrieves the devices the bridge knows about. Create a Generic or Relay device for each. Test that you can control them directly from the Indigo UI. Then add them to HKB.
Fri Oct 16, 2020 8:47 am
jamesm offline
ty for the reply. any advice on where to look up how to create a Generic or Relay device for each?
Fri Oct 16, 2020 8:51 am
It's a plugin device type, like the bridge device. The plugin reads all the actions/devices you have defined using the iOS app and gives you a list:
Screen Shot 2020-10-16 at 10.50.49 AM.png (714.5 KiB) Viewed 5532 times
Fri Oct 16, 2020 8:53 am
jamesm offline
ahh, ty. didn't see the relay drop dn. going to try now
Fri Oct 16, 2020 8:56 am
jamesm offline
hmm, not seeing any devices populate.. i see select an item which is blank.
Fri Oct 16, 2020 9:13 am
Turn on detailed debugging then restart the plugin, then post the log contents after the restart.
And maybe a screen shot of what you're seeing.
Fri Oct 16, 2020 9:49 am
jamesm offline
Reloading plugin "Bond Home 0.0.2"
Stopping plugin "Bond Home 0.0.2" (pid 83203)
Bond Home Stopping BondHome
Stopped plugin "Bond Home 0.0.2"
Starting plugin "Bond Home 0.0.2" (pid 84534)
Bond Home Debug logLevel = 5
Started plugin "Bond Home 0.0.2"
Bond Home Starting BondHome
Ignored device "Fan" action request (communication is disabled)
Fri Oct 16, 2020 9:51 am
What happened to the Bridge device you created, that you put in the IP address and token?
Fri Oct 16, 2020 10:02 am
jamesm offline
i did. under model, bond home bridge, and the ip address and the local token off the app.
Fri Oct 16, 2020 10:03 am
t-star offline
Question. I have been looking at this Bond device. How will I know if it will work with my particular fans? Or is it just understood that it will pretty much work with any?
Fri Oct 16, 2020 10:04 am
It's not showing up in the log. There should be a line showing it as starting. Do you have it disabled? Unless that device is working correctly (communicating with the Bond bridge) nothing else is going to work.
It works with mine. If they use an RF remote, then it will probably work with yours. But the only way to really know is to try it.
Fri Oct 16, 2020 10:53 am
jamesm offline
im not seeing a green dot or the word running.
i installed the plug in. went to new:type:bond home:
then entered in the ip address and local token
