The device will be the ISS. If you haven’t created a device for that yet, you need to do so. Then you can create a Masquerade device based on one of the ISS states.
Feb 29, 2020 at 8:32:59 AM
Enabling plugin "WeatherLink Live 0.1.5"
Starting plugin "WeatherLink Live 0.1.5" (pid 5548)
Started plugin "WeatherLink Live 0.1.5"
WeatherLink Live Starting WeatherLink Live
WeatherLink Live Debug Internal Barometric : Starting Device
WeatherLink Live Debug Internal Barometric : getDeviceDisplayStateId returning: bar_sea_level
WeatherLink Live Debug Internal Barometric : deviceStartComm complete, sensorDevices = {389397522: <indigo.Device object at 0x105602488>}
WeatherLink Live Debug Outside Humidity: Starting Device
WeatherLink Live Debug Outside Humidity: getDeviceDisplayStateId returning: hum
WeatherLink Live Debug Outside Humidity: deviceStartComm complete, sensorDevices = {827828065: <indigo.Device object at 0x105602668>, 389397522: <indigo.Device object at 0x105602488>}
WeatherLink Live Debug Outside Temperature: Starting Device
WeatherLink Live Debug Outside Temperature: getDeviceDisplayStateId returning: temp
WeatherLink Live Debug Outside Temperature: deviceStartComm complete, sensorDevices = {827828065: <indigo.Device object at 0x105602668>, 389397522: <indigo.Device object at 0x105602488>, 141456850: <indigo.Device object at 0x1056026e0>}
WeatherLink Live Debug WeatherLink Base Station: Starting Device
WeatherLink Live Debug WeatherLink Base Station: getDeviceDisplayStateId returning: status
WeatherLink Live Debug WeatherLink __init__ address = 192.168.1.7, port = 80, pollFrequency = 300.0
WeatherLink Live Debug WeatherLink Base Station: deviceStartComm complete, sensorDevices = {827828065: <indigo.Device object at 0x105602668>, 389397522: <indigo.Device object at 0x105602488>, 141456850: <indigo.Device object at 0x1056026e0>}
WeatherLink Live Debug WeatherLink Internal Temp/Humidity: Starting Device
WeatherLink Live Debug WeatherLink Internal Temp/Humidity: getDeviceDisplayStateId returning: temp_in
WeatherLink Live Debug WeatherLink Internal Temp/Humidity: deviceStartComm complete, sensorDevices = {827828065: <indigo.Device object at 0x105602668>, 389397522: <indigo.Device object at 0x105602488>, 1776076858: <indigo.Device object at 0x1056027d0>, 141456850: <indigo.Device object at 0x1056026e0>}
WeatherLink Live Debug Wind_Speed: Starting Device
WeatherLink Live Debug Wind_Speed: getDeviceDisplayStateId returning: wind_speed_last
WeatherLink Live Debug Wind_Speed: deviceStartComm complete, sensorDevices = {827828065: <indigo.Device object at 0x105602668>, 389397522: <indigo.Device object at 0x105602488>, 1776076858: <indigo.Device object at 0x1056027d0>, 141456850: <indigo.Device object at 0x1056026e0>, 43128917: <indigo.Device object at 0x105602848>}
WeatherLink Live WeatherLink Base Station: Polling WeatherLink Live
WeatherLink Live Debug WeatherLink Base Station: http_poll success: did = 001D0A7111DE, ts = 1582993978, 3 conditions
WeatherLink Live Debug Added sensor 293838 to knownDevices: {'type': '1', 'lsid': '293838'}
WeatherLink Live Debug sensorDictToList: key = wind_dir_scalar_avg_last_1_min, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = rain_storm_start_at, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = rain_storm_last_end_at, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = wind_dir_scalar_avg_last_10_min, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = rain_storm, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = rain_storm_last, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = rain_storm_last_start_at, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug sensorDictToList: key = wind_dir_scalar_avg_last_2_min, value = None (<type 'NoneType'>) coerced to value 0
WeatherLink Live Debug Added sensor 293837 to knownDevices: {'type': '4', 'lsid': '293837'}
WeatherLink Live Debug Added sensor 293836 to knownDevices: {'type': '3', 'lsid': '293836'}
WeatherLink Live Debug WeatherLink Base Station: udp_start() broadcast_port = 22222, duration = 1200
WeatherLink Live Debug WeatherLink Base Station: udp_start() socket listener started
Disabling plugin "WeatherLink Live 0.1.5"
Stopping plugin "WeatherLink Live 0.1.5" (pid 5548)
WeatherLink Live Debug Internal Barometric : Stopping Device
WeatherLink Live Debug Internal Barometric : deviceStopComm complete, sensorDevices = {827828065: <indigo.Device object at 0x105602668>, 1776076858: <indigo.Device object at 0x1056027d0>, 141456850: <indigo.Device object at 0x1056026e0>, 43128917: <indigo.Device object at 0x105602848>}
WeatherLink Live Debug Outside Humidity: Stopping Device
WeatherLink Live Debug Outside Humidity: deviceStopComm complete, sensorDevices = {1776076858: <indigo.Device object at 0x1056027d0>, 141456850: <indigo.Device object at 0x1056026e0>, 43128917: <indigo.Device object at 0x105602848>}
WeatherLink Live Debug Outside Temperature: Stopping Device
WeatherLink Live Debug Outside Temperature: deviceStopComm complete, sensorDevices = {1776076858: <indigo.Device object at 0x1056027d0>, 43128917: <indigo.Device object at 0x105602848>}
WeatherLink Live Debug WeatherLink Base Station: Stopping Device
WeatherLink Live Debug WeatherLink Base Station: deviceStopComm complete, sensorDevices = {1776076858: <indigo.Device object at 0x1056027d0>, 43128917: <indigo.Device object at 0x105602848>}
WeatherLink Live Debug WeatherLink Internal Temp/Humidity: Stopping Device
WeatherLink Live Debug WeatherLink Internal Temp/Humidity: deviceStopComm complete, sensorDevices = {43128917: <indigo.Device object at 0x105602848>}
WeatherLink Live Debug Wind_Speed: Stopping Device
WeatherLink Live Debug Wind_Speed: deviceStopComm complete, sensorDevices = {}
WeatherLink Live Shutting down WeatherLink Live
Stopped plugin "WeatherLink Live 0.1.5"
WeatherLink Live Debug *PWS: PWS upload data = {'dateutc': '2020-10-18 18:16:23', 'softwaretype': 'Indigo WeatherLink Live', 'tempf': 37.2, 'yearrainin': 0.0, 'windspeedmph': 3.0, 'baromin': 25.01, 'rainin': 0.0, 'windgustmph': 7.0, 'humidity': 89.0, 'winddir': 84.0, 'dewptf': 34.3, 'monthrainin': 0.0, 'dailyrainin': 0.0, 'action': 'updateraw', 'PASSWORD': u'xxxxxxxxxxxxx', 'ID': u'XXXXXXXX'}
