New Plugin - Bond Home
Thu Apr 13, 2023 9:05 am
Different Computers offline
Re: New Plugin - Bond Home
Just upgraded to Ventura, and I'm seeing (I think for the first time) this in the indigo log:
Bond Home Error                 Error in plugin execution _postStartup:
  File "plugin.py", line 176, in _postStartup
  File "plugin.py", line 204, in doDeviceStartup
type: ('LT',)
However, as best I can tell, the plugin is working correctly.
Thu Apr 13, 2023 9:24 am
What kind of device is that?
Thu Apr 13, 2023 9:26 am
If it's not the Bond Bridge, I don't have the slightest idea. How would I tell?
Thu Apr 13, 2023 9:27 am
Oh, nevermind, they added some device types to the API. I'll need to update the plugin.
Exciting!
Thu Apr 13, 2023 9:35 am
Try this version and see if the error goes away:
https://github.com/FlyingDiver/Indigo-B ... g/2022.0.5
Tue May 16, 2023 8:16 pm
boisy offline
Joe,
I'm having an issue adding my Molino Fan which has built-in Bond support. When I create a new action group to control the fan, I get this error:
May 16, 2023 at 9:08:40 PM
   Action Group                    new action group
   Bond Home Error                 Error in plugin execution ExecuteAction:
  File "plugin.py", line 443, in doDeviceAction
type: ('KIMJAFB17184',)
"KIMJAFB17184" is actually the DNS name of the device.
What logging can I provide to help you troubleshoot this?
Wed May 17, 2023 8:32 am
It might be the dns name but it’s probably also the device ID reported in the json payload.
As usual, enable debug logging, restart the plugin, then trigger the error.
In this case please create a GitHub issue as I’m out of the country and won’t be able to look at this for a couple weeks. I probably won’t have forums access after tomorrow.
Mon May 22, 2023 4:48 am
boisy offline
Thanks Joe. I just created an issue on GitHub with log information. It appears that get_bridge_info() is erroring for that device.
