Purple Air sensor plugin
Sat Apr 16, 2022 2:55 pm
Re: Purple Air sensor plugin
Anyone still using this plugin? I'm porting it to Python3, but I cannot get a sensor ID from the map anymore. If you have a sensor ID that works, please let me know.
Sat Apr 16, 2022 2:59 pm
norcoscia offline
I have it running but since I could never figure out how to map the data I wanted to a trigger I have not messed with it in a while - I have it pointed to a station near my house - if that helps let me know and I will go look to see if it is still working and let you know which one it is…..
_______
Norm
Sat Apr 16, 2022 3:03 pm
Yeah, that's what I need.
Sat Apr 16, 2022 3:40 pm
norcoscia offline
Looks like the one I mapped to has not reported in several days but another close to that one is reporting. Its ID is 81321
Let me know if that is not what you need. I owe you about a million favors so happy to help with anything you need...
_______
Norm
Sat Apr 16, 2022 3:47 pm
That worked.
Sat Apr 16, 2022 3:49 pm
norcoscia offline
Switched to the working one -- my logic is, if sensor value is above 50 and I have a window open send me an email - seems to be valid so guess it is still good and seems to be working now.
_______
Norm
Mon May 23, 2022 5:12 pm
wikner offline
Errors since Indigo upgrade
My event log is filled up with the following:
   Error                           device "mini AQI Exterior" state key pm2_5_current not defined (ignoring update request)
   Error                           device "mini AQI Exterior" state key pm2_5_10m not defined (ignoring update request)
   Error                           device "mini AQI Exterior" state key pm2_5_30m not defined (ignoring update request)
   Error                           device "mini AQI Exterior" state key pm2_5_1h not defined (ignoring update request)
   Error                           device "mini AQI Exterior" state key pm2_5_6h not defined (ignoring update request)
   Error                           device "mini AQI Exterior" state key pm2_5_24h not defined (ignoring update request)
   Error                           device "mini AQI Exterior" state key pm2_5_1w not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_current not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_10m not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_30m not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_1h not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_6h not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_24h not defined (ignoring update request)
   Error                           device "mini AQI Interior" state key pm2_5_1w not defined (ignoring update request)
Indigo Version 2022.1
Mon May 23, 2022 5:36 pm
norcoscia offline
Is that from a remote station or do you have a unit in your house - I’m not sure if anyone tested with a local unit - I was going to buy one but they where backordered over 4 months at the time and they wanted to charge me as soon as I ordered - so I never did get one.
If you do have one I would be interested in knowing what you think about it - fire season is just around the corner :-(
_______
Norm
Mon May 23, 2022 5:49 pm
Re: Errors since Indigo upgrade
The the Indigo device and save it, see if that makes it stop.
Mon May 23, 2022 5:52 pm
wikner offline
I think part of your sentence was cut off. Not sure what you want me to do.
Mon May 23, 2022 5:53 pm
EDIT the Indigo device. Sorry.
Mon May 23, 2022 5:57 pm
wikner offline
I have 2 devices, one interior and one exterior (as you can see from the logs I posted). The plugin uses the web interface to these devices, so it doesn't matter if you use your own or someone else's. I got them for the same reason you mention. Smoke from fires getting into may lungs. I have Indigo send me alerts when the AQI goes bad.
The devices themselves work well. My outdoor one failed after about a year, and it was replaced for free. Now my indoor one has had it's LED's fail. That's actually a good thing for me, as I don't have this constantly glowing thing on my countertop. I have to look in Indigo or on the web to get its output, but the LED's gave only an approximate reading anyway.
Mon May 23, 2022 6:02 pm
wikner offline
OK, that seems to have worked. Was getting those errors once per minute; now none for the past 5 minutes.
Mon May 23, 2022 6:35 pm
norcoscia offline
Thanks - I’m going to look into them again.
We added a few indoor WINIX HEPA air filters (when they were on sale at COSCTO). Best money we have spent in a long time. My wife has really bad seasonal allergies and since we have been using them she has been a million times better (plus they are totally silent).
I use Indigo to open and close the outside air vent to my HVAC system to pull in clean air when the temps are not going to kill efficiency. I could also tie in air quality to make sure it does not come on if above a threshold (if I had purple air sensors). I just don’t trust a remote station since I have no control over it.
_______
Norm
Mon May 23, 2022 6:43 pm
FWIW, I have a plugin for the Davis WeatherLink which also supports their AirLink device. One advantage is that it's all local LAN access, no Internet required.
