Juggler wrote:Should the dimming work with z-wave devices? I have a Leviton VRPD3-1LW (lamp module). It is behaving the same way, i.e. press the "-" button and it turns off.
Have you updated to the latest release per the link above?
LIFX Bridge Debug LightSetColor command is for device: livingroom table lamp, payload = [('Color', (18432, 33343, 0, 47872)), ('Duration', 256011)]
LIFX Bridge Debug LightSetColor command is for device: under walkway, payload = [('Color', (18432, 33343, 26112, 48051)), ('Duration', 256011)]
Top light button pushed once
LIFX Bridge Debug logLevel = 10
LIFX Bridge Debug lifxRespond, seq_num = 231, type = 117, target = 00:16:0d:7b:35:5b
LIFX Bridge Debug LightSetPower command is for device: under walkway, payload = [('Power', 65535), ('Duration', 1000)]
LIFX Bridge Set on state of device 202061131 to 65535
Sent INSTEON "under walkway" on to 100
- button pushed once
LIFX Bridge Debug lifxRespond, seq_num = 232, type = 102, target = 00:16:0d:7b:35:5b
LIFX Bridge Debug LightSetColor command is for device: under walkway, payload = [('Color', (18432, 33343, 49920, 47969)), ('Duration', 256011)]
LIFX Bridge Set brightness of device 202061131 to 49920
LIFX Bridge Debug lifxRespond, seq_num = 233, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug LightGet message, replying for: under walkway
LIFX Bridge Debug lifxRespond, seq_num = 234, type = 32, target = 00:00:00:00:00:00
Sent INSTEON "under walkway" on to 76
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 233, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 234, type = 32, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, seq_num = 235, type = 102, target = 00:16:0d:7b:35:5b
LIFX Bridge Debug LightSetColor command is for device: under walkway, payload = [('Color', (18432, 33343, 52480, 48102)), ('Duration', 256011)]
LIFX Bridge Set brightness of device 202061131 to 52480
LIFX Bridge Debug lifxRespond, seq_num = 236, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, seq_num = 237, type = 32, target = 00:00:00:00:00:00
Sent INSTEON "under walkway" on to 80
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 236, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 237, type = 32, target = 00:00:00:00:00:00
- button pushed twice
LIFX Bridge Debug lifxRespond, seq_num = 238, type = 102, target = 00:16:0d:7b:35:5b
LIFX Bridge Debug LightSetColor command is for device: under walkway, payload = [('Color', (18432, 33343, 20992, 48041)), ('Duration', 256011)]
LIFX Bridge Set brightness of device 202061131 to 20992
LIFX Bridge Debug lifxRespond, seq_num = 239, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, seq_num = 240, type = 32, target = 00:00:00:00:00:00
Sent INSTEON "under walkway" on to 32
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 238, type = 102, target = 00:16:0d:7b:35:5b
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 239, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 240, type = 32, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, seq_num = 241, type = 102, target = 00:16:0d:7b:35:5b
LIFX Bridge Set brightness of device 202061131 to 26112
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 241, type = 102, target = 00:16:0d:7b:35:5b
Sent INSTEON "under walkway" on to 39
top light button pushed
LIFX Bridge Debug lifxRespond, seq_num = 247, type = 117, target = 00:16:0d:7b:35:5b
- button pushed
LIFX Bridge Debug lifxRespond, seq_num = 248, type = 102, target = 00:16:0d:7b:35:5b
LIFX Bridge Debug LightSetColor command is for device: under walkway, payload = [('Color', (18432, 33343, 0, 47872)), ('Duration', 256011)]
LIFX Bridge Set brightness of device 202061131 to 0
LIFX Bridge Debug lifxRespond, seq_num = 249, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, seq_num = 250, type = 32, target = 00:00:00:00:00:00
Sent INSTEON "under walkway" on to 0
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 249, type = 101, target = 00:00:00:00:00:00
LIFX Bridge Debug lifxRespond, skipping repeat seq_num = 250, type = 32, target = 00:00:00:00:00:00
DVDDave wrote:I'll try to research it some more on the Harmony side and report the bug to Logitech.
