Lifx Bridge Devices not active
Tue Jan 24, 2017 6:57 am
Albatros offline
First, thanks for the great harmony en lifx plugins.
I have got the Lifx bridge plugin working. The devices I have defined show up on my remote but after a while the devices show as "not active" on de harmony remote an I can't use them. When I restart the plugin they will work a gain. Don't know what is causing the plugin to stop working.
Tue Jan 24, 2017 8:48 am
FlyingDiver online
Re: Lifx Bridge Devices not active
I've never seen that. I only have a companion remote (no display). But I've never seen that on the Harmony app either.
What kind of devices are you publishing via the bridge?
Tue Jan 24, 2017 8:56 am
Albatros offline
I have published from Indigo into the Lifx Plugin; Hue devices, z-wave and a virtual device.
Also have Hue on the Harmony Hub so maybe this is something. I also have noticed that when I pick-up the remote, the display of the elite is than going on, this is shown in the Indigo log:
   Harmony Hub Debug               Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
   Harmony Hub Debug               Harmony Hub Woonkamer: Device: lifx-0:22:0:39:92:153, status: 2, brightness: 254, on: True
   Harmony Hub Debug               Harmony Hub Woonkamer: Device: lifx-0:22:66:213:39:127, status: 2, brightness: 0, on: False
   Harmony Hub Debug               Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 254, on: True
   Harmony Hub Debug               Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 254, on: True
Tue Jan 24, 2017 8:59 am
FlyingDiver online
The hub can control Hue lights directly, can't it? If so, you should not republish them through the LIFX bridge. Doing so enables looping issues.
Tue Jan 24, 2017 9:01 am
Albatros offline
Ok will try with z-wave only and see if it stay's connected.
Any Idea why it shows the lifx message in the log when I pick-up the remote?
Tue Jan 24, 2017 9:09 am
Albatros offline
Other thing I have is that I have e second harmony hub in my bedroom. This hub is connected to a TP-Link accespoint which has the same SSID name as my router but I am not able to get the LIFX Bridge devices on the Hub.
Tue Jan 24, 2017 9:24 am
FlyingDiver online
Those messages appear when the hub is updating any remotes with changed status of automation devices. As far as the hub is concerned, the Indigo plugin is a remote. I think maybe your remote is sending some sort of "I'm awake" message to the hub, and then the hub is sending device status updates to the remote, which Indigo is seeing. Since I don't have an Elite remote, I've never seen those.
Tue Jan 24, 2017 9:27 am
FlyingDiver online
The TP-Link might not be sending all broadcast or multi-cast messages through. If you move that Hub closer to your primary WiFi access point, does it work?
Tue Jan 24, 2017 10:46 am
Albatros offline
I have setup the second harmony hub near my router and that worked. So in the Harmony app the 2 devices which I have added show but as "not ready" and I can't resync as the hub is now upstairs and connect via the acces point.
Putting it back downstairs and connected to the router it works again.
Tue Jan 24, 2017 10:57 am
FlyingDiver online
That's definitely a networking problem, not a plugin problem. You might want to try TP-Link support and ask them.
Tue Jan 24, 2017 11:14 am
Albatros offline
Ok will check what I can do with TP-Link
How can we troubleshoot the "no connection" problem on my hub downstairs. I have now only two z-wave devices in the lifx bridge. But again after working for a while I have got no connection on the remote and can't control them. Reloading the plugin fixes the problem.
Tue Jan 24, 2017 11:24 am
FlyingDiver online
Turn on debugging on the LIFX Bridge plugin and post what's happening when they loose connection. You're reloading the LIFX-Bridge plugin, not the HarmonyHub plugin, right?
Wed Feb 01, 2017 4:45 pm
Albatros offline
Difficult to catch but I have reloaded the plugin at 8:00 PM and I think arround 11:15 pm it lost connection. At 11:35 I noticed on the harmony remote it lost connection. This is the log:
2017-02-01 23:05:10.033 LIFX Bridge Debug lifxRespond, processing message seq_num = 205
2017-02-01 23:05:10.194 LIFX Bridge Debug lifxRespond, processing message seq_num = 206
2017-02-01 23:05:10.314 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:10.421 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:10.528 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:10.635 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:10.744 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:10.853 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:10.964 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:11.075 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:11.183 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:11.296 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:11.405 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:11.513 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:11.622 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:11.730 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:11.837 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:11.943 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:12.054 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 205
2017-02-01 23:05:12.164 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 206
2017-02-01 23:05:12.633 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:05:12.634 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:05:12.654 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:05:12.656 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:06:00.721 Schedule Daikin Standen Ophalen
2017-02-01 23:06:00.722 Action Group Daikin Standen Woonkamer
2017-02-01 23:06:00.723 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:06:05.721 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:06:05.722 Action Group Daikin Standen TN
2017-02-01 23:06:10.720 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:06:10.722 Action Group Daikin Standen Nick
2017-02-01 23:06:15.720 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:06:15.722 Action Group Daikin Standen Jesper
2017-02-01 23:06:16.517 LIFX Bridge Debug lifxRespond, processing message seq_num = 207
2017-02-01 23:06:16.669 LIFX Bridge Debug lifxRespond, processing message seq_num = 208
2017-02-01 23:06:16.785 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:16.896 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:17.005 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:17.111 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:17.219 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:17.327 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:17.432 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:17.542 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:17.651 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:17.758 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:17.868 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:17.975 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:18.087 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:18.196 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:18.303 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:18.412 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:18.525 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 207
2017-02-01 23:06:18.632 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 208
2017-02-01 23:06:19.146 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:06:19.147 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:06:19.172 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:06:19.174 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:06:23.478 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 4C 0C 60 0D 02 02 31 05 01 44 00 00 06 9D 2E
2017-02-01 23:06:23.801 Z-Wave Debug . . multiEndPointPacket: node 076, endPoint 2
2017-02-01 23:06:23.802 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 4C 08 31 05 01 44 00 00 06 9D FF
2017-02-01 23:06:23.803 Z-Wave Debug . . requestVarSensorStatus: node 076, endpoint 2, type 1, raw value 4400...
2017-02-01 23:06:23.804 Z-Wave Debug . . requestVarSensorStatus: 16.93 °C (float: 16.930000)
2017-02-01 23:06:23.804 Z-Wave received "Sensor - Temperatuur Schuifdeur Woonkamer" sensor update to 16.93 °C
2017-02-01 23:06:23.805 Trigger Temperatuur in variabele zetten copy
2017-02-01 23:06:31.178 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 0F 07 60 0D 02 02 25 03 FF 4A
2017-02-01 23:06:31.179 Z-Wave Debug . . multiEndPointPacket: node 015, endPoint 2
2017-02-01 23:06:31.181 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 0F 03 25 03 FF FF
2017-02-01 23:06:31.182 Z-Wave Debug . . requestRelayStatus: node 015, endpoint 2, value 255
2017-02-01 23:06:31.183 Z-Wave received "PIR - Keuken" status update is on
2017-02-01 23:06:31.184 Trigger Keuken Lamp Aan
2017-02-01 23:06:31.204 Z-Wave Debug SENT setRelayValue: 01 0E 00 13 10 07 60 0D 01 01 25 01 FF 25 FC 9A
2017-02-01 23:06:31.410 Z-Wave sent "Lamp - Plafond Keuken" on
2017-02-01 23:06:35.280 OWServer Getting OWServer data...
2017-02-01 23:06:35.800 OWServer Total of 1 servers polled.
2017-02-01 23:06:35.801 OWServer Total of 4 devices updated.
2017-02-01 23:06:35.802 OWServer OWServer data parsed successfully.
2017-02-01 23:06:35.828 Trigger windKracht in variabele zetten
2017-02-01 23:06:35.836 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:06:41.706 Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 4C 02 84 07 3E
2017-02-01 23:06:41.708 Z-Wave Debug . . nodeAwake: node 076
2017-02-01 23:06:41.709 Z-Wave Debug . . . . . . . : skipping battery check (next check in 539 mins)
2017-02-01 23:06:41.710 Z-Wave Debug SENT goToSleep: 01 09 00 13 4C 02 84 08 24 FD FE
2017-02-01 23:06:41.724 Z-Wave Debug RCVD packet: 01 05 00 13 FD 00 14 (hex)
2017-02-01 23:07:07.643 LIFX Bridge Debug lifxRespond, processing message seq_num = 209
2017-02-01 23:07:07.803 LIFX Bridge Debug lifxRespond, processing message seq_num = 210
2017-02-01 23:07:07.921 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:08.034 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:08.145 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:08.253 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:08.361 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:08.471 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:08.579 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:08.691 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:08.802 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:08.909 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:09.018 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:09.130 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:09.239 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:09.343 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:09.451 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:09.561 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:09.670 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 209
2017-02-01 23:07:09.783 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 210
2017-02-01 23:07:10.201 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:07:10.204 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:07:10.222 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:07:10.224 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:08:00.722 Schedule Daikin Standen Ophalen
2017-02-01 23:08:00.723 Action Group Daikin Standen Woonkamer
2017-02-01 23:08:00.724 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:08:05.720 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:08:05.722 Action Group Daikin Standen TN
2017-02-01 23:08:09.513 LIFX Bridge Debug lifxRespond, processing message seq_num = 211
2017-02-01 23:08:09.667 LIFX Bridge Debug lifxRespond, processing message seq_num = 212
2017-02-01 23:08:09.782 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:09.892 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:10.001 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:10.112 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:10.219 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:10.330 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:10.440 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:10.543 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:10.653 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:10.719 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:08:10.720 Action Group Daikin Standen Nick
2017-02-01 23:08:10.763 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:10.876 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:10.985 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:11.092 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:11.199 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:11.308 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:11.419 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:11.530 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 211
2017-02-01 23:08:11.641 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 212
2017-02-01 23:08:12.102 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:08:12.103 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:08:12.124 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:08:12.125 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:08:15.720 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:08:15.722 Action Group Daikin Standen Jesper
2017-02-01 23:08:25.897 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 6A FC
2017-02-01 23:08:25.899 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:08:25.900 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 6A FF
2017-02-01 23:08:25.900 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:08:25.901 Z-Wave Debug . . requestVarSensorStatus: 6.18 °C (float: 6.180000)
2017-02-01 23:08:25.902 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.18 °C
2017-02-01 23:08:26.035 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 6A FC
2017-02-01 23:08:26.037 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:08:26.037 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 6A FF
2017-02-01 23:08:26.038 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:08:26.039 Z-Wave Debug . . requestVarSensorStatus: 6.18 °C (float: 6.180000)
2017-02-01 23:08:26.040 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.18 °C
2017-02-01 23:08:26.073 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 6A FC
2017-02-01 23:08:26.074 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:08:26.076 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 6A FF
2017-02-01 23:08:26.076 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:08:26.077 Z-Wave Debug . . requestVarSensorStatus: 6.18 °C (float: 6.180000)
2017-02-01 23:08:26.078 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.18 °C
2017-02-01 23:08:26.204 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 6A FC
2017-02-01 23:08:26.206 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:08:26.207 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 6A FF
2017-02-01 23:08:26.208 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:08:26.209 Z-Wave Debug . . requestVarSensorStatus: 6.18 °C (float: 6.180000)
2017-02-01 23:08:26.209 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.18 °C
2017-02-01 23:08:26.402 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 6A FC
2017-02-01 23:08:26.404 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:08:26.405 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 6A FF
2017-02-01 23:08:26.406 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:08:26.407 Z-Wave Debug . . requestVarSensorStatus: 6.18 °C (float: 6.180000)
2017-02-01 23:08:26.407 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.18 °C
2017-02-01 23:08:28.823 Z-Wave Debug polling status of node "017 - Gordijn - Keuken"
2017-02-01 23:08:28.867 Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 11 02 26 02 25 FE 09
2017-02-01 23:08:29.147 Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 11 03 20 03 00 C3
2017-02-01 23:08:29.148 Z-Wave Debug . . dimmerSetLevel: node 017, endpoint None, value 0
2017-02-01 23:08:31.382 LIFX Bridge Debug lifxRespond, processing message seq_num = 213
2017-02-01 23:08:31.540 LIFX Bridge Debug lifxRespond, processing message seq_num = 214
2017-02-01 23:08:31.659 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:31.770 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:31.839 Z-Wave Debug polling status of node "018 - Gordijn - Woonkamer" (defer list)
2017-02-01 23:08:31.862 Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 12 02 26 02 25 FF 0B
2017-02-01 23:08:31.881 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:31.993 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:32.104 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:32.145 Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 12 03 20 03 00 C0
2017-02-01 23:08:32.146 Z-Wave Debug . . dimmerSetLevel: node 018, endpoint None, value 0
2017-02-01 23:08:32.212 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:32.320 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:32.430 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:32.541 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:32.645 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:32.748 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:32.843 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 15 06 31 05 04 22 05 93 60
2017-02-01 23:08:32.845 Z-Wave Debug . . requestVarSensorStatus: node 021, endpoint None, type 4, raw value 2205...
2017-02-01 23:08:32.845 Z-Wave Debug . . requestVarSensorStatus: 142.7 W (float: 142.700000)
2017-02-01 23:08:32.846 Z-Wave Debug received "TV Woonkamer" power load to 142.7 W
2017-02-01 23:08:32.859 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:32.965 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:33.075 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:33.182 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:33.292 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:33.401 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 213
2017-02-01 23:08:33.513 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 214
2017-02-01 23:08:33.982 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:08:33.984 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:08:34.014 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:08:34.015 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:08:35.822 OWServer Getting OWServer data...
2017-02-01 23:08:36.344 OWServer Total of 1 servers polled.
2017-02-01 23:08:36.345 OWServer Total of 4 devices updated.
2017-02-01 23:08:36.347 OWServer OWServer data parsed successfully.
2017-02-01 23:08:36.381 Trigger windKracht in variabele zetten
2017-02-01 23:08:36.390 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:09:06.437 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 31 06 31 05 04 22 00 05 D7
2017-02-01 23:09:06.471 Z-Wave Debug . . requestVarSensorStatus: node 049, endpoint None, type 4, raw value 2200...
2017-02-01 23:09:06.471 Z-Wave Debug . . requestVarSensorStatus: 0.5 W (float: 0.500000)
2017-02-01 23:10:00.720 Schedule setWeatherUpdateVariable
2017-02-01 23:10:00.723 Schedule Daikin Standen Ophalen
2017-02-01 23:10:00.724 Action Group Daikin Standen Woonkamer
2017-02-01 23:10:00.725 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:10:00.728 Schedule setHomewizard Temperatuur
2017-02-01 23:10:00.729 Action Group HomewizardTemperatuur
2017-02-01 23:10:00.943 Action Group Verwarming - Woonkamer Uit
2017-02-01 23:10:00.947 Virtual Devices sent "Verwarming Woonkamer " off
2017-02-01 23:10:05.717 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:10:05.718 Action Group Daikin Standen TN
2017-02-01 23:10:10.719 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:10:10.720 Action Group Daikin Standen Nick
2017-02-01 23:10:15.718 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:10:15.721 Action Group Daikin Standen Jesper
2017-02-01 23:10:33.437 LIFX Bridge Debug lifxRespond, processing message seq_num = 215
2017-02-01 23:10:33.630 LIFX Bridge Debug lifxRespond, processing message seq_num = 216
2017-02-01 23:10:33.749 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:33.857 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:33.968 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:34.080 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:34.189 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:34.299 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:34.412 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:34.523 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:34.629 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:34.739 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:34.843 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:34.951 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:35.055 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:35.163 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:35.271 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:35.378 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:35.490 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 215
2017-02-01 23:10:35.600 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 216
2017-02-01 23:10:36.041 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:10:36.042 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:10:36.061 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:10:36.063 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:10:36.392 OWServer Getting OWServer data...
2017-02-01 23:10:36.937 OWServer Total of 1 servers polled.
2017-02-01 23:10:36.938 OWServer Total of 4 devices updated.
2017-02-01 23:10:36.939 OWServer OWServer data parsed successfully.
2017-02-01 23:10:36.966 Trigger windKracht in variabele zetten
2017-02-01 23:10:36.976 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:10:49.681 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 6F 07 60 0D 01 01 20 01 00 D2
2017-02-01 23:10:49.682 Z-Wave Debug . . multiEndPointPacket: node 111, endPoint 1
2017-02-01 23:10:49.683 Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 6F 03 20 01 00 FF
2017-02-01 23:10:49.684 Z-Wave Debug . . sensorSetLevel: node 111, endpoint 1, cmdClass 20, value 0
2017-02-01 23:10:49.685 Z-Wave received "Sensor - Regen" status update is off
2017-02-01 23:11:03.176 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 14 0A 32 02 21 44 00 00 37 BF 00 00 28
2017-02-01 23:11:03.178 Z-Wave Debug . . requestMeterLevel: node 020, endpoint None, meterType 01, raw value 4400...
2017-02-01 23:11:03.179 Z-Wave Debug . . requestMeterLevel: 142.71 kWh (float: 142.710000)
2017-02-01 23:11:03.180 Z-Wave received "Wall Plug - HIFI " energy total to 142.71 kWh
2017-02-01 23:11:04.011 LIFX Bridge Debug lifxRespond, processing message seq_num = 217
2017-02-01 23:11:04.166 LIFX Bridge Debug lifxRespond, processing message seq_num = 218
2017-02-01 23:11:04.287 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:04.400 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:04.507 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:04.616 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:04.726 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:04.837 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:04.942 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:05.045 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:05.148 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:05.255 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:05.365 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:05.470 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:05.574 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:05.682 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:05.791 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:05.904 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:06.014 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 217
2017-02-01 23:11:06.122 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 218
2017-02-01 23:11:06.618 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:11:06.619 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:11:06.639 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:11:06.640 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:11:29.635 ZEAL Debug runConcurrentThread
2017-02-01 23:11:29.653 ZEAL Debug Mapping Z-wave nodes to indigo devices
2017-02-01 23:11:29.986 ZEAL Finished mapping 61 z-wave nodes to indigo devices.
2017-02-01 23:11:29.988 ZEAL Debug Periodically saving z-wave node statistics
2017-02-01 23:11:29.989 ZEAL Debug Checking status of other plugins this plugin depends on
2017-02-01 23:11:29.991 ZEAL Debug Checking plugin "Better E-mail"
2017-02-01 23:11:30.003 ZEAL Debug Plugin "Better E-mail" successfully checked
2017-02-01 23:11:30.005 ZEAL Debug Checking if there are triggers for outgoing z-wave commands: Found
2017-02-01 23:11:44.482 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 0F 07 60 0D 02 02 25 03 00 B5
2017-02-01 23:11:44.484 Z-Wave Debug . . multiEndPointPacket: node 015, endPoint 2
2017-02-01 23:11:44.485 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 0F 03 25 03 00 FF
2017-02-01 23:11:44.486 Z-Wave Debug . . requestRelayStatus: node 015, endpoint 2, value 0
2017-02-01 23:11:44.487 Z-Wave received "PIR - Keuken" status update is off
2017-02-01 23:11:44.488 Trigger Keuken Lamp Uit
2017-02-01 23:11:44.498 Z-Wave Debug SENT setRelayValue: 01 0E 00 13 10 07 60 0D 01 01 25 01 00 25 01 98
2017-02-01 23:11:44.521 Z-Wave sent "Lamp - Plafond Keuken" off
2017-02-01 23:11:55.920 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 6A FC
2017-02-01 23:11:55.922 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:11:55.923 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 6A FF
2017-02-01 23:11:55.924 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:11:55.925 Z-Wave Debug . . requestVarSensorStatus: 6.18 °C (float: 6.180000)
2017-02-01 23:11:55.926 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.18 °C
2017-02-01 23:12:00.715 Schedule Daikin Standen Ophalen
2017-02-01 23:12:00.716 Action Group Daikin Standen Woonkamer
2017-02-01 23:12:00.717 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:12:05.716 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:12:05.718 Action Group Daikin Standen TN
2017-02-01 23:12:10.715 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:12:10.717 Action Group Daikin Standen Nick
2017-02-01 23:12:15.715 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:12:15.717 Action Group Daikin Standen Jesper
2017-02-01 23:12:36.974 OWServer Getting OWServer data...
2017-02-01 23:12:37.152 Trigger Lux in variabele zetten
2017-02-01 23:12:37.554 OWServer Total of 1 servers polled.
2017-02-01 23:12:37.555 OWServer Total of 4 devices updated.
2017-02-01 23:12:37.556 OWServer OWServer data parsed successfully.
2017-02-01 23:12:37.610 Trigger windKracht in variabele zetten
2017-02-01 23:12:37.622 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:12:41.406 LIFX Bridge Debug lifxRespond, processing message seq_num = 219
2017-02-01 23:12:41.565 LIFX Bridge Debug lifxRespond, processing message seq_num = 220
2017-02-01 23:12:41.681 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:41.789 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:41.897 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:42.007 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:42.119 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:42.228 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:42.337 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:42.447 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:42.559 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:42.669 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:42.772 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:42.879 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:42.988 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:43.091 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:43.204 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:43.312 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:43.421 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 219
2017-02-01 23:12:43.532 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 220
2017-02-01 23:12:44.012 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:12:44.014 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:12:44.038 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:12:44.039 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:14:00.714 Schedule Daikin Standen Ophalen
2017-02-01 23:14:00.715 Action Group Daikin Standen Woonkamer
2017-02-01 23:14:00.716 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:14:05.714 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:14:05.716 Action Group Daikin Standen TN
2017-02-01 23:14:10.713 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:14:10.714 Action Group Daikin Standen Nick
2017-02-01 23:14:15.713 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:14:15.714 Action Group Daikin Standen Jesper
2017-02-01 23:14:37.573 OWServer Getting OWServer data...
2017-02-01 23:14:38.073 OWServer Total of 1 servers polled.
2017-02-01 23:14:38.074 OWServer Total of 4 devices updated.
2017-02-01 23:14:38.075 OWServer OWServer data parsed successfully.
2017-02-01 23:14:38.104 Trigger windKracht in variabele zetten
2017-02-01 23:14:38.119 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:14:53.503 LIFX Bridge Debug lifxRespond, processing message seq_num = 221
2017-02-01 23:14:53.668 LIFX Bridge Debug lifxRespond, processing message seq_num = 222
2017-02-01 23:14:53.785 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:53.893 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:54.003 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:54.118 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:54.227 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:54.338 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:54.451 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:54.560 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:54.670 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:54.777 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:54.886 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:54.994 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:55.102 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:55.215 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:55.327 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:55.435 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:55.542 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 221
2017-02-01 23:14:55.650 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 222
2017-02-01 23:14:56.104 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:14:56.105 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:14:56.132 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:14:56.133 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:15:00.715 Schedule Set_HouseMode_Sleeping
2017-02-01 23:15:00.718 Trigger setLampOverloopBrightness Nacht
2017-02-01 23:15:00.719 Trigger Prescence Light Sleeping
2017-02-01 23:15:00.721 Schedule setHomewizard Temperatuur
2017-02-01 23:15:00.722 Action Group HomewizardTemperatuur
2017-02-01 23:15:00.749 Z-Wave Debug SENT setConfigVal: 01 0C 00 13 4E 05 70 04 28 01 19 25 02 C8
2017-02-01 23:15:01.255 Z-Wave device "Lamp - Overloop" parameter 40 changed to 25
2017-02-01 23:15:01.257 Z-Wave Debug SENT setMultiLevelValue: 01 0E 00 13 5C 07 60 0D 01 04 26 01 00 25 03 D0
2017-02-01 23:15:01.393 Z-Wave sent "Led - Gang Vakantie" set brightness to 0
2017-02-01 23:15:01.395 Z-Wave Debug queueing energy request of "092 - Led - Gang Composite" (activity detected)
2017-02-01 23:15:01.398 Z-Wave Debug SENT setMultiLevelValue: 01 0E 00 13 5C 07 60 0D 01 03 26 01 00 25 04 D0
2017-02-01 23:15:01.425 Z-Wave sent "Led - Gang Home" set brightness to 0
2017-02-01 23:15:01.427 Z-Wave Debug ignoring duplicate energy request of "092 - Led - Gang Composite" (activity detected)
2017-02-01 23:15:01.433 Z-Wave Debug SENT setMultiLevelValue: 01 0E 00 13 5C 07 60 0D 01 02 26 01 0F 25 05 DF
2017-02-01 23:15:01.462 Z-Wave sent "Led - Gang Alarm Aan" set brightness to 15
2017-02-01 23:15:01.464 Z-Wave Debug ignoring duplicate energy request of "092 - Led - Gang Composite" (activity detected)
2017-02-01 23:15:01.470 Z-Wave Debug SENT setRelayValue: 01 0E 00 13 63 07 60 0D 01 02 25 01 FF 25 06 10
2017-02-01 23:15:01.559 Z-Wave sent "Led - Voordeur Alarm Aan" on
2017-02-01 23:15:01.923 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 5C 07 60 0D 02 02 26 03 0F EA
2017-02-01 23:15:01.924 Z-Wave Debug . . multiEndPointPacket: node 092, endPoint 2
2017-02-01 23:15:01.925 Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 5C 03 26 03 0F FF
2017-02-01 23:15:01.926 Z-Wave Debug . . requestDimmerStatus: node 092, endpoint 2, value 15
2017-02-01 23:15:01.927 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 5C 07 60 0D 03 03 26 03 00 E5
2017-02-01 23:15:01.928 Z-Wave Debug . . multiEndPointPacket: node 092, endPoint 3
2017-02-01 23:15:01.928 Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 5C 03 26 03 00 FF
2017-02-01 23:15:01.929 Z-Wave Debug . . requestDimmerStatus: node 092, endpoint 3, value 0
2017-02-01 23:15:05.248 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 64 F2
2017-02-01 23:15:05.249 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:15:05.250 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 64 FF
2017-02-01 23:15:05.251 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:15:05.252 Z-Wave Debug . . requestVarSensorStatus: 6.12 °C (float: 6.120000)
2017-02-01 23:15:05.252 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.12 °C
2017-02-01 23:15:08.234 Z-Wave Debug polling status of node "092 - Led - Gang Composite" (post-activity energy request)
2017-02-01 23:15:08.273 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 5C 03 32 01 00 25 07 A8
2017-02-01 23:15:08.555 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 5C 0A 32 02 21 44 00 00 01 31 00 00 D8
2017-02-01 23:15:08.557 Z-Wave Debug . . requestMeterLevel: node 092, endpoint None, meterType 01, raw value 4400...
2017-02-01 23:15:08.558 Z-Wave Debug . . requestMeterLevel: 3.05 kWh (float: 3.050000)
2017-02-01 23:15:08.559 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 5C 03 32 01 10 25 08 B7
2017-02-01 23:15:08.839 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 5C 0A 32 02 21 32 00 00 00 00 00 00 9E
2017-02-01 23:15:08.840 Z-Wave Debug . . requestMeterLevel: node 092, endpoint None, meterType 01, raw value 3200...
2017-02-01 23:15:08.841 Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
2017-02-01 23:15:43.561 LIFX Bridge Debug lifxRespond, processing message seq_num = 223
2017-02-01 23:15:43.758 LIFX Bridge Debug lifxRespond, processing message seq_num = 224
2017-02-01 23:15:43.876 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:43.986 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:44.093 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:44.201 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:44.310 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:44.417 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:44.527 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:44.637 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:44.743 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:44.850 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:44.957 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:45.066 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:45.176 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:45.284 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:45.392 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:45.503 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:45.611 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 223
2017-02-01 23:15:45.721 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 224
2017-02-01 23:15:46.157 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:15:46.181 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:15:46.189 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:15:46.191 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:16:00.713 Schedule Daikin Standen Ophalen
2017-02-01 23:16:00.714 Action Group Daikin Standen Woonkamer
2017-02-01 23:16:00.715 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:16:05.712 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:16:05.713 Action Group Daikin Standen TN
2017-02-01 23:16:10.712 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:16:10.713 Action Group Daikin Standen Nick
2017-02-01 23:16:11.782 LIFX Bridge Debug lifxRespond, processing message seq_num = 225
2017-02-01 23:16:11.951 LIFX Bridge Debug lifxRespond, processing message seq_num = 226
2017-02-01 23:16:12.065 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:12.176 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:12.283 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:12.394 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:12.501 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:12.613 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:12.724 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:12.835 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:12.947 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:13.058 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:13.170 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:13.280 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:13.389 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:13.500 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:13.609 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:13.718 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:13.828 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 225
2017-02-01 23:16:13.936 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 226
2017-02-01 23:16:14.381 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:16:14.383 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:16:14.403 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:16:14.404 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:16:15.712 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:16:15.714 Action Group Daikin Standen Jesper
2017-02-01 23:16:26.348 LIFX Bridge Debug lifxRespond, processing message seq_num = 227
2017-02-01 23:16:26.503 LIFX Bridge Debug lifxRespond, processing message seq_num = 228
2017-02-01 23:16:26.623 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:26.734 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:26.838 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:26.946 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:27.057 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:27.165 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:27.275 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:27.384 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:27.493 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:27.603 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:27.717 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:27.827 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:27.938 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:28.048 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:28.158 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:28.268 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:28.378 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 227
2017-02-01 23:16:28.487 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 228
2017-02-01 23:16:28.951 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:16:28.952 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:16:28.984 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:16:28.985 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:16:38.454 OWServer Getting OWServer data...
2017-02-01 23:16:38.922 OWServer Total of 1 servers polled.
2017-02-01 23:16:38.923 OWServer Total of 4 devices updated.
2017-02-01 23:16:38.924 OWServer OWServer data parsed successfully.
2017-02-01 23:16:38.967 Trigger windKracht in variabele zetten
2017-02-01 23:16:38.981 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:16:58.224 LIFX Bridge Debug lifxRespond, processing message seq_num = 229
2017-02-01 23:16:58.383 LIFX Bridge Debug lifxRespond, processing message seq_num = 230
2017-02-01 23:16:58.498 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:58.605 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:16:58.718 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:58.824 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:16:58.934 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:59.046 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:16:59.156 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:59.265 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:16:59.375 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:59.482 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:16:59.592 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:59.701 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:16:59.807 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:16:59.917 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:17:00.028 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:17:00.137 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:17:00.245 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 229
2017-02-01 23:17:00.355 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 230
2017-02-01 23:17:00.829 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:17:00.830 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:17:00.851 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:17:00.852 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:17:52.761 LIFX Bridge Debug lifxRespond, processing message seq_num = 231
2017-02-01 23:17:52.916 LIFX Bridge Debug lifxRespond, processing message seq_num = 232
2017-02-01 23:17:53.036 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:53.146 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:53.255 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:53.361 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:53.472 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:53.582 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:53.690 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:53.796 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:53.904 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:54.016 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:54.129 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:54.241 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:54.351 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:54.463 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:54.573 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:54.682 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:54.791 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 231
2017-02-01 23:17:54.898 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 232
2017-02-01 23:17:55.350 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:17:55.352 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:17:55.373 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:17:55.374 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:18:00.710 Schedule Daikin Standen Ophalen
2017-02-01 23:18:00.711 Action Group Daikin Standen Woonkamer
2017-02-01 23:18:00.712 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:18:05.709 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:18:05.710 Action Group Daikin Standen TN
2017-02-01 23:18:10.709 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:18:10.710 Action Group Daikin Standen Nick
2017-02-01 23:18:15.708 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:18:15.710 Action Group Daikin Standen Jesper
2017-02-01 23:18:34.946 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:18:35.265 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:18:35.266 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:18:35.267 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:18:35.268 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:18:35.269 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:18:38.947 OWServer Getting OWServer data...
2017-02-01 23:18:39.505 OWServer Total of 1 servers polled.
2017-02-01 23:18:39.506 OWServer Total of 4 devices updated.
2017-02-01 23:18:39.507 OWServer OWServer data parsed successfully.
2017-02-01 23:18:39.544 Trigger windKracht in variabele zetten
2017-02-01 23:18:39.557 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:20:00.708 Schedule setWeatherUpdateVariable
2017-02-01 23:20:00.711 Schedule Daikin Standen Ophalen
2017-02-01 23:20:00.712 Action Group Daikin Standen Woonkamer
2017-02-01 23:20:00.713 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:20:00.717 Schedule setHomewizard Temperatuur
2017-02-01 23:20:00.718 Action Group HomewizardTemperatuur
2017-02-01 23:20:00.952 Action Group Verwarming - Woonkamer Uit
2017-02-01 23:20:00.959 Virtual Devices sent "Verwarming Woonkamer " off
2017-02-01 23:20:04.934 LIFX Bridge Debug lifxRespond, processing message seq_num = 233
2017-02-01 23:20:05.087 LIFX Bridge Debug lifxRespond, processing message seq_num = 234
2017-02-01 23:20:05.203 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:05.314 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:05.425 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:05.530 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:05.640 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:05.707 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:20:05.708 Action Group Daikin Standen TN
2017-02-01 23:20:05.745 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:05.854 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:05.966 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:06.078 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:06.190 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:06.295 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:06.401 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:06.515 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:06.624 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:06.732 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:06.843 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:06.953 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 233
2017-02-01 23:20:07.062 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 234
2017-02-01 23:20:07.530 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:20:07.531 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:20:07.549 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:20:07.551 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:20:10.707 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:20:10.709 Action Group Daikin Standen Nick
2017-02-01 23:20:15.706 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:20:15.707 Action Group Daikin Standen Jesper
2017-02-01 23:20:36.432 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 31 0A 32 02 21 44 00 00 25 4A 00 00 EA
2017-02-01 23:20:36.433 Z-Wave Debug . . requestMeterLevel: node 049, endpoint None, meterType 01, raw value 4400...
2017-02-01 23:20:36.434 Z-Wave Debug . . requestMeterLevel: 95.46 kWh (float: 95.460000)
2017-02-01 23:20:36.435 Z-Wave Debug received "Wall Plug - Boiler" energy total to 95.46 kWh
2017-02-01 23:20:39.532 OWServer Getting OWServer data...
2017-02-01 23:20:40.063 OWServer Total of 1 servers polled.
2017-02-01 23:20:40.064 OWServer Total of 4 devices updated.
2017-02-01 23:20:40.065 OWServer OWServer data parsed successfully.
2017-02-01 23:20:40.080 Trigger windKracht in variabele zetten
2017-02-01 23:20:40.088 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:21:44.183 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:21:44.184 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:21:44.185 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:21:44.186 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:21:44.187 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:21:44.187 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:21:48.189 LIFX Bridge Debug lifxRespond, processing message seq_num = 235
2017-02-01 23:21:48.378 LIFX Bridge Debug lifxRespond, processing message seq_num = 236
2017-02-01 23:21:48.495 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:48.605 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:48.711 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:48.819 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:48.930 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:49.040 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:49.145 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:49.253 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:49.363 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:49.470 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:49.578 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:49.686 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:49.795 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:49.903 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:50.015 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:50.124 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:50.230 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 235
2017-02-01 23:21:50.336 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 236
2017-02-01 23:21:50.786 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:21:50.787 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:21:50.808 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:21:50.809 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:21:59.773 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 54 03 25 03 00 83
2017-02-01 23:21:59.775 Z-Wave Debug . . requestRelayStatus: node 084, endpoint None, value 0
2017-02-01 23:21:59.776 Z-Wave received "PIR - Woonkamer" status update is off
2017-02-01 23:22:00.705 Schedule Daikin Standen Ophalen
2017-02-01 23:22:00.706 Action Group Daikin Standen Woonkamer
2017-02-01 23:22:00.707 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:22:05.705 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:22:05.706 Action Group Daikin Standen TN
2017-02-01 23:22:05.741 LIFX Bridge Debug lifxRespond, processing message seq_num = 237
2017-02-01 23:22:05.910 LIFX Bridge Debug lifxRespond, processing message seq_num = 238
2017-02-01 23:22:06.029 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:06.139 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:06.251 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:06.360 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:06.470 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:06.581 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:06.687 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:06.792 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:06.902 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:07.009 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:07.117 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:07.223 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:07.333 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:07.445 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:07.557 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:07.661 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:07.770 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 237
2017-02-01 23:22:07.878 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 238
2017-02-01 23:22:08.343 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:22:08.344 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:22:08.362 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:22:08.364 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:22:10.707 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:22:10.709 Action Group Daikin Standen Nick
2017-02-01 23:22:15.705 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:22:15.706 Action Group Daikin Standen Jesper
2017-02-01 23:22:40.089 OWServer Getting OWServer data...
2017-02-01 23:22:40.647 OWServer Total of 1 servers polled.
2017-02-01 23:22:40.648 OWServer Total of 4 devices updated.
2017-02-01 23:22:40.649 OWServer OWServer data parsed successfully.
2017-02-01 23:22:40.681 Trigger windKracht in variabele zetten
2017-02-01 23:22:40.692 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:22:47.446 Netatmo Plugin Error Plugin stopping. Reason = ('The read operation timed out',)
2017-02-01 23:22:47.448 Netatmo Plugin Stopping Netatmo device read loop
2017-02-01 23:22:47.449 Netatmo Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-02-01 23:22:50.544 LIFX Bridge Debug lifxRespond, processing message seq_num = 239
2017-02-01 23:22:50.702 LIFX Bridge Debug lifxRespond, processing message seq_num = 240
2017-02-01 23:22:50.821 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:50.931 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:51.038 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:51.144 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:51.255 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:51.365 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:51.477 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:51.585 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:51.694 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:51.802 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:51.909 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:52.019 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:52.131 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:52.242 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:52.352 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:52.462 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:52.571 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 239
2017-02-01 23:22:52.676 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 240
2017-02-01 23:22:53.157 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:22:53.159 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:22:53.177 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:22:53.178 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:22:58.058 Trigger Sonair - Woonkamer Openhaard uit lager dan 1000
2017-02-01 23:22:58.118 Z-Wave Debug SENT setRelayValue: 01 0E 00 13 52 07 60 0D 01 01 25 01 FF 25 09 2D
2017-02-01 23:22:58.314 Z-Wave sent "Ventilatie Woonkamer Openhaard Uit" on
2017-02-01 23:22:59.317 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 52 03 25 03 00 85
2017-02-01 23:22:59.318 Z-Wave Debug . . requestRelayStatus: node 082, endpoint None, value 0
2017-02-01 23:22:59.319 Z-Wave received "Ventilatie Woonkamer Openhaard Uit" status update is off
2017-02-01 23:23:01.706 Schedule Sonair - Woonkamer Openhaard uit lager dan 1000 (delayed action)
2017-02-01 23:23:01.750 Z-Wave Debug SENT setRelayValue: 01 0E 00 13 52 07 60 0D 01 01 25 01 FF 25 0A 2E
2017-02-01 23:23:01.830 Z-Wave sent "Ventilatie Woonkamer Openhaard Uit" on
2017-02-01 23:23:02.814 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 52 03 25 03 00 85
2017-02-01 23:23:02.815 Z-Wave Debug . . requestRelayStatus: node 082, endpoint None, value 0
2017-02-01 23:23:02.816 Z-Wave received "Ventilatie Woonkamer Openhaard Uit" status update is off
2017-02-01 23:24:00.704 Schedule Daikin Standen Ophalen
2017-02-01 23:24:00.705 Action Group Daikin Standen Woonkamer
2017-02-01 23:24:00.705 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:24:05.703 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:24:05.704 Action Group Daikin Standen TN
2017-02-01 23:24:10.704 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:24:10.706 Action Group Daikin Standen Nick
2017-02-01 23:24:15.705 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:24:15.706 Action Group Daikin Standen Jesper
2017-02-01 23:24:40.673 OWServer Getting OWServer data...
2017-02-01 23:24:41.181 OWServer Total of 1 servers polled.
2017-02-01 23:24:41.182 OWServer Total of 4 devices updated.
2017-02-01 23:24:41.184 OWServer OWServer data parsed successfully.
2017-02-01 23:24:41.235 Trigger windKracht in variabele zetten
2017-02-01 23:24:41.253 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:24:44.260 LIFX Bridge Debug lifxRespond, processing message seq_num = 241
2017-02-01 23:24:44.414 LIFX Bridge Debug lifxRespond, processing message seq_num = 242
2017-02-01 23:24:44.532 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:44.643 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:44.754 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:44.864 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:44.975 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:45.085 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:45.191 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:45.302 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:45.409 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:45.519 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:45.625 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:45.730 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:45.843 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:45.956 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:46.067 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:46.175 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:46.285 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 241
2017-02-01 23:24:46.392 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 242
2017-02-01 23:24:46.864 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:24:46.866 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:24:46.883 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:24:46.884 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:25:00.703 Schedule setHomewizard Temperatuur
2017-02-01 23:25:00.718 Action Group HomewizardTemperatuur
2017-02-01 23:25:14.238 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:25:14.261 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:25:14.262 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:25:14.263 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:25:14.264 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:25:14.265 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:25:14.345 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:25:14.346 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:25:14.347 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:25:14.349 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:25:14.350 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:25:14.351 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:25:14.422 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:25:14.424 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:25:14.425 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:25:14.425 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:25:14.426 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:25:14.427 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:25:43.158 LIFX Bridge Debug lifxRespond, processing message seq_num = 243
2017-02-01 23:25:43.328 LIFX Bridge Debug lifxRespond, processing message seq_num = 244
2017-02-01 23:25:43.442 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:43.554 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:43.667 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:43.778 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:43.885 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:43.996 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:44.102 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:44.213 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:44.323 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:44.428 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:44.534 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:44.641 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:44.754 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:44.866 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:44.977 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:45.083 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:45.190 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 243
2017-02-01 23:25:45.301 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 244
2017-02-01 23:25:45.683 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:25:45.705 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:25:45.712 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:25:45.714 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:26:00.701 Schedule Daikin Standen Ophalen
2017-02-01 23:26:00.703 Action Group Daikin Standen Woonkamer
2017-02-01 23:26:00.703 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:26:01.489 Trigger Er is beweging in de voortuin
2017-02-01 23:26:05.701 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:26:05.702 Action Group Daikin Standen TN
2017-02-01 23:26:10.701 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:26:10.728 Action Group Daikin Standen Nick
2017-02-01 23:26:15.701 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:26:15.702 Action Group Daikin Standen Jesper
2017-02-01 23:26:36.967 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 69 07 60 0D 02 02 25 03 00 D3
2017-02-01 23:26:37.036 Z-Wave Debug . . multiEndPointPacket: node 105, endPoint 2
2017-02-01 23:26:37.039 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 69 03 25 03 00 FF
2017-02-01 23:26:37.042 Z-Wave Debug . . requestRelayStatus: node 105, endpoint 2, value 0
2017-02-01 23:26:37.043 Z-Wave received "PIR - Jesper Presence " status update is off
2017-02-01 23:26:37.044 Trigger set Presence Jesper OFF
2017-02-01 23:26:41.258 OWServer Getting OWServer data...
2017-02-01 23:26:41.754 OWServer Total of 1 servers polled.
2017-02-01 23:26:41.756 OWServer Total of 4 devices updated.
2017-02-01 23:26:41.756 OWServer OWServer data parsed successfully.
2017-02-01 23:26:41.822 Trigger windKracht in variabele zetten
2017-02-01 23:26:41.832 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:26:46.333 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 6F 07 60 0D 01 01 20 01 FF 2D
2017-02-01 23:26:46.335 Z-Wave Debug . . multiEndPointPacket: node 111, endPoint 1
2017-02-01 23:26:46.336 Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 6F 03 20 01 FF FF
2017-02-01 23:26:46.337 Z-Wave Debug . . sensorSetLevel: node 111, endpoint 1, cmdClass 20, value 255
2017-02-01 23:26:46.338 Z-Wave received "Sensor - Regen" status update is on
2017-02-01 23:27:01.800 LIFX Bridge Debug lifxRespond, processing message seq_num = 245
2017-02-01 23:27:02.021 LIFX Bridge Debug lifxRespond, processing message seq_num = 246
2017-02-01 23:27:02.142 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:02.254 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:02.359 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:02.468 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:02.576 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:02.684 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:02.791 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:02.899 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:03.010 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:03.116 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:03.222 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:03.325 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:03.432 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:03.541 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:03.646 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:03.752 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:03.857 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 245
2017-02-01 23:27:03.969 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 246
2017-02-01 23:27:04.404 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:27:04.426 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:27:04.436 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:27:04.437 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:28:00.700 Schedule Daikin Standen Ophalen
2017-02-01 23:28:00.717 Action Group Daikin Standen Woonkamer
2017-02-01 23:28:00.718 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:28:05.699 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:28:05.700 Action Group Daikin Standen TN
2017-02-01 23:28:05.754 LIFX Bridge Debug lifxRespond, processing message seq_num = 247
2017-02-01 23:28:05.921 LIFX Bridge Debug lifxRespond, processing message seq_num = 248
2017-02-01 23:28:06.037 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:06.141 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:06.253 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:06.362 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:06.470 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:06.580 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:06.688 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:06.793 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:06.900 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:07.007 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:07.111 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:07.224 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:07.334 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:07.440 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:07.553 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:07.658 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:07.765 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 247
2017-02-01 23:28:07.872 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 248
2017-02-01 23:28:08.353 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:28:08.355 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:28:08.374 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:28:08.375 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:28:10.701 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:28:10.703 Action Group Daikin Standen Nick
2017-02-01 23:28:15.701 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:28:15.702 Action Group Daikin Standen Jesper
2017-02-01 23:28:23.229 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:28:23.230 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:28:23.231 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:28:23.232 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:28:23.233 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:28:23.233 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:28:23.364 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:28:23.365 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:28:23.366 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:28:23.367 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:28:23.368 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:28:23.368 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:28:23.380 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 71 E7
2017-02-01 23:28:23.381 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:28:23.382 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 71 FF
2017-02-01 23:28:23.382 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:28:23.383 Z-Wave Debug . . requestVarSensorStatus: 6.25 °C (float: 6.250000)
2017-02-01 23:28:23.384 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.25 °C
2017-02-01 23:28:41.800 OWServer Getting OWServer data...
2017-02-01 23:28:41.957 Trigger Lux in variabele zetten
2017-02-01 23:28:42.316 Trigger windKracht in variabele zetten
2017-02-01 23:28:42.330 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:28:42.495 OWServer Total of 1 servers polled.
2017-02-01 23:28:42.498 OWServer Total of 4 devices updated.
2017-02-01 23:28:42.499 OWServer OWServer data parsed successfully.
2017-02-01 23:30:00.699 Schedule setWeatherUpdateVariable
2017-02-01 23:30:00.703 Schedule Daikin Standen Ophalen
2017-02-01 23:30:00.704 Action Group Daikin Standen Woonkamer
2017-02-01 23:30:00.705 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:30:00.708 Schedule setHomewizard Temperatuur
2017-02-01 23:30:00.709 Action Group HomewizardTemperatuur
2017-02-01 23:30:01.012 Action Group Verwarming - Woonkamer Uit
2017-02-01 23:30:01.019 Virtual Devices sent "Verwarming Woonkamer " off
2017-02-01 23:30:05.697 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:30:05.698 Action Group Daikin Standen TN
2017-02-01 23:30:07.470 LIFX Bridge Debug lifxRespond, processing message seq_num = 249
2017-02-01 23:30:07.620 LIFX Bridge Debug lifxRespond, processing message seq_num = 250
2017-02-01 23:30:07.735 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:07.844 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:07.958 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:08.064 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:08.175 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:08.283 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:08.393 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:08.504 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:08.614 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:08.720 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:08.832 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:08.944 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:09.051 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:09.164 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:09.276 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:09.385 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:09.488 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 249
2017-02-01 23:30:09.592 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 250
2017-02-01 23:30:10.074 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:30:10.075 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:30:10.093 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:30:10.095 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:30:10.699 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:30:10.700 Action Group Daikin Standen Nick
2017-02-01 23:30:15.697 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:30:15.699 Action Group Daikin Standen Jesper
2017-02-01 23:30:30.066 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 74 06 31 05 04 22 00 3F A8
2017-02-01 23:30:30.068 Z-Wave Debug . . requestVarSensorStatus: node 116, endpoint None, type 4, raw value 2200...
2017-02-01 23:30:30.069 Z-Wave Debug . . requestVarSensorStatus: 6.3 W (float: 6.300000)
2017-02-01 23:30:30.069 Z-Wave Debug received "Lamp - Tafel Keuken" power load to 6.3 W
2017-02-01 23:30:40.035 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 74 06 31 05 04 22 00 51 C6
2017-02-01 23:30:40.037 Z-Wave Debug . . requestVarSensorStatus: node 116, endpoint None, type 4, raw value 2200...
2017-02-01 23:30:40.038 Z-Wave Debug . . requestVarSensorStatus: 8.1 W (float: 8.100000)
2017-02-01 23:30:40.039 Z-Wave Debug received "Lamp - Tafel Keuken" power load to 8.1 W
2017-02-01 23:30:42.516 OWServer Getting OWServer data...
2017-02-01 23:30:43.097 OWServer Total of 1 servers polled.
2017-02-01 23:30:43.098 OWServer Total of 4 devices updated.
2017-02-01 23:30:43.099 OWServer OWServer data parsed successfully.
2017-02-01 23:30:43.132 Trigger windKracht in variabele zetten
2017-02-01 23:30:43.140 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:31:53.382 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 77 E1
2017-02-01 23:31:53.383 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:31:53.384 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 77 FF
2017-02-01 23:31:53.385 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:31:53.385 Z-Wave Debug . . requestVarSensorStatus: 6.31 °C (float: 6.310000)
2017-02-01 23:31:53.386 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.31 °C
2017-02-01 23:31:53.514 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 6D 0C 60 0D 03 03 31 05 01 44 00 00 02 77 E1
2017-02-01 23:31:53.515 Z-Wave Debug . . multiEndPointPacket: node 109, endPoint 3
2017-02-01 23:31:53.516 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 6D 08 31 05 01 44 00 00 02 77 FF
2017-02-01 23:31:53.517 Z-Wave Debug . . requestVarSensorStatus: node 109, endpoint 3, type 1, raw value 4400...
2017-02-01 23:31:53.517 Z-Wave Debug . . requestVarSensorStatus: 6.31 °C (float: 6.310000)
2017-02-01 23:31:53.518 Z-Wave received "Sensor - Temperatuur Buiten Schuur" sensor update to 6.31 °C
2017-02-01 23:32:00.696 Schedule Daikin Standen Ophalen
2017-02-01 23:32:00.697 Action Group Daikin Standen Woonkamer
2017-02-01 23:32:00.697 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:32:05.557 Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 4C 0C 60 0D 02 02 31 05 01 44 00 00 06 6B D8
2017-02-01 23:32:05.558 Z-Wave Debug . . multiEndPointPacket: node 076, endPoint 2
2017-02-01 23:32:05.559 Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 4C 08 31 05 01 44 00 00 06 6B FF
2017-02-01 23:32:05.560 Z-Wave Debug . . requestVarSensorStatus: node 076, endpoint 2, type 1, raw value 4400...
2017-02-01 23:32:05.561 Z-Wave Debug . . requestVarSensorStatus: 16.43 °C (float: 16.430000)
2017-02-01 23:32:05.561 Z-Wave received "Sensor - Temperatuur Schuifdeur Woonkamer" sensor update to 16.43 °C
2017-02-01 23:32:05.562 Trigger Temperatuur in variabele zetten copy
2017-02-01 23:32:05.695 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:32:05.696 Action Group Daikin Standen TN
2017-02-01 23:32:10.698 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:32:10.699 Action Group Daikin Standen Nick
2017-02-01 23:32:11.669 LIFX Bridge Debug lifxRespond, processing message seq_num = 251
2017-02-01 23:32:11.824 LIFX Bridge Debug lifxRespond, processing message seq_num = 252
2017-02-01 23:32:11.934 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:12.041 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:12.152 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:12.261 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:12.369 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:12.477 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:12.583 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:12.693 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:12.800 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:12.910 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:13.020 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:13.127 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:13.233 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:13.341 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:13.449 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:13.561 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:13.669 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 251
2017-02-01 23:32:13.781 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 252
2017-02-01 23:32:15.695 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:32:15.696 Action Group Daikin Standen Jesper
2017-02-01 23:32:43.119 OWServer Getting OWServer data...
2017-02-01 23:32:43.694 OWServer Total of 1 servers polled.
2017-02-01 23:32:43.696 OWServer Total of 4 devices updated.
2017-02-01 23:32:43.697 OWServer OWServer data parsed successfully.
2017-02-01 23:32:43.726 Trigger windKracht in variabele zetten
2017-02-01 23:32:43.736 Trigger windSnelheid in M/S variabele zetten
2017-02-01 23:32:59.263 Trigger Sonair - T&N aan boven 900
2017-02-01 23:32:59.328 Z-Wave Debug SENT setRelayValue: 01 0E 00 13 2C 07 60 0D 01 02 25 01 FF 25 0B 52
2017-02-01 23:32:59.519 Z-Wave sent "Ventilatie T&N Aan" on
2017-02-01 23:33:00.487 Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 2C 07 60 0D 02 02 25 03 00 96
2017-02-01 23:33:00.489 Z-Wave Debug . . multiEndPointPacket: node 044, endPoint 2
2017-02-01 23:33:00.490 Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 2C 03 25 03 00 FF
2017-02-01 23:33:00.491 Z-Wave Debug . . requestRelayStatus: node 044, endpoint 2, value 0
2017-02-01 23:33:00.492 Z-Wave received "Ventilatie T&N Aan" status update is off
2017-02-01 23:33:59.516 LIFX Bridge Debug lifxRespond, processing message seq_num = 253
2017-02-01 23:33:59.668 LIFX Bridge Debug lifxRespond, processing message seq_num = 254
2017-02-01 23:33:59.790 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:33:59.898 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:00.003 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:00.110 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:00.220 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:00.325 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:00.432 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:00.540 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:00.650 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:00.695 Schedule Daikin Standen Ophalen
2017-02-01 23:34:00.697 Action Group Daikin Standen Woonkamer
2017-02-01 23:34:00.697 Action Group Daikin Standen Woonkamer 2
2017-02-01 23:34:00.759 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:00.869 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:00.976 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:01.087 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:01.196 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:01.307 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:01.416 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:01.521 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 253
2017-02-01 23:34:01.633 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 254
2017-02-01 23:34:02.118 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:34:02.135 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:34:02.145 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:34:02.146 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:34:05.693 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:34:05.694 Action Group Daikin Standen TN
2017-02-01 23:34:10.695 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:34:10.696 Action Group Daikin Standen Nick
2017-02-01 23:34:15.695 Schedule Daikin Standen Ophalen (delayed action)
2017-02-01 23:34:15.697 Action Group Daikin Standen Jesper
2017-02-01 23:34:25.824 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 15 0A 32 02 21 44 00 00 20 76 00 00 F7
2017-02-01 23:34:26.153 Z-Wave Debug . . requestMeterLevel: node 021, endpoint None, meterType 01, raw value 4400...
2017-02-01 23:34:26.154 Z-Wave Debug . . requestMeterLevel: 83.10 kWh (float: 83.100000)
2017-02-01 23:34:26.156 Z-Wave Debug received "TV Woonkamer" energy total to 83.10 kWh
2017-02-01 23:34:30.940 LIFX Bridge Debug lifxRespond, processing message seq_num = 255
2017-02-01 23:34:31.099 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:31.210 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:31.319 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:31.428 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:31.540 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:31.653 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:31.756 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:31.860 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:31.968 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:32.079 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:32.185 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:32.290 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:32.399 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:32.507 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:32.615 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:32.721 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:32.830 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:32.941 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 255
2017-02-01 23:34:33.051 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 0
2017-02-01 23:34:33.539 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:34:33.540 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 0, brightness: 51, on: True
2017-02-01 23:34:33.570 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:34:33.571 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 0, brightness: 51, on: True
2017-02-01 23:34:41.437 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:41.548 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:41.657 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:41.770 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:41.882 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:41.988 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:42.097 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:42.204 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:42.315 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:42.418 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:42.526 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:42.630 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:42.738 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:42.849 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:42.958 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:43.071 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:43.185 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:43.291 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:43.400 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 1
2017-02-01 23:34:43.507 LIFX Bridge Debug lifxRespond, skipping message, duplicate or out of order seq_num = 2
2017-02-01 23:34:43.734 OWServer Getting OWServer data...
2017-02-01 23:34:44.142 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:34:44.143 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:17:193:172:138, status: 2, brightness: 51, on: True
2017-02-01 23:34:44.216 Trigger windKracht in variabele zetten
2017-02-01 23:34:44.231 Harmony Hub Debug Harmony Hub Woonkamer: messageHandler: Event automation notify, contents:
2017-02-01 23:34:44.232 Harmony Hub Debug Harmony Hub Woonkamer: Device: lifx-0:22:5:160:60:0, status: 2, brightness: 51, on: True
Wed Feb 01, 2017 5:02 pm
FlyingDiver online
Re: Lifx Bridge Devices not active
I would believe it stopped responding at 11:34pm. Looks like there's an issue with rollover on the sequence number. I need to skip duplicate sequence numbers to avoid processing the same command multiple times. But the sequence number rolls over faster than I expected.
I'll try to have an updated version to handle that this weekend.
Wed Feb 01, 2017 9:09 pm
FlyingDiver online
D'oh. I forgot I had already written the code to deal with this, I just hadn't tested it for release yet.
Try this version: https://github.com/FlyingDiver/Indigo-l ... v7.0.1.zip
It's a pre-release, so you can't use the built in updater.
