Error logging into MyQ server
Thu Aug 03, 2023 4:31 pm
hensed offline
At about 1:20pmPST I got this message:
   MyQ Warning                     Error logging into MyQ server: Error requesting data from https://partner-identity.myq-cloud.com/connect/token: 401 - Unauthorized
Since that time I have not been able to control the garage door thru Indigo plugin. The app works still, and my credentials are still working for MyQ.
Thu Aug 03, 2023 4:33 pm
hensed offline
Re: Error logging into MyQ server
...sometimes unable to control with Indigo Plugin. Sometimes it works and i don't see the error in the log.
Thu Aug 03, 2023 5:19 pm
That's MyQ messing with unauthorized clients again. There's no current open issues on the backend library, and no updates, so there's nothing I can do.
Thu Sep 28, 2023 10:20 pm
JustJack offline
I've started to see that error now. It was working just fine until today.
Sep 28, 2023 at 9:15:13 PM
Fri Sep 29, 2023 5:56 am
Yep, me too. Unfortunately, it's the cost of doing business with an unauthorized client.
Sat Sep 30, 2023 2:53 pm
JustJack offline
Fortunately it seems to clean itself up :D :D
Thu Oct 12, 2023 7:18 am
wideglidejrp offline
I am still getting the Error logging into MyQ server. This is giving me a security issue because I have an action group which closes my garage door every night. This no longer works as of a couple of weeks ago.
John R Patrick
Author of
Home Attitude
Thu Oct 12, 2023 7:25 am
MyQ does not have an official API. This plugin works using a reverse-engineered library which MyQ manages to break regularly. I'm monitoring the library development, and it looks like there's a fix coming soon (days, not weeks). Until then, there's nothing I can do about it.
If this is truly a security issue for you, you should install sensors on the door so you can send yourself an alert to manually close the door when needed.
Sat Oct 14, 2023 6:08 pm
If you're brave, you can use an unreleased patch to the MyQ library to address this issue. In Terminal on the Indigo server system, do:
pip3 uninstall pymyq
pip3 install git+https://github.com/arraylabs/pymyq.git@refs/pull/188/head
It seems to work on my system.
Sat Oct 14, 2023 6:17 pm
You will also need to update to plugin version 2022.0.4.
Sun Oct 15, 2023 12:39 pm
I got following...
Successfully installed pip-23.3
rivington24:~ jrpatric$ pip3 install git+https://github.com/arraylabs/pymyq. ... l/188/head
Collecting git+https://github.com/arraylabs/pymyq. ... l/188/head
Cloning https://github.com/arraylabs/pymyq.git (to revision refs/pull/188/head) to /private/var/folders/01/xlm443k95x1759h42x6z_mqm0000gn/T/pip-req-build-0k6xmdqk
error: subprocess-exited-with-error
× git version did not run successfully.
│ exit code: 1
╰─> [2 lines of output]
xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
John R Patrick
Author of
Home Attitude
Sun Oct 15, 2023 1:32 pm
You need the developer tools (Xcode) installed in order to build the library.
Sun Oct 15, 2023 3:34 pm
MyQ plugin now working to open/close garage door. Thanks for the assistance.
John R Patrick
Author of
Home Attitude
Mon Oct 16, 2023 11:49 am
yosappy offline
Sorry, I updated the Plugin to Version 2022.0.4 & I am still receiving the Error Message. Here's my Indigo Version 2023.1.0 Log:
"Starting plugin "MyQ 2022.0.4" (pid 11919)
Started plugin "MyQ 2022.0.4"
MyQ Starting MyQ
MyQ 1-Car Garage Door Opener LOCKED GREEN ON = CLOSED & UNLOCKED RED OFF = OPEN: Starting myqOpener Device 1501173758
MyQ Garage 3-Car Left Door Opener LOCKED GREEN ON = CLOSED & UNLOCKED RED OFF = OPEN: Starting myqOpener Device 761454836
MyQ Garage 3-Car Right Door Opener LOCKED GREEN ON = CLOSED & UNLOCKED RED OFF = OPEN: Starting myqOpener Device 852342143
MyQ Warning Error logging into MyQ server: Error requesting data from https://partner-identity.myq-cloud.com/connect/token: 401 - Unauthorized"
I did not do the Terminal Commands that were listed above as that looked like it caused additional Errors which I would not know how to fix myself. Please help. Note that MyQ still works fine on my iPhone; so, I know my Login is still working fine.
Yo
Mon Oct 16, 2023 11:51 am
2022.0.4 is not enough on it's own. You HAVE to do the terminal commands to get the correct version of the mypyq library.
