Initial install of MYQ plug-in
Fri May 12, 2023 12:13 am
sarahcat offline
I have tried several times since Indigo 7.2, to install the MYQ plug-in, but I never seemed to get it to work initially. Tonight, I updated Indigo Server to its latest release 2022.2.2, so I thought I would give the MYQ plug-in another go. Thanks for the work on this, BTW!
I did notice posts in the Forum about Chamberlain's cloud support problems, but I downloaded MYQ Plug-in 2020.0.3. I installed the 3..1.5 framework, which was successful, then I installed the new version of the plugin. I configured it with my working MYQ credentials, but I still get no apparent response from the opener (that I can see in Indigo).
MYQ works with Amazon Key Delivery and it works with the iOS app on iPhone, with the same credentials. I included a screen shot of the event log and of the client. Perhaps it's a Chamberlain cloud problem as well, but the event log does seem to indicate something I'm doing wrong.
Thanks again!
Event log after running
Screen Shot 2023-05-12 at 12.58.32 AM.jpeg (92.43 KiB) Viewed 931 times
Indigo client
Screen Shot 2023-05-12 at 1.00.02 AM.jpeg (87.46 KiB) Viewed 931 times
Fri May 12, 2023 5:14 am
Re: Initial install of MYQ plug-in
Turn on debug logging for the MyQ plugin, restart the plugin, then select the "Write MyQ Data to Log" menu command. Then attempt to open (or close) the door from Indigo.
Then post the text from the Indigo log. NOT a screen shot.
