rgspb wrote:I'm using version 7.5.3 with Indio 2021.1.1 and High Sierra and keep getting Invalid login in the setup. I've triple checked my login credentials and they are correct. What do I try next?
ryanbuckner wrote:rgspb wrote:I'm using version 7.5.3 with Indio 2021.1.1 and High Sierra and keep getting Invalid login in the setup. I've triple checked my login credentials and they are correct. What do I try next?
Make sure your client version and server versions are the same
rgspb wrote:Turn on debug logging and restart the plug-in.I'm using version 7.5.3 with Indio 2021.1.1 and High Sierra and keep getting Invalid login in the setup. I've triple checked my login credentials and they are correct. What do I try next?
Upgrading plugin MyQ to newer version 7.7.1 (previous version moved to trash)
Loading plugin "MyQ 7.7.1"
Starting plugin "MyQ 7.7.1" (pid 87273)
Started plugin "MyQ 7.7.1"
MyQ Starting MyQ
MyQ Error Error in plugin execution startup:
File "plugin.py", line 67, in startup
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 394, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1047, in _execute_child
OSError: [Errno 2] No such file or directory
MyQ Garage Door (CG08500FA764): Starting myqOpener Device 1847282094
MyQ Warning Unknown writing to subprocess: ''Plugin' object has no attribute 'pymyq''
