Release 7.4.3 - MyQ API Version 5 support
Sun Oct 27, 2019 10:28 am
The new release is in the plugin store: http://www.indigodomo.com/pluginstore/77/
MyQ has deprecated V4 of their API. If you're getting plugin failures, that's why. This new plugin release supports the new V5 API.
However:
You MUST be using the MyQ mobile app. If you're still using the Craftsman app (and probably others), your login for that app will not work. Create an account with the MyQ app, get your openers working with that app, then install and configure the plugin.
You MUST edit your opener devices (in Indigo client) and reselect the appropriate opener. The device IDs changed between the API versions, and the plugin can't fix that on it's own.
Otherwise, it should just work. :wink:
Sun Nov 03, 2019 1:35 pm
rgspb offline
Re: Release 7.4.3 - MyQ API Version 5 support
It's not working for me :( I keep gettin the following error:
File "plugin.py", line 79, in runConcurrentThread
File "plugin.py", line 379, in getDevices
File "plugin.py", line 351, in myqLogin
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 816, in json
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/__init__.py", line 307, in loads
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 335, in decode
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 353, in raw_decode
ValueError: No JSON object could be decoded
MyQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
MyQ Error Error in plugin execution runConcurrentThread:
I've only ever used the MyQ mobile app. It is current. Everything works using the MyQ app on my phone. I tried to edit my opener devices in Indigo but no openers show up to select!
Sun Nov 03, 2019 5:11 pm
Release 7.4.4 - MyQ API Version 5 support
I've pushed 7.4.4 to the store.
Sun Nov 03, 2019 8:31 pm
rgspb offline
Thanks, that fixed it right up!
