Does MyQ actually work?!
Wed Sep 04, 2019 7:36 pm
omnikey offline
I installed the lift master 8500W earlier this year, and MyQ works very well with the iOS app available.
I am on Indigo 7.3.1, and have the latest MyQ plugin installed. I consistently get an error that indicates a username or password error. Have disabled and re-enabled the plug-in to no avail.
Am I wasting my time here trying to get MyQ to work? My experience with these types of issues with H.A. is that they just never get solved, and you just need to move on.
Wed Sep 04, 2019 7:38 pm
Re: Does MyQ actually work?!
It works fine for many users. Please post the contents of the Indigo log when you restart the MyQ plugin.
Wed Sep 04, 2019 9:05 pm
Mine's working too.
Thu Sep 05, 2019 9:49 pm
omnikey offline
My log shows this:
myqLogin failure, RequestException: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:590)
Based on some research, this is occurring because my Python ssl or request libraries are not compatible with MyQ.
Seems to be a common issue, not just with MyQ.
Not sure its worth the trouble to correct, as the iOS MyQ app works quite well.
Fri Sep 06, 2019 1:55 am
omnikey wrote:
My log shows this:
You are correct. You need to be running High Sierra or later.
Sun Sep 08, 2019 11:13 pm
omnikey offline
You should consider mentioning the requirement for High Sierra or more recent release on the main page for this Plugin.
Indigo does NOT require High Sierra, and supports much older releases of Mac OSX.
Just a suggestion to help others.
Sat Oct 26, 2019 1:19 pm
Prose110 offline
MyQ no longer working after I updated to Catalina. Have tried reenabling the plugin without success. Any ideas of things to try? Thanks.
Sat Oct 26, 2019 1:20 pm
Read this thread: viewtopic.php?f=214&t=22765
