MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[XXXXXXXXXXXXXXXXX]</body></html>
If you have existing devices, they're still good (but nothing will work since the API is currently not responsive). If you're trying to create new devices, then the plugin uses the list it gets via the API. Which would be empty at this point.DaveL17 wrote:Every 10 minutes. When I go into the device settings, the MyQ Opener Device is blank and there are no devices to choose from. Presumably, those are picked up through the API and not cached.
Same thing. It can't give you a list of devices.DaveL17 wrote:Thanks Joe - that was editing an existing device. I haven't tried to create a new one.
Agreed. I really hope I don't have to replace my opener (it won't work with other solutions like the Insteon and GoControl kits)...FlyingDiver wrote:Still happening this morning. That's not good.
How many MyQ devices do you have? And do you already have Indigo devices created for them?DaveL17 wrote:Applied the update and the error messages are gone. List of MyQ devices under the device config dialog is still empty, however. I invoked Update Device Status from the plugin menu--still no errors--but also still no devices listed under the config menu. I tried creating a new device and the list was likewise empty. Perhaps I need to be patient?
Uno.FlyingDiver wrote:How many MyQ devices do you have? And do you already have Indigo devices created for them?
