Stack trace
Fri Nov 03, 2017 2:25 pm
Stack trace
Got the following several times in a row this afternoon:
   MyQ Error                       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 94, in runConcurrentThread
  File "plugin.py", line 365, in getDevices
  File "plugin.py", line 338, in myqLogin
AttributeError: 'Response' object has no attribute 'status_coderl'
Then, about 5 minutes later (and after I bounced the plugin), I got:
   MyQ Error                       myqLogin failure, RequestException: ('Connection aborted.', error(54, 'Connection reset by peer'))
Seems likely that they've got some kind of system/network issue, but you might want to at least catch that first error.
Fri Nov 03, 2017 2:37 pm
Re: Stack trace
Their systems are totally screwed right now. I can't even log into the website. So I can't test my code changes. :(
Sat Nov 04, 2017 7:22 am
Re: Stack trace
I think I just misspelled that attribute. Fixed in my current code, but I can't replicate the error to test.
