Bad return code: Unauthorized
Tue Nov 28, 2017 10:50 am
Re: Bad return code: Unauthorized
OK, I'm calling this one good and upgrading it to an actual release. Which means the built-in upgrader will work now.
Tue Nov 28, 2017 8:48 pm
nelis249 offline
Yea that issue #22 was me hehe. I was asking to see if they encountered the same issue, and they did. WIth the help from brbeaird it is indeed the additional header. I checked the android apk and found the headers in there as well. My unit tests are functioning now, whoot. Game on myQ'ers.
Tue Nov 28, 2017 9:36 pm
lanbrown wrote:
A published API would be nice. Even better would be able to either query the MyQ gateway or opener itself and if it could alert say Indigo of a status change of say the door. Then you would have instantaneous status of door changes so Indigo could then do what you want it too.
Z-wave Garage Door tilt sensors work great for that. And the MyQ plugin allows you to associate such sensors with the MyQ device and will report an error if the two don't agree.
Mon Jan 15, 2018 2:12 pm
kennybroh offline
BTW, I was having that error message but 7.1.9 fixed it.
