7.1.4 Released
Sun Feb 05, 2017 1:31 pm
7.1.4 Released
This version has the linked sensor devices and improved login error checking.
Tue Feb 14, 2017 10:42 am
roquej offline
Re: 7.1.4 Released
Since updating to 7.1.4, I am getting the following error:
File "plugin.py", line 94, in runConcurrentThread
File "plugin.py", line 328, in getDevices
File "plugin.py", line 310, in myqLogin
UnboundLocalError: local variable 'err' referenced before assignment
Nothing has change. the login/password is the same at 7.1.2 when it worked flawlessly.
Any suggestions?
JP
Tue Feb 14, 2017 10:44 am
Re: 7.1.4 Released
MyQ changed the API. I'm working on a fixed version. I've got the error you're getting fixed, but I'm still working on the commands to open/close a door.
Tue Feb 14, 2017 10:45 am
roquej offline
Re: 7.1.4 Released
Ok - thanks.
FYI: 7.1.5 gets the same error
JP
Sat Nov 25, 2017 3:10 pm
Tom W offline
Re: 7.1.4 Released
I guess I'm dense - where do I go to get the PlugIn to download? I've searched and I can't find it.
Sat Nov 25, 2017 3:13 pm
Re: 7.1.4 Released
My bad. Current is here: https://github.com/FlyingDiver/Indigo-M ... v7.1.8.zip
Be warned that some users cannot use the plugin because of an API change on the MyQ side that is slowly rolling out.
Sat Nov 25, 2017 8:57 pm
Re: 7.1.4 Released
lanbrown wrote:
So if the current plugin works don't upgrade, is that what you're saying?
No. If the API change effects you, it'll happen with any version.
If you already have it installed, you can upgrade using the plugin menu.
