Ok - Uninstalled the plugin, and reinstalled it and the chamberlain error went away. Now everything seems to work now!
Thank you!
JP
roquej wrote:Ok - Uninstalled the plugin, and reinstalled it and the chamberlain error went away. Now everything seems to work now!
Thank you!
JP
roquej wrote:Ended up calling Liftmaster support and they did something that got rid of the 2017 error. The plugin is now working ,but getting the following error in the log, when it executes:
Script Error embedded script: 'key name chamberlainAppID not found in database'
embedded script, line 6, at top level
KeyError: 'key name chamberlainAppID not found in database'
dnomode wrote:I selected an I/O-Linc as a sensor device, however the status of the garage door does not change until the plugin updates which is every 5 minutes. Is this normal?
dnomode wrote:Is there a way I can create a trigger to update the device status when the I/O-Linc Binary Input changes? Or when motion is detected in the garage?
