MyQ Plugin discussion
Sun Nov 27, 2016 7:34 pm
Re: MyQ Plugin discussion
So the south door was closed and the north door was open? How was that door opened? Wall button, car remote, MyQ app?
Sun Nov 27, 2016 7:36 pm
dougkillmer offline
Correct. It was opened by car remote.
When I try to open with Indigo, I get the following error:
Nov 27, 2016, 5:35:18 PM
   MyQ Debug                       actionControlDevice: "North Door" Toggle
   MyQ Error                       Error in plugin execution ExecuteAction:
  File "plugin.py", line 187, in actionControlDevice
AttributeError: 'RelayDevice' object has no attribute 'isOn'
Sun Nov 27, 2016 7:37 pm
Is that the latest version of the plugin?
Sun Nov 27, 2016 7:38 pm
dougkillmer offline
I think so, It's running 7.0.1.
Nov 27, 2016, 5:38:04 PM
   MyQ                             Checking for updates...
   MyQ Debug                       Plugin version detected: 7.0.1
   MyQ Debug                       Current version is: 7.0.1
   MyQ Debug                       Getting latest release from FlyingDiver/Indigo-MyQ...
   MyQ Debug                       GET /repos/FlyingDiver/Indigo-MyQ/releases/latest
   MyQ Debug                       HTTP 200 OK
   MyQ Debug                       Latest release is: 7.0.1
   MyQ                             No updates are available
Sun Nov 27, 2016 7:58 pm
OK. I'll look into that.
Fri Dec 02, 2016 5:01 pm
roquej offline
Trying to use MyQ 7.02, which doesn't have the sensor support, and getting the following error:
changeDevice: Bad return code: Error processing request (217)
Any suggestion?
thanks in advance
JP
Fri Dec 02, 2016 5:08 pm
Seems to be a not uncommon error with the gateway. See: https://myqcommunity.chamberlain.com/ch ... /error-217
Might be an intermittent error on the MyQ server side.
Sun Oct 22, 2017 1:26 pm
wideglidejrp offline
What is the model 9000? The liftmaster site does not show it?
John R Patrick
Author of
Home Attitude
Sun Oct 22, 2017 1:38 pm
I have no idea. Where did you get that number?
Sun Oct 22, 2017 1:45 pm
It was posted in this discussion in November and again later. First post says "Just installed with Indigo 7. I have a new Liftmaster 9000 series with MyQ. Works great so far. I will post again if I run into any issues.." Also, a few other questions, please:
1. Good success with the 8550W ?
2. Requires separate purchase of MyQ option? I think is $99.
.3. Does the plugin know door status, so I can test, say at 6PM, if door is open, and if so, close it?
John R Patrick
Author of
Home Attitude
Sun Oct 22, 2017 1:51 pm
Ah, that was posted by another user. I have the 8500 jack shaft model, not the 8550 belt drive, but they're the same as far as the MyQ interface is concerned.
I did need to buy the external box that connects to the home lan. I think you can get it for $70-80 or so. List price is probably $100.
The plugin knows the last status that it was able to get from the MyQ servers, but that's not 100% reliable. I recommend installing a z-wave garage door (tilt) sensor and linking it to the plugin device so that the plugin use that for definitive closed/not-closed status. Mine are https://www.monoprice.com/product?p_id=11987
Sun Oct 22, 2017 3:26 pm
lanbrown wrote:
I guess I should look into seeing if I could tap into the door sensor on each garage door as they are both tied into the alarm system. Might be easier than adding a battery powered Z-wave device into the network.
If the sensor looks like a standard on/off sensor to Indigo, it should work fine. If not, look at my Masquerade plugin to see if you can fake it.
Sun Oct 22, 2017 3:27 pm
I found a z-wave garage door sensor at http://a.co/8TT7ikr It has gold contacts to avoid corrosion and also a 5-year battery. Found a good article about KRACK at....
https://krebsonsecurity.com/2017/10/wha ... -weakness/
John R Patrick
Author of
Home Attitude
Mon Oct 23, 2017 5:14 pm
lanbrown wrote:
Given that it is just two wires; it is either just an open or closed circuit, so it should be fairly simple to get setup in Indigo.
If you have Insteon already installed, then an I/O Linc should work if they are simple N/O or N/C sensors. I think FlyingDiver accepted my patch to the plugin that allows I/O Lincs to work directly as sensors in the plugin without having to use the Masquerade plugin.
