MyQ Plugin discussion
Wed Nov 23, 2016 7:50 am
Re: MyQ Plugin discussion
OK, that's a typo. Not going to roll an immediate fix because it's self correcting on next poll of the device status.
Fri Nov 25, 2016 8:14 am
Bollar offline
It turns out the plug-in isn't actually controlling the doors. It gets status okay, but when I try to lock or unlock, I get the following:
2016-11-25 08:12:32.640   MyQ Debug   actionControlDevice: "Range Rover" Unlock
2016-11-25 08:12:32.643   MyQ Debug   changeDevice: Range Rover, state = 1
2016-11-25 08:12:32.835   MyQ Debug   myqLogin: response = <Response [200]>
2016-11-25 08:12:32.838   MyQ Debug   myqLogin: content = {"UserId":0,"SecurityToken":"xxx","ReturnCode":"0","ErrorMessage":"","BrandId":2,"BrandName":"Chamberlain","RegionId":1}
2016-11-25 08:12:32.840   MyQ Debug   myqLogin: Success, Brand = Chamberlain, SecurityToken = xxx
2016-11-25 08:12:33.025   MyQ Debug   changeDevice: Bad return code: MyQ Application ID unrecognized. (1001)
2016-11-25 08:13:30.993   MyQ Debug   actionControlDevice: "Tesla" Lock
2016-11-25 08:13:30.995   MyQ Debug   changeDevice: Tesla, state = 0
2016-11-25 08:13:31.230   MyQ Debug   myqLogin: response = <Response [200]>
2016-11-25 08:13:31.233   MyQ Debug   myqLogin: content = {"UserId":0,"SecurityToken":"xxx","ReturnCode":"0","ErrorMessage":"","BrandId":2,"BrandName":"Chamberlain","RegionId":1}
2016-11-25 08:13:31.236   MyQ Debug   myqLogin: Success, Brand = Chamberlain, SecurityToken = xxx
2016-11-25 08:13:31.445   MyQ Debug   changeDevice: Bad return code: MyQ Application ID unrecognized. (1001)
Fri Nov 25, 2016 9:43 am
That's odd. Grab this version:
https://github.com/FlyingDiver/Indigo-M ... 8b3787.zip
Then in the plugin config dialog, change the Brand to "Chamberlain v4". See if that works.
There's two sets of API keys floating around the Internet. I've been using the older one, but I found a newer set associated with the SmartThings plugin. I've tried both, and not sure what if anything is different. That's the problem with using a reverse engineered API. There's no definitive source.
Fri Nov 25, 2016 10:23 am
Bollar offline
That works. I was using 7.1 and didn't notice if there was a v4 in that version.
Fri Nov 25, 2016 10:25 am
No, I still had the old one in there. Now I need to find out if I can switch them all to the new API key or if I need to keep them both.
Fri Nov 25, 2016 10:26 am
Bollar offline
Also, I don't know if this is important or not, but the Device Details: Last Update doesn't change when I Send Status Request. I see it's successful in the log.
Fri Nov 25, 2016 10:28 am
I don't explicitly set that in the plugin. I think the Indigo server does, based on actual changes to the device state. Are you saying that the door states did change but the Last Update did not?
Fri Nov 25, 2016 10:32 am
Bollar offline
Sorry, when I manually send a status request (not when I open or close a door), the last update time doesn't update. IMO, it should.
Fri Nov 25, 2016 10:37 am
Well, I'm writing the current door states back to the Indigo server on every status report or check. If the update time isn't changing, it's because Indigo isn't doing so when the states haven't actually changed. I think you 're going to need to do a feature request to Matt & Jay to change that.
Fri Nov 25, 2016 11:04 am
Bollar offline
Cool, I'll take it up with management.
Sun Nov 27, 2016 6:51 pm
dougkillmer offline
I'm running 7.0.1 and I've noticed these errors once in a while.
Nov 27, 2016, 3:52:03 PM
   MyQ Debug                       myqLogin: content = {"UserId":0,"SecurityToken":"71836042...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
   MyQ Debug                       myqLogin: Success, Brand = Liftmaster, SecurityToken = 71836042...
   MyQ Debug                       getDevices: 3 Devices
   MyQ Debug                       getDevices: MyQDeviceTypeId = 1, DeviceId = 50360411
   MyQ Debug                       getDevices: MyQDeviceTypeId = 7, DeviceId = 251758172
   MyQ Error                       getDevices: Opener North Door (251758172), state out of range: 9
   MyQ                             MyQ Device North Door is now Unknown
   MyQ Debug                       getDevices: MyQDeviceTypeId = 7, DeviceId = 251758173
   MyQ Error                       getDevices: Opener South Door (251758173), state out of range: 9
   MyQ                             MyQ Device South Door is now Unknown
Nov 27, 2016, 4:02:37 PM
   MyQ Debug                       myqLogin: content = {"UserId":0,"SecurityToken":"a4574d3f...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
   MyQ Debug                       myqLogin: Success, Brand = Liftmaster, SecurityToken = a4574d3f...
   MyQ Error                       getDevices: Opener North Door (251758172), state out of range: 8
   MyQ Error                       getDevices: Opener South Door (251758173), state out of range: 8
Nov 27, 2016, 4:13:10 PM
   MyQ Debug                       myqLogin: content = {"UserId":0,"SecurityToken":"8f6dd356...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
   MyQ Debug                       myqLogin: Success, Brand = Liftmaster, SecurityToken = 8f6dd356...
Sun Nov 27, 2016 7:02 pm
Do you have any idea what's going on with the doors when you get state 8 or 9? They're not on the list of known states that I have.
The states I know are:
doorStateNames = ["Unknown", "Open", "Closed", "Stopped", "Opening", "Closing", "Unknown", "Disconnected"]
That's 0 through 7. I can add 8 and 9 in as "Unknown", but that's just masking the problem.
Sun Nov 27, 2016 7:19 pm
dougkillmer offline
Thanks, I believe the doors were open when 8 and 9 were received..
I decided to remove the Indigo devices and let the plug-in create new ones for now. Maybe I caused the problem by upgrading and downgrading the plugin a number of times. I'll let you know if I see it again with these new devices.
Sun Nov 27, 2016 7:25 pm
No, I don't see any way you could cause that problem. The number is taken directly from the API call to the MyQ servers.
Sun Nov 27, 2016 7:32 pm
dougkillmer offline
I received 9 again with one door open.
Nov 27, 2016, 5:29:45 PM
   MyQ Debug                       myqLogin: content = {"UserId":0,"SecurityToken":"a861a310...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
   MyQ Debug                       myqLogin: Success, Brand = Liftmaster, SecurityToken = a861a310...
   MyQ Debug                       getDevices: Opener South Door (251758173), state = 2
