Basic Installation
Sat Feb 11, 2017 5:31 pm
jgb offline
Re: Basic Installation
Works perfectly now. Thanks.
Mon Feb 13, 2017 8:47 pm
blysik offline
I started getting the login error after months of it working fine. I upgraded to most recent version, but I'm still getting this:
MyQ Error                       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 94, in runConcurrentThread
  File "plugin.py", line 335, in getDevices
  File "plugin.py", line 315, in myqLogin
UnboundLocalError: local variable 'err' referenced before assignment
   MyQ Error                       plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any suggestion?
Mon Feb 13, 2017 8:55 pm
Turn on debug logging. There should be a couple of log entries just before you get that error.
Mon Feb 13, 2017 8:57 pm
blysik offline
It's tricky, because it won't let me save the config with debug. However, It will if I stay on that panel:
MyQ Debug                       myqLogin request url = https://myqexternal.myqdevice.com/api/user/validate?username=EMAIL&password=PASS&appId=LONGAPPID
   MyQ Debug                       myqLogin response = <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[5442595389213767696]</body></html>
That's all I can get out of debug.
Mon Feb 13, 2017 9:03 pm
blysik offline
No crazy characters in email or password. Just letters and numbers.
Mon Feb 13, 2017 9:04 pm
Did you edit that url line in the log output?
Mon Feb 13, 2017 9:08 pm
blysik offline
Yes, I should have been clear. I anonymized my email, password, and appid.
Mon Feb 13, 2017 9:09 pm
The appID is coded into the plugin, depending on the opener brand. it's not user specific.
The following line says that your login is being rejected. Are you sure the login info and brand selected are correct?
Mon Feb 13, 2017 9:14 pm
blysik offline
100%. I've verified via the myliftmaster.com site. The weird thing to me is that it was working fine forever, and then just today I noticed the error in the logs.
How often are you polling for status?
Mon Feb 13, 2017 9:17 pm
Hmm. Just checked. Mine is failing as well. I think MyQ broke the reverse engineered API we were using.
Need to do some research.
Mon Feb 13, 2017 9:24 pm
blysik offline
Ok, good to know it's not just me. :) I was polling every 9 minutes. I'll hold tight while we figure out what happened.
Tue Feb 14, 2017 12:22 am
bkmar1192 offline
mine seemed to have stopped working as well.
Wed Feb 15, 2017 8:19 pm
jgb offline
same issue after working fine for several day with 7.1.5 now this error message about a million times in the last 2 days due to attempt every 10 seconds.
Have disabled and re-enabled and also cannot reconfigure plug-in. Getting the error message in the login fields as before, when attempting to get debugging messages.
MyQ Debug myqLogin request url = https://myqexternal.myqdevice.com/api/u ... HKwTmDzHOu
MyQ Debug myqLogin response = <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[5442595389242462761]</body></html>
Wed Feb 15, 2017 8:21 pm
It's broken. Just stop using it until I resolve the API issues.
