Twilio plugin - BETA
Mon Jun 13, 2016 6:28 pm
Download from: https://github.com/FlyingDiver/Indigo-Twilio/releases
  1. Get Twilio account info and phone number (see other thread)
  2. Download and install plugin
  3. Configure Plugin
  4. Create Twilio Number Device
Right now, there's an action to send an SMS message. And there are Events (Triggers) to handle incoming SMS messages. You can set the polling interval, or you can use a Menu Action or scheduled action to poll for messages.
Mon Jun 13, 2016 7:05 pm
Re: Twilio plugin - BETA
Just posted v0.0.2, the Mclass release.
Added action to place a voice call, with a selection of hold music for the recipient to listen to. No voice announcement or anything, so be careful who you call.
Mon Jun 13, 2016 7:23 pm
Oops. Forgot to mention, you need to install the Twilio library using pip:
sudo pip install Twilio
Mon Jun 13, 2016 7:25 pm
Darnit. Got an initial configuration bug. Hold on...
Mon Jun 13, 2016 7:37 pm
OK, grab v0.0.3. I think that fixed it.
Tue Jun 14, 2016 1:57 am
mclass offline
Gosh - I'm flattered. First time I've had a release named after me!!
Unfortunately I'm away from home and office for the next few days, but can't wait to try it out! Many thanks.
Mon Jun 20, 2016 1:38 am
mclass offline
Hi!
Have finally got back to my ndigo, have downloaded the plugin, installed the Twilio python helper library (pip was a command not found, so I used easy_install instead), but find I get the following error on startup of the Twilio plug in (OSX 10.10.5, with Indigo 6.1.9):
20 Jun 2016 5:28:54 pm
  Reloading plugin "Twilio 0.0.3"
  Starting plugin "Twilio 0.0.3" (pid 445)
  Twilio Error                    Error in plugin execution InitializeMain:
  File "plugin.py", line 9, in <module>
ImportError: No module named twilio.rest
  Stopping plugin "Twilio 0.0.3" (pid 445)
  Stopped plugin "Twilio 0.0.3"
  Error                           plugin "Twilio 0.0.3" (pid 445) failed to start -- restarti
Tried restarting Mac after helper installation, but without success. I'm thinking the fault may lie in my installation of the Twilio helper package, but I'm not sufficiently (not at all?) familiar with the intricacies of Python - any suggestions?
Thanks in advance
Mclass
Mon Jun 20, 2016 1:42 am
You probably don't have it installed for Python2.6 which Indigo uses. I would recommend using easy_install to install pip and pip2.6, then using pip to install Twilio.
Thu Jun 23, 2016 1:23 pm
I'm trying to get a handle on how many people are using this plugin. If you're using it, please post a reply. Any issues or requests are welcome as well.
Thu Jun 23, 2016 4:35 pm
mclass offline
I'm kinda using it - Over the Twilio helper issue, thanks, but was having difficulties in configuring. Did not resolve this because life (work, family, renovations) got in the way. Hoping to get back to it next week as I am hoping to interface Indigo to a remote cell-phone controller.
One issue (that is not in your domain!) is that Twilio does not offer a single phone number here in Australia that handles voice and SMS. I need voice capability to actuate the remote device, and SMS to receive status information. This means two separate numbers, so may need two "instances" of the plugin?
Anyway, I'll persevere when time permits to get the plugin up and running with just one number to see how we go. I suspect I may be seeking some advice .........
Thu Jun 23, 2016 4:49 pm
No, just two Twilio devices. As long as they both are under the same Twilio account, that is. Which shouldn't be a problem.
I didn't think to check the capabilities of the Aussie numbers when I picked Twilio, I just checked that they had numbers there. Pretty much all the numbers in the US do both. I wonder if there are other similar services that do both in Australia?
Thu Jun 23, 2016 8:04 pm
roquej offline
Using it. Thank you!
JP
Thu Jun 23, 2016 11:13 pm
mclass offline
Well, as things would have it, I found an hour this morning to have another go.
I have loaded the Twilio helper and the phonenumber packages (I had missed the latter one until I read the README file). I note that I have Python 2.6 and 2.7 so have loaded both packages into each (I think!!)
Twilio plugin appears to load OK, but when I attempt to create a device, the "Model" field in the Create New Device window does not present any models (" - no device type selected -"), and the Edit Device Settings tab is greyed out.
The Twilio number is active (messages can be sent and received from the Twilio console), and I have rentered the Twilio SID and token.
Turned debugging on, but no hints there! Just plugin version check (completes OK - version 0.0.3). Have reloaded plugin, rebooted Mac, but to no avail. Should the event log show confirmation of connection to the Twilio account on starting or "check for new messages" on plugin drop down?
Any suggestions?
Fri Jun 24, 2016 6:19 am
The only thing I can think of that would cause those symptoms is a corrupt Devices.xml file.
I just pushed v0.0.4 to GitHub. Please use the link in the first message of this thread to download a new copy of the plugin. Don't use the updater.
All other users - some device state definitions have changed - please edit your Twilio devices to pick up the new states.
Fri Jun 24, 2016 6:31 am
And the phonenumbers module isn't actually needed (yet). I thought I needed to normalize the phone numbers for Twilio, but it's not actually required.
