Harmony Elite Home control buttons
Sat Mar 05, 2022 11:20 am
steve-indigo offline
I have a Harmony Elite remote with the separate home control buttons at the bottom of the remote. Is there anyway for indigo to determine when one of those buttons are pressed (turned on/off)?
If possible, I would like to setup a trigger or something and then perform some conditional action.
Sat Mar 05, 2022 11:32 am
Re: Harmony Elite Home control buttons
Use the LIFX bridge plugin to expose an Indigo device, which you'll be able to control. You can create a Virtual device to do so.
See the LIFX Bridge plugin thread for more info.
Commands to home control devices are not reported through the normal API, so I can't do events (triggers) based on them.
Sat Mar 05, 2022 3:05 pm
Thanks! I'll check into that plugin.
