Equivalent of holding down volume button?
Wed Jul 24, 2019 1:12 pm
rustyhodge offline
I'm trying to create an action that will turn my receiver's volume down to 0. My receiver has no support for a "Set Volume To", only increase/decrease.
I can create an action to send the volume down/decrease command to my receiver with the plugin; but it's really slow, and takes about 15 seconds to send enough volume downs.
Is there a way I can send the equivalent of "Press volume down for 3 seconds" on the remote? Pressing and holding down makes the receiver go down in volume much, much faster.
And thank you for this plug-in, it's amazing!
Wed Jul 24, 2019 1:24 pm
Re: Equivalent of holding down volume button?
Does the press-and-hold work with the Harmony remote, or just the OEM remote?
Thu Jul 25, 2019 7:55 am
Also, doesn't your receiver have a "mute" command?
Thu Jul 25, 2019 8:08 am
mat offline
Also, check for a plugin for your amp, lots are supported and you can get feedback from the amp if needed, ie current source, current volume etc
Late 2018 mini 10.14
