New Activity Devices available in Harmony Hub plugin
Wed Jun 05, 2019 12:23 pm
Pre-release: https://github.com/FlyingDiver/Indigo-H ... /tag/7.3.0
Users can now create an Indigo device to represent a Harmony activity. The device can be turned on (enabled) using any standard Indigo action or UI. Sending PowerOff command or switching to any other activity turns off the device.
The device accurately reflects activity changes initiated from Indigo, mobile apps, or Harmony remotes.
I'm going to hold this in pre-release until I get some additional testing reports. Please try....
Sat Jun 08, 2019 4:52 am
Umtauscher offline
Re: New Activity Devices available in Harmony Hub plugin
Thanks Joe,
this seems a nice addition to the plugin.
I have updated my installation yesterday. It took some time until the activity devices were correctly updated but now it works fine.
Thanks again
Wilhelm
Tue Jun 11, 2019 2:42 am
colinpartridge offline
Installed new version today and all appears well. Created some Activity devices which work well. Its made some tricky event triggering a bit clearer. All remotes sync activity status.
Cheers
Colin
Tue Jun 11, 2019 4:07 am
The updated functionality worked perfectly for me.
Nice feature!
Tue Jun 11, 2019 6:02 am
Published as new release for plugin store.
Sun Jun 16, 2019 1:13 pm
denno offline
What are some example use cases for this?
Sun Jun 16, 2019 1:14 pm
Using Siri or Alexa to start/stop/change activities is the primary one.
Sun Jun 16, 2019 3:56 pm
denno offline
Thanks. I've been using the Alexa Harmony Skill and the Homebridge plugin for Siri control. How would I set up Activity devices in the Harmony Hub plugin to do it?
Thanks for your help/
Sun Jun 16, 2019 3:57 pm
Just create a device for each activity, add it to HKB, then tell Siri to turn that device on or off.
Sun Jun 16, 2019 4:07 pm
denno offline
Ah--got it. Thanks-this is great!
Mon Jun 17, 2019 2:44 am
siclark offline
This is amazing, simplifies my setup so much.
Mon Jun 17, 2019 6:28 am
Glad to hear it.
Mon Jun 17, 2019 7:30 am
Umtauscher offline
Hi Joe,
from time to time the Harmony Hub device and the Activity devices seem to get out of sync.
For example at the moment the Harmony Hub device shows the Activity "Power Off" and the Activity device for the Activity Radio shows active (on). This obviously cannot be correct. In fact the PowerOff information is the one that is correct.
I have had something like that a few times since I installed the new version.
I hope you can do something about it.
Wilhelm
Mon Jun 17, 2019 7:41 am
Umtauscher offline
Maybe this is because I used to switch on the radio by the "start activity" command instead of the switching on my "Activity device" radio?
Mon Jun 17, 2019 7:55 am
Hmm. I would expect them to be out of sync for a short period (a few seconds) after an activity change is requested, but it should sync up shortly. If that's not happening, then there's a problem.
Turning an activity device on or off sends the same commands as the "Start Activity" command. The state of the device is not changed at that time, but when the plugin gets the "startActivityFinished" XMPP message. I did it that way so that Activity changes from a remote or mobile app (ie anything not from Indigo) will also update the device state.
If that's not happening, then the plugin is not getting the XMPP message, or not processing it properly.
Is this repeatable? If so, can you turn on debug level logging and go through the steps to get it to that state? Then post the log segments?
