Turn On/Off an activity
Sat May 25, 2019 10:03 am
johnofcamas offline
How can I create a 'device' that can turn on / off a specific Harmony Hub Activity?
Sat May 25, 2019 11:42 am
Re: Turn On/Off an activity
Create an Action Group that starts that activity.
Create an Action Group that stops that activity, which means a Power Off command.
Create a Virtual Device -> Virtual On/Off Device that uses those two action groups for on/off.
And yes, that seems like a lot of work for what should be simple. Feel free to create an enhancement request on the GitHub page for the plugin.
Sat May 25, 2019 11:52 am
Be aware that this minimalist implementation won't work properly with Siri (using HKB) because the virtual device doesn't maintain state. The device always looks like it's off so Siri won't ever send the actual off command.
I'll see if I can come up with a workaround. Adding virtual activity devices to the plugin would probably be easier. Hmmm.
Sat May 25, 2019 12:36 pm
OK, to make it work with Siri (and I assume Alexa, but I'm not sure) you need a status variable to associate with the virtual device.
So, create an Indigo variable. Edit the Virtual Device settings. Enable status, and pick the variable from the list.
Now, you need TWO triggers. One to set the variable to true, another to set it to False.
Create a Trigger of type "Device State Changed". Pick the Harmony Hub device and the "Current Activity" state. Select "Becomes Equal to" and put in "PowerOff". Leave Condition to Always. Set the action to Variable Actions->Modify Variable, pick your status variable, then "Set to false". Save.
Repeat previous step, but this time you want "Becomes Equal to" to be the name of the activity you're starting. And set the status variable to True.
There's probably an easier way to do this with one of the plugins that does smarter virtual devices.
I really should add this directly to the plugin....
Sun May 26, 2019 7:18 am
johnofcamas offline
Brilliant! And thanks for anticipating my Siri question which would have been next :D
Sat Jun 01, 2019 4:06 pm
denno offline
Is it possible to do a similar thing with a Harmony device instead of an activity? Haven't been able to figure out how to do it.
I tried creating an Action Group to send a device specific command but there are no devices listed in the action settings dropdown.
I did enable XMPP.
Use case: my TV occasionally turns itself off. I'd like to be able to use Siri to turn it back on.
Sat Jun 01, 2019 5:56 pm
The problem with making a Siri friendly switch for a device is that the plugin has no way to determine what the current state of the device is, so it might be a problem getting Siri to actually send the command.
I think HKB has a stateless switch type, so using that might make it work. Worth a try.
Sat Jun 01, 2019 5:59 pm
I just saw the second part of your post. As far as I remember that dialog should work. I’m not near a computer now so I can’t verify.
Do the formatted device dump from the menu an post it here.
Sat Jun 01, 2019 9:18 pm
denno offline
Device dump-
2019-06-01 Events.txt
(97.68 KiB) Downloaded 152 times
Sat Jun 01, 2019 9:27 pm
denno offline
I just checked again and now my devices are showing up as expected
Wed Jun 05, 2019 12:13 pm
Activity devices now in pre-release 7.3.0: https://github.com/FlyingDiver/Indigo-H ... /tag/7.3.0
Please test.
