When is this needed?
Sat Apr 14, 2018 6:29 am
mrmatt68 offline
I just ordered a harmony elite with the intentions of adding actions to siri. Do I install this plugin or install the home bridge-harmony plugin or both? I am currently using the home bridge buddy plugin. Just a little confused on what is needed.
Matt
Sat Apr 14, 2018 7:14 am
Different Computers offline
Re: When is this needed?
The harmony hub acts as an indigo device once the plugin is installed & configured.
You can then create Action groups that do harmony activities.
Then publish those to HomeKit with HomeKit bridge.
Sat Apr 14, 2018 7:45 am
I guess there's two ways to do this. Use this plugin so that the Hub can be controlled from Indigo, then use the HomeBridge Kit (or Homebridge Buddy) plugin to enable control of from HomeKit (and Siri).
Or use the homebridge-harmony adapter so you can go direct from HomeKit to the Harmony, bypassing Indigo.
Which you use depends on if you want to be able to control the Hub from Indigo as well as HomeKit.
Sat Apr 14, 2018 10:40 am
Having gone the HomeKit Bridge route and the Harmony Hub plugin route, I can't recommend it enough. It will be much harder to arrange good integration between your AV and the rest of the house any other way.
Sun Apr 15, 2018 8:33 am
mrmatt68 offline
Thank you so much. Can’t wait to try this out! Love the new version of indigo with the plug-ins.
