Not able to set IP for Hubs
Sat Dec 16, 2017 12:46 pm
ksalno offline
I downloaded 7.2.2. plug-in and installed successfully. The logs are clean with no errors. When I go in to try to create a New Device with Indigo, I can select Harmony Hub but when I try to configure, I don't get any values in the drop down box to input the Model and therefore, the box to enter the IP address shows "undefined" and stays greyed out.
Sat Dec 16, 2017 1:12 pm
Re: Not able to set IP for Hubs
I just updated to v7.2.2 from 7.2.1 and it works fine for me.
Sat Dec 16, 2017 1:32 pm
That sounds like the plugin got corrupted somehow and the Devices.xml file is missing. Can you confirm it's still in the .indigoPlugin wrapper? Or are you possibly using a case-sensitive HFS+ file system? I think that's caused similar issues for people.
Tue Dec 19, 2017 9:20 am
Please create a compressed zip file of the plugin as installed (right click in Finder), then create an issue on GitHub and attach it: https://github.com/FlyingDiver/Indigo-Harmony/issues
Fri Dec 22, 2017 9:44 am
Working now.
