Not working without Internet connection?
Sat Nov 18, 2017 9:58 am
Umtauscher offline
due to recent events I wanted to block my Harmony hubs from the Internet (via blocklist in my router).
Unfortunately this seems to stop all communication to Indigo.
So my question is:
Does the API you are using with the harmy hub rely on an active Internet connection or is this just another bug Harmony indroduced in their recent firmware updates?
Any hint or insight is highly apreciated.
TIA
Wilhelm
Sat Nov 18, 2017 11:35 am
Re: Not working without Internet connection?
I'm pretty sure on one of those regular internet outages I experience out here, my Hub keeps working with Indigo.
Sat Nov 18, 2017 11:50 am
Umtauscher offline
Thanks, I'm sure now, the Harmonyhub altogether is not working any more without being online.
You may test yourself. Once the iOS app is connected to the hub it just takes a while until it stops working.
Sometimes it takes a few hours.
It seems Indigo Harmony plugin just react faster to an internet outage. It's a pain since there is no real alternative to Harmony.
Cheers
Wilhelm
Sat Nov 18, 2017 1:26 pm
The plugin uses the pyharmony library (https://pypi.python.org/pypi/pyharmony). The library needs to communicate with Logitech's servers to get an authentication token needed to talk to the Hub. If you block the Hub from the internet then I think that authentication process will eventually fail when Logitech's servers decide the hub isn't active anymore.
I'd be very surprised if the Hub continued to work, even with a Logitech remote, after you block it.
Sat Nov 18, 2017 1:27 pm
I think it'll work until the authentication token expires.
Mon Jul 30, 2018 8:05 pm
rustyhodge offline
Sorry to bump this old thread, but if this is happening with your Harmony, update to a newer version. Harmony fixed this issue about a year ago.
Mon Jul 30, 2018 11:30 pm
Umtauscher offline
Thanks for sharing. I will try to isolate the hubs from the Internet right away.
If that is true, I would be very happy.
Wilhelm
Thu Aug 02, 2018 3:59 am
Umtauscher offline
Ok, I have used the hubs for 3 days now without internet connection.
Works ok, now.
Thanks again for the tip.
Wilhelm
