Harmony Hub Firmware v4.13.100
Sat Aug 05, 2017 2:06 am
Woetjes offline
Hi Joe,
Yesterday I've updated my two Hubs to the latest firmware. I can control the hubs (start/stop activities) via the plugin but the status of the hub is not updated (so, no triggers are executed :( ), unless I do a reboot of the plugin.
Some debugging:
   Harmony Hub Debug               Living: Harmony Hub: messageHandler: Event state notify, activityId = 18968390, activityStatus = 1
   Harmony Hub Debug               Living: Harmony Hub: messageHandler: Event state notify, activityId = 18968390, activityStatus = 2
   Harmony Hub Debug               Living: Harmony Hub: messageHandler: Event startActivityFinished, activityId = 200, errorCode = OK, errorString = 18968390
And idea? Let me know if you need something else!
W
Sat Aug 05, 2017 2:30 am
Re: Harmony Hub Firmware v4.13.100
I can confirm this behaviour with mine.. two hubs updated do the same, one that hasn’t yet seems to work fine. Interestingly the two that aren’t updating are still causing the “Last Update” field to change so clearly the plugin is still recognising that a change has occurred.
Sat Aug 05, 2017 5:50 am
OK, I see it. I have one hub on the new firmware, and one on the old.
I'll work on a fix this weekend.
Sat Aug 05, 2017 7:41 am
Woetjes offline
Great - thanks!!
Sat Aug 05, 2017 12:43 pm
v7.1.1 posted. Use built in updater.
Sun Aug 06, 2017 4:20 am
Woetjes offline
Thanks. Getting an error now on both hubs, any idea how to resolve this?
   Harmony Hub Error               exception in deviceStartComm(Living: Harmony Hub): not all arguments converted during string formatting
Sun Aug 06, 2017 5:36 am
Turn on debug logging and try it again.
Sun Aug 06, 2017 5:42 am
Woetjes offline
I get this all the time:
Harmony Hub Debug               Called deviceStartComm(self, device): Living: Harmony Hub (913114866)
   Harmony Hub Debug               Living: Harmony Hub: Device Current Version = 0
   Harmony Hub Debug               Living: Harmony Hub: Device Version is up to date
   Harmony Hub Debug               Living: Harmony Hub: Starting harmonyHub device (913114866)
   Harmony Hub Debug               Living: Harmony Hub: Socket test failure
Sun Aug 06, 2017 5:46 am
I need to change the line just above the error to another error or warning. "Socket test failure" means the plugin was unable to get a connection to the hub. That usually means that the IP address is wrong. I need to check why that's not getting reported correctly.
Double check the IP address of your hub hasn't changed.
Edit: Found the error causing the exception. Will be fixed in next release. Your IP address is still wrong.
Sun Aug 06, 2017 6:02 am
Woetjes offline
Oohhh my bad.. I updated my WLC yesterday and for some reason my wireless clients were in another subnet. Everything is working now ;) Thanks!
Sun Aug 06, 2017 5:40 pm
roquej offline
Update to the latest firmware by mistake and although updated to the latest version of the plugin, now getting the following errors when changing activities:
Harmony Hub Error Harmony Hub - Family: Event startActivity child.text parse error = local variable 'pairs' referenced before assignment
Harmony Hub Error Harmony Hub - Family: Event startActivity child.attrib = {'type': 'harmony.engine?startActivity'}, child.text:
done=3:total=7:deviceId=17702736
done=4:total=7:deviceId=29438601
done=5:total=7:deviceId=29438601
done=6:total=7:deviceId=29438601
done=7:total=7:deviceId=29438601
Suggestions?
Thank you in advance.
JP
Sun Aug 06, 2017 7:03 pm
I introduced that error when I fixed the other firmware problem. It's benign, but I'll fix it in an update in the next couple days.
Sun Aug 06, 2017 7:50 pm
roquej offline
Ok - thank you for great work.
Sat Sep 02, 2017 6:06 am
wormhole offline
Running Harmony Hub plugin V7.2, two hubs connected, one with v4.13.100 status still not updating, however hub runinng v4.12.36 activity status is working/updating properly. only fix for having hub with v4.13.100 properly reflect activity is stopping/restarting the plugin.
Sat Sep 02, 2017 7:22 am
Can you post debug logging entries for the Hub with the new firmware when you change activities?
