[SOLVED] First install problems
Sat Apr 29, 2017 5:50 am
marketability offline
Hi - wonder if anyone can help me please...
installed sleek then the plugin but am getting the following error lines in the log and can't successfully create a hub device...
   Error (client)                  timeout waiting for plugin response from com.flyingdiver.indigoplugin.harmonyhub for request UiGetValues1
   Error (client)                  timeout waiting for plugin response from com.flyingdiver.indigoplugin.harmonyhub for request CallPluginFunc
   Error (client)                  runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
   Z-Wave                          received "MultiPorch 029 - Motion Sensor" status update is on
   Z-Wave                          received "MultiKitchen 039 - Motion Sensor" status update is off
   Z-Wave                          received "MultiKitchen 039 - Tamper" status update is off
   Error (client)                  timeout waiting for plugin response from com.flyingdiver.indigoplugin.harmonyhub for request CalcDeviceFunc
   Error (client)                  timeout waiting for plugin response from com.flyingdiver.indigoplugin.harmonyhub for request UiGetValues2
   Error (client)                  runDialogForDevice() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Sat Apr 29, 2017 5:53 am
Re: First install problems
Those look like the messages you get when you have an open Device configuration dialog box. Try quitting the Indigo client and restarting it.
Sat Apr 29, 2017 5:57 am
doh - sorted - stoped and started indigo server and worked OK
blonde moment No.21 today
Sat Apr 29, 2017 5:58 am
Re: [SOLVED] First install problems
Thanks for the response - i turned my brain on whilst you were typing it would appear
Cheers
