Pause / Play commands - can lights be controlled?
Sat Dec 31, 2016 11:45 am
docp offline
Hello
Thank you for this plugin - it is great. I was wondering if it is possible to initiate indigo events based on pause / play actions - I have searched through the threads but can't find an answer to this question -
At the moment I can have the lights dim when an activity is started or stopped. Is it possible to have the lights brigthen when the pause button is pressed?
Sat Dec 31, 2016 12:34 pm
Re: Pause / Play commands - can lights be controlled?
Not easily, no. The hub doesn't communicate individual button presses to other clients. Only activity changes and automation controls.
I think what some users are doing is setting up Control Pages that they use to control their AV equipment, and pause/play buttons send both light and AV equipment commands.
Sat Dec 31, 2016 1:13 pm
GlennNZ offline
docp wrote:
Hello
Depends on what you are playing on - as far as I'm aware there are plugins for plex, emby, Kodi and Roku? (Probably others that I've missed). With these plugins playback, pause events can be captured and lights dimmed etc.
(Thanks a lot for Harmony plugin - all going well)
Glenn
Thu Jan 05, 2017 2:16 am
docp offline
Thank you for the reply. The Plex plugin in excelltent and I have got this working (thank you to the author). I can't seem to find a kodi plugin however. The media box I want to buy uses kodi so ideally this is what I need. Can anyone point me in the right direction?
Thu Jan 05, 2017 11:15 am
Colorado4Wheeler offline
I wrote a Kodi plugin for myself a while ago but have long since stopped using Kodi and just use Plex with my Apple TV now. If you want I could post it up for you to play with, it worked quite well when I was using it.
Sat Jan 14, 2017 3:54 am
docp offline
Hi there
Thank you very much for the offer - it is very kind of you. I have also decided to settle with plex. The available plugin works pretty well I think.
Thank you again!
