Re: Harmony Hub plugin
Sun Nov 27, 2016 11:35 am
nev offline
Re: Harmony Hub plugin - Indigo 7
https://www.python.org/downloads/
I used the standard one from this link. I think you're correct regarding other installs as I've had home-brew at some point as well.
Sun Nov 27, 2016 11:53 am
At this point, I would try to uninstall that one you got from python.org. There was no need to install it, and it's causing the problem.
Sun Nov 27, 2016 12:11 pm
nev offline
Oh my! That did it. Wow, sorry that was right in front of me. Thanks for your help, I really appreciate it! I use this plugin for so much.
Mon Nov 28, 2016 8:05 pm
denno offline
Having a problem with the plugin and Indigo 7. If I read the thread right, I don't think I need to install anything else.
Starting plugin "Harmony Hub 7.0.0" (pid 1927)
   Harmony Hub Error               Error in plugin execution InitializeMain:
  File "plugin.py", line 10, in <module>
ImportError: No module named sleekxmpp
Tue Nov 29, 2016 10:09 am
Yes, you need to install sleekxmpp. The first line is only needed if you haven't installed pip yet. But rerunning it shouldn't hurt anything.
sudo easy_install pip
sudo pip install sleekxmpp
Tue Nov 29, 2016 9:22 pm
denno offline
Thanks-got it working. How do I find the IP address of the Harmony Hub?
Tue Nov 29, 2016 9:23 pm
You'll have to look on your router's DHCP lease list for that info. I don't know of any other way.
Tue Nov 29, 2016 9:37 pm
rapamatic offline
At least in iOS, open the harmony app, go to Menu -> About -> Versions
Tue Nov 29, 2016 10:35 pm
D'oh. Never even looked there.
Tue Nov 29, 2016 11:12 pm
denno offline
Thanks. Is there a guide someplace to how to use the plugin? I didn't see anything with the download.
Wed Nov 30, 2016 6:27 am
Not really. It's like most other Indigo plugins. It has actions and event triggers. The most useful ones are the events that trigger when certain Harmony activities start/stop, and the actions to start/stop those Activities.
Thu Dec 01, 2016 1:03 pm
I'm going to lock this topic, as I don't want it to turn into a never ending Q&A thread. If you have a new issue, please start a new thread.
