Re: Harmony Hub plugin
Sat Nov 12, 2016 7:38 pm
I’m assuming you’re aware of it already but harmony hub doesn’t load (for me anyway) on i7:
   Starting plugin "Harmony Hub 0.2.8" (pid 82223)
   Harmony Hub Error               Error in plugin execution InitializeMain:
  File "plugin.py", line 8, in <module>
ImportError: No module named sleekxmpp
   Stopping plugin "Harmony Hub 0.2.8" (pid 82223)
   Stopped plugin "Harmony Hub 0.2.8"
Sat Nov 12, 2016 10:41 pm
Indigo 7 uses Python 2.7, not 2.6 like I6 did. You'll need to install the sleekxmpp module for 2.7.
Sun Nov 13, 2016 6:30 am
Ah very good! :)
Sun Nov 13, 2016 6:38 am
Yup that worked. Just in case anyone needs it the command to fix it is "sudo pip2.7 install sleekxmpp" :)
Wed Nov 16, 2016 10:04 pm
Wondercow offline
I just upgraded to Indigo 7 and can't get this plugin to work. I tried "sudo pip2.7 install sleekxmpp" as mentioned in the previous post and got "sudo: pip2.7: command not found" in response. I downloaded and installed Python 2.7.12 and was able to continue with installing sleekxmpp; however, when I tried to enable the plugin I again got
  File "plugin.py", line 10, in <module>
What am I doing wrong?
Wed Nov 16, 2016 10:28 pm
I suspect that you installed a new version of Python in a non standard location, and the sleekxmpp module as well.
Since Indigo 7 uses Python 2.7, which is the osX default. "sudu pip install sleekxmpp" should be what you need to run for the install.
Wed Nov 16, 2016 10:54 pm
Wondercow offline
I tried the above (using sudo, I recognize that, at least :) ) and I got "pip: command not found"
Thu Nov 17, 2016 5:28 am
That's what I get posting from my iPad. ;)
Try this:
sudo easy_install pip
sudo pip install sleekxmpp
Thu Nov 17, 2016 9:45 am
Wondercow offline
Try this:
Thank you so much for your help.
Originally this didn't work, but then I cleaned up my Python mess (different installs from their website and Homebrew), tried again, and it worked--I'm back on track :D
On another note, I'm seeing this in my log
Harmony Hub Error               Harmony Hub: messageHandler: Unknown Event Type: {'type': 'control.button?sequenceFinished'}
errorCode=200:errorString=OK
But everything still works (as far as I can tell). Is this concerning?
Thu Nov 17, 2016 10:23 am
That means it's a message type I never saw in my testing, so I didn't put in code to handle it.
Do you know what you did (or were doing) when that message appeared?
If you can turn on debug logging and do whatever you did to cause that message, then send me the log file, I'd appreciate it.
Thu Nov 17, 2016 7:19 pm
jingai offline
curl --data-binary '{"email":"me@email.com", "password":"password"}' -H 'content-type: application/json; charset=utf-8;' https://svcs.myharmony.com/CompositeSec ... rAuthToken
is suddenly returning {"GetUserAuthTokenResult":null}
I'm not using this plugin, but I'm using the same basic code called elsewhere. Is anyone else seeing this?
Fri Nov 18, 2016 10:16 pm
Wondercow offline
The errors seem to come up pretty often (+- 50 times per day), but with no rhyme or reason that I can see. I'll turn on debugging tomorrow and send you the log.
Sat Nov 19, 2016 10:23 am
jingai offline
Is it possible to call volumeUp and volumeDown from AppleScript?
I handle volume controls differently depending on what I'm doing at the time. So, if AirFoil is running for instance, I send volume commands to it. But if it's not running, I'd like to send the volume commands directly to the Harmony Hub.
Sat Nov 19, 2016 10:33 am
Not directly, at least not without a pretty hacky AppleScript that calls into python. Instead I would create 2 Action Groups for executing the actions, then you can easily execute the Action Group from AppleScript.
Sat Nov 19, 2016 10:35 am
jingai offline
Harmony Hub plugin - Indigo 7
Thanks, that'll work :)
