Could not get token from Logitech server
Posted: Tue Nov 22, 2016 2:53 am
When I start the plugin I get the following warning:
Is something wrong?
I have been controlling my harmony with a Vera for a long time. So I have not completely transitioned from Vera to the Indigo Plugin yet. Could two running plugins be causing problems for the HUB?
I have also seen some delays when executing commands with the Indigo Plugin compared to the Vera plugin. Is the Indigo plugin talking locally to the hub, or is everything going through the logitech servers?
With Indigo 7 out, I am planing to permanently shutting down my Vera, and move all harmony control to this plugin. Thanks for your brilliant work on this so far.
- Code: Select all
Harmony Hub Warning Harmony Plugin : Could not get token from Logitech server.
Harmony Hub Checking for updates...
Harmony Hub No updates are available
Is something wrong?
