- Posted on
Fri Sep 16, 2016 4:14 pm
Different Computers
offline
Finally, finally had an afternoon home early from work and time to call Logitech. So my activities are actually working rather than limping.
Now I'm trying to install the plugin.
Got pip installed.
Googled how to use it to install.
pip install sleekxmpp
Gives me a bunch of stuff, but then this in red:
- Code: Select all
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/private/var/folders/ts/jyctrlts01q_8jzmv8s_zv0m0000gp/T/pip-build-
BIjTu9/sleekxmpp/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record
/var/folders/ts/jyctrlts01q_8jzmv8s_zv0m0000gp/T/pip-kalvV2-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in
/private/var/folders/ts/jyctrlts01q_8jzmv8s_zv0m0000gp/T/pip-build-BIjTu9/sleekxmpp/
And requests did this:
- Code: Select all
Collecting requests
Downloading requests-2.11.1-py2.py3-none-any.whl (514kB)
100% |████████████████████████████████| 522kB 730kB/s
Installing collected packages: requests
Exception:
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/commands/install.py", line 317, in run
prefix=options.prefix_path,
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/req/req_set.py", line 742, in install
**kwargs
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/req/req_install.py", line 831, in install
self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/req/req_install.py", line 1032, in move_wheel_files
isolated=self.isolated,
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/wheel.py", line 346, in move_wheel_files
clobber(source, lib_dir, True)
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/wheel.py", line 317, in clobber
ensure_dir(destdir)
File "/Library/Python/2.7/site-packages/pip-8.1.2-py2.7.egg/pip/utils/__init__.py", line 83, in ensure_dir
os.makedirs(path)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 157, in makedirs
mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/Library/Python/2.7/site-packages/requests'
Help?
