error on gmail email scan
Mon Aug 26, 2019 5:18 pm
mpovolo offline
I am getting this, any idea how to fix it
Gmail: Error fetching Message 1: coercing to Unicode: need string or buffer, int found
thanks
Mon Aug 26, 2019 5:59 pm
Re: error on gmail email scan
Turn on debug logging and then post what you get.
Mon Aug 26, 2019 8:07 pm
mpovolo offline
Better Email Debug              Gmail: Connecting to POP Server
Better Email Debug              Gmail: Fetching Message # 1
Better Email Debug              Gmail: Parsing message GmailId16cd0bda7d51e82d
Better Email                    Gmail: Received Message Subject: Your Front Door camera saw Duilio.
Better Email                    Received Message From: Vomano <notifications@nest.com>
Better Email                    Gmail: Received Message To: mark.povolo@gmail.com
Better Email                    Gmail: Received Message Date: Tue, 27 Aug 2019 01:43:05 +0000
Better Email Error              Gmail: Error fetching Message 1: coercing to Unicode: need string or buffer, int found
Better Email Debug              Gmail: Logged out from POP server
Mon Aug 26, 2019 8:15 pm
I think you're the first person I've seen that is using POP with Gmail. OK, I need you to set the logging to "Detailed Debugging" and run the same test.
Mon Aug 26, 2019 8:23 pm
mpovolo offline
Should I be using IMAP
Mon Aug 26, 2019 8:25 pm
That does seem to work for most people.
Since the error you got mentioned unicode, I'm cleaning up the code to be more unicode friendly. This was the first plugin I wrote, so it's not as clean as my more recent ones.
Mon Aug 26, 2019 8:27 pm
mpovolo offline
I switched to IMAP, will try it.
Also, are you by chance familiar with http digest authentication and using restful API to run actions on into server
Mon Aug 26, 2019 8:50 pm
I am, somewhat, but this in not the right forum for that. Post in the appropriate forum. I'll see it.
Mon Aug 26, 2019 9:35 pm
mpovolo offline
ok thanks, can I use idle with gmail IMAP
thanks
Tue Aug 27, 2019 6:06 am
I think so. Try it and see.
