Experience with Kwikset 916
Sun Jan 10, 2021 7:45 pm
dduff617 offline
I just installed a Kwikset 916 deadbolt. Basic commands (lock/unlock) to the lock seem to work.
I created a new ZWave Lock/Code Manager plugin Door Lock device.
I was trying to send some commands to set user PINs and I was seeing these messages in logs (XX's substituted for PIN values).
   Z-Wave Lock/Code Manager        Setting PIN for user 5 to: XXXXXX
   Z-Wave                          sent "GAR-W Door Deadbolt" raw command [63 01 05 01  XX XX XX XX XX XX]
   Z-Wave                          received "GAR-W Door Deadbolt" status update user code add failed (duplicate)
   Z-Wave Lock/Code Manager        Unknown lock status received: 34 [Node: 111]
Can anyone tell me what "status update user code add failed (duplicate)" means? I assumed that I can set a user code and then set it again. Is it necessary to somehow clear an existing code before resetting it to a new value or something?
Also the "unknown status code" message is a bit disconcerting... Anyone seen that before?
I've used Indigo and ZWave Lock Manager on other Kwikset locks (not model 916) previously and had generally good results.
Sun Jan 10, 2021 8:05 pm
dduff617 offline
Re: Experience with Kwikset 916
Ok - i partially answered my own question.
I confirmed that if I first clear the PIN, then set the PIN, I don't get the "code add failed (duplicate)" error.
I thought with my the other KwikSet locks, I was able to write a script to do a bunch of set-pin commands and I could execute it repeatedly without problems - that is, without ever using the clear-pin command. Apparently the 916 works differently.
Thanks.
Sun Jan 10, 2021 8:11 pm
dduff617 offline
automating PIN-setting for multiple users, multiple locks -
I have five PINs for different family members and service providers. i have seven locks and plans for that number to increase. So for the overall setup, that's 35 set-pin commands I need to do. I occasionally need to add/delete/modify PINs so this is more than a one-time setup.
I can write an action group with a bunch of set-pin commands - this is a bit tedious. Neither the lock name nor the user-no show in the text for a set-pin action that appears when you do "Show All" in the action group, making it a bit hard to maintain (feature request).
I'm curious - does anyone have a python example showing how to loop over an array of PINs and a list of lock devices to automate the PIN setting/changing process? Seems much easier to write a script to iterate rather than using an action group, however offhand I'm not sure how to invoke the plugin commands in code.
Tue Jan 12, 2021 3:40 am
Hi
None of my actions are currently exposed to python for other users.
I’ll have to look into this.
Peter
Sat Jan 23, 2021 11:41 am
dduff617 offline
I'm seeing error in the log when door is unlocked/locked manually as follows:
   Z-Wave                          received "GAR-DRIVE-DOOR Deadbolt" status update unlocked (manually)
   Z-Wave Lock/Code Manager        Status: Door unlocked manually [Node: 112]
   Z-Wave Lock/Code Manager Error  Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 435, in zwaveCommandReceived
  File "plugin.py", line 850, in updateState
KeyError: (112,)
This is repeatable.
Sat Jan 23, 2021 4:36 pm
Have you created, or have you subsequently deleted, the dummy lock device?
Peter
Sun Jan 24, 2021 3:16 pm
dduff617 offline
I checked and I do have a "dummy" (Z-Wave Lock/Code Manager Plugin > Door Lock) device that points to the lock in question.
Today, I tried to reproduce the problem by manually locking/unlocking manually and by locking/unlocking using the keypad, but the error did not recur.
So for now, I'll retract my report. I'll notify if I see it again.
