Unkown Lock Status
Tue Mar 31, 2020 5:44 am
jenwill1 offline
Unkown Lock Status
I was checking my event log and noticed this error repeated each hour. I'm thinking this may be a low battery state ?
Copied on the device information on the lock below as well.
Thanks !
Z-Wave received "Utility Door Lock Device" status update is on
Z-Wave Lock Manager Debug Node ID 34 (Hex 34) found in lockIDs
Z-Wave Lock Manager Debug Raw: 01 10 00 04 00 22 0A 71 05 AA 01 00 FF 08 FE 00 00 FF
Z-Wave Lock Manager Unknown lock status received: 170 [Node: 34]
Z-Wave Lock Manager Debug -----
Indigo Z-Wave Version: 7.4.1
Node ID: 34
Model: Keypad Door Lock
Model ID: 00030742
Manufacturer: Kwikset
Manufacturer ID: 0090
Protocol Version: 4.34
Application Version: 4.10
Model Definition Version: 0
Library Type: 3
Class Name: Keypad Door Lock
Class Hierarchy: 04 : 40 : 03
Command Class Base: 62
Command Versions: 80v1 85v1 86v1 8Bv1 4Cv1 4Ev1 98v1 59v1 5Av1 5Dv1 5Ev1 20v1 62v1 63v1 70v1 71v1 72v1 73v1 7Av1
Encryption Status: Enabled for Commands 80 85 86 8B 4C 4E 59 5D 62 63 70 71
Features: routing, battery, beaming, security, frequentWaking
Neighbors: 2, 3
Associations: 1:[1] 2:[]
Config Values: - none -
Tue Mar 31, 2020 3:09 pm
Re: Unkown Lock Status
Hi Jen.
Your device is reporting strange things; it says it supports Alarm Class 0x71 version 1 but the length of the report it sent is not a v1 report.
Regardless, i've emailed Kwikset support as the value AA (decimal 170) that it's reporting (... 71 05 AA...) is not a defined value so Kwikset have implemented custom values. I already added A7, A8 and A9 (decimal 167-169) from a Kwikset document I found online that explains they are Low, Critical and Dead battery alarms, but AA (170) isn't in that guide.
Peter
Tue Mar 31, 2020 5:15 pm
jenwill1 offline
Thanks Peter... If I need to re-sync the lock or anything on my end let me know.
Regards,
Will (My wife Jen had the first half of the old email name!)
