None of my Locks now work with Lock Manager
Posted: Fri Jun 15, 2018 8:06 am
Hello,
I had to recover from a hard drive failure and since then ( i think, i have only just checked and noticed) I can no longer set pins etc for any of my 4 Locks. 3 are Yale Keyfree Connected locks and 1 is a Yale Keyless Connected.
All 4 were working perfectly but now i have gone to my action group to set a pin/clear a pin, none of the locks show up in actions anymore.
All the locks are working in Indigo (lock, unlock and battery status). They are all included encrypted incase that matters to the plugin?
I turned on debugging but no clues there: just mentions the triggers i have set up:
On test status response i get:
Any ideas how to start troubleshooting this?
- Code: Select all
Starting plugin "Z-Wave Lock Manager 1.0.49" (pid 1246)
Started plugin "Z-Wave Lock Manager 1.0.49"
Z-Wave Lock Manager Debug startup called
Z-Wave Lock Manager Debug Start processing trigger Andrew Unlock Back Door
Z-Wave Lock Manager Debug Start processing trigger Andrew Unlock Front Door
Z-Wave Lock Manager Debug Start processing trigger Andrew Unlock Garage Door
Z-Wave Lock Manager Debug Start processing trigger Andrew Unlock Patio Door
Z-Wave Lock Manager Debug Start processing trigger Billie Unlock Back Door
Z-Wave Lock Manager Debug Start processing trigger Billie Unlock Front Door
Z-Wave Lock Manager Debug Start processing trigger Billie Unlock Garage Door
Z-Wave Lock Manager Debug Start processing trigger Billie Unlock Patio Door
Z-Wave Lock Manager Debug Start processing trigger Contractor (BoilerMan) Unlock Back Door
Z-Wave Lock Manager Debug Start processing trigger Dog Walker Unlock Front Door
Z-Wave Lock Manager Debug Start processing trigger Hollie Unlock Back Door
Z-Wave Lock Manager Debug Start processing trigger Hollie Unlock Front Door
Z-Wave Lock Manager Debug Start processing trigger Hollie Unlock Garage Door
Z-Wave Lock Manager Debug Start processing trigger Hollie Unlock Patio Door
Z-Wave Lock Manager Debug Start processing trigger Margret Unlock Back Door
Z-Wave Lock Manager Debug Start processing trigger Margret Unlock Front Door
Z-Wave Lock Manager Debug Start processing trigger Margret Unlock Garage Door
Z-Wave Lock Manager Debug Start processing trigger Margret Unlock Patio Door
- Code: Select all
Z-Wave Lock Manager Debug lockIDs: []
