Benext Tag Reader 500 not working
Sat Jul 29, 2017 9:36 am
SpikeB offline
I get the Tag Reader not working, I followed Matt's instructions and installed a beta Z-Wave library, also using the latest version of the plugin 1.0.43
When I look at the plugin, I do not see the usual commands as for example Set User Pin.
Device details:
Z-Wave Indigo Device "079 - Notification Sound" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.86
Node ID: 79
Model: RFID Keypad
Model ID: 00070200
Manufacturer: Digital Home Systems
Manufacturer ID: 008A
Protocol Version: 4.33
Application Version: 1.04
Model Definition Version: 2
Library Type: 3
Class Name: Entry Control
Class Hierarchy: 04 : 40 : 0B
Command Class Base: 00
Command Versions: 20v1 80v1 63v1 84v2 85v1 86v1 87v1 6Fv1 70v1 71v1 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1 25v1
Encryption Status: Enabled for Commands 80 63 84 25 86 87 6F 70 71 72 73 59 5A 85
Features: routing, battery, beaming, security, waking
Neighbors: 8, 9, 35, 44, 64
Associations: 1:[1]
Config Values: 2:15 4:2 5:1
Log when selecting Home/away with Tag.
Z-Wave Lock Manager Status: User code 0 is blank [Node: 79]
Z-Wave Lock Manager Debug -----
Z-Wave Lock Manager Debug Node ID 79 (Hex 79) found in lockIDs
Z-Wave Debug RCVD nonceFetch: node 079
Z-Wave Debug SENT nonceReport: 01 11 00 13 4F 0A 98 80 12 91 E9 8E F7 D1 77 10 25 1B 3B
Z-Wave Debug RCVD encryptedPacket: 00 84 07 (decrypted)
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 4F 02 84 07 FF
Z-Wave Debug . . nodeAwake: node 079
Z-Wave Debug . . . . . . . : skipping battery check (next check in 430 mins)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 4F 02 98 40 25 1C 49
Z-Wave Debug RCVD nonceReport: node 079, nonce 29 18 9F B9 8C 61 E9 E8
Z-Wave Debug SENT goToSleep: 84 08 (encrypted)
Z-Wave Debug RCVD packet: 01 07 00 13 1D 00 00 02 F4 (hex)
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 26 02 84 07 54
Z-Wave Debug . . nodeAwake: node 038
Z-Wave Debug . . . . . . . : skipping battery check (next check in 225 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 26 02 84 08 24 1E 77
Z-Wave Debug RCVD packet: 01 07 00 13 1E 00 00 01 F4 (hex)
Z-Wave Debug RCVD requestReply1: 01 0D 00 04 00 4F 07 88 03 66 00 00 01 23 71 (hex)
Z-Wave Debug SENT nonceReport: 01 11 00 13 4F 0A 98 80 77 7B 54 22 0E 09 D7 B7 25 1F 87
Z-Wave Debug RCVD encryptedPacket: 00 63 03 00 00 39 36 34 35 32 32 30 30 30 30 (decrypted)
Z-Wave Debug RCVD requestReply1: 01 14 00 04 00 4F 0E 63 03 00 00 39 36 34 35 32 32 30 30 30 30 FF (hex)
Z-Wave Lock Manager Debug User Code Status received:
Z-Wave Lock Manager Debug Raw command: 01 14 00 04 00 4F 0E 63 03 00 00 39 36 34 35 32 32 30 30 30 30 FF
Z-Wave Lock Manager Debug Node: 79
Z-Wave Lock Manager Debug User: 0
No commands visible
Schermafbeelding 2017-07-29 om 16.25.30.png (155.04 KiB) Viewed 2048 times
Sat Jul 29, 2017 11:39 am
Re: Benext Tag Reader 500 not working
Hi Spike.
That screenshot is correct; there's no menu items missing there.
(There were some test menu items at one point, which I use for debugging - they shouldn't have been released publicly)
To set pins, create an action > Zwave manager actions > Set Pin.
I'll check through the Zwave commands you've posted once I've got my laptop out tonight.
Sat Jul 29, 2017 1:00 pm
Hi Spike.
I've just remembered what Matt said about this device being an OEM of the Zipato keypad.
That being the case, please look at: viewtopic.php?f=210&t=17527
Those instructions from Krissh should help you.
Peter
Sun Jul 30, 2017 4:41 am
SpikeB offline
Hi Peter,
Many thanks for your support, I got it working :D
Create an action did the trick.
Regards, Spike
Sun Jul 30, 2017 8:07 am
Excellent.
I'm looking at adding device detection to offer help specific to the devices a user has added.
