Kwikset 916 Managment Problems
Mon May 29, 2017 4:26 pm
Gelfin offline
I've finally switched out my locks for the Kwikset 916, and almost everything is fine, but ZWave Lock Manager is having problems sending commands to my locks.
I have a Lock Manager device set up and associated with each lock. If I set up an action that just does a simple "Get User PIN" for one lock, I get:
May 29, 2017, 3:57:18 PM
   Action Group                 Get Code
   Z-Wave Lock Manager          Requesting PIN for user 1
   Z-Wave Lock Manager Error    Error in plugin execution ExecuteAction:
Trace back (most recent call last):
  File "plugin.py", line 146, in getUserPin
InvalidParameter: could not find module/node for action
If I look at Line 146 and do what it's doing manually in a script action:
indigo.zwave.sendRaw(device=indigo.devices[1555487768], cmdBytes=[0x63, 0x2, 0x1], sendMode=1)
I get no error and see the following in the log:
Z-Wave                 sent "Mud Room Lock" raw command [63 02 01]
Z-Wave Lock Manager    Status:  User code 1 is 1 2 3 4 5 6 (Node: 4)
(...where 1 2 3 4 5 6 stands in for the one code I set manually on the lock when setting it up)
Any idea what might be happening here?
Mon May 29, 2017 4:36 pm
Gelfin offline
Re: Kwikset 916 Managment Problems
One further update:
The Device ID in the script above is for the actual Z-Wave lock, which is what I would have expected. After turning on debugging in Lock Manager, it appears that the Get User PIN action is trying to use the ID of the Lock Manager device itself instead of the Z-Wave lock it's associated with. I assume that's failing because it isn't a valid target for raw Z-Wave commands.
Mon May 29, 2017 11:36 pm
Ah, that's probably a bug I've introduced when merging the beta code into the main stream over the weekend. It's precisely that set of code that I switched but I thought I'd done a find in the code for all references to it. :-(
I'll sort it tonight!
Peter
Tue May 30, 2017 2:03 pm
Right, I've just uploaded 1.0.36 to the same link in the announcement thread.
Can you check it out?
Peter
Tue May 30, 2017 3:44 pm
CliveS offline
Just updated and I don't get a dropdown list from the 4 set commands in Lock Manager Actions but Device Actions > Lock Controls I do .
I did do a resync and reset Indigo.
CliveS
CliveS
Tue May 30, 2017 3:47 pm
You need to create dummy lock devices - see the latest announcement post for .35
Peter
Tue May 30, 2017 5:39 pm
Gelfin offline
Peter
Fixed for Get User PIN, thanks, but it looks as if the same problem also (still) exists for Set User PIN.
May 30, 2017, 5:34:36 PM
   Action Group                    Test Manager
   Z-Wave Lock Manager Debug       setUserPin action called
   Z-Wave Lock Manager Debug       Indigo lock selected: 14551786
  File "plugin.py", line 109, in setUserPin
  File "plugin.py", line 543, in setPin
KeyError: (14551786,)
(14551786 is the Manager device)
Tue May 30, 2017 11:29 pm
Grrr. I thought I'd been careful to copy the fix through get, set and clear!
I'll try do it as soon as I can get on a pc.
Wed May 31, 2017 12:03 am
1.0.37 now live.
Wed May 31, 2017 2:46 am
CliveS offline
Peter,
I have now read the .35 release notes, my fault for jumping from .34 to .36!! and see for a new trigger I get the option of the Lock Device( Node 55) or the dummy lock, can I use either?
A couple more bugs to eradicate
31 May 2017, 09:21:19
Z-Wave Lock Manager Debug logging enabled
Schedule Front Door Lock Time Set
Z-Wave Lock Manager Debug setRCT action called
Z-Wave Lock Manager Debug Indigo lock selected: 1802317647
Z-Wave Lock Manager Debug 11111100001
Z-Wave Lock Manager Debug 7
Z-Wave Lock Manager Debug 11100001
Z-Wave Lock Manager Debug 225
Z-Wave Lock Manager Debug 2017
Z-Wave Lock Manager Setting lock time to 31/5/2017 9:21:26 (UK format DD/MM/YYYY HH:MM:SS)
File "plugin.py", line 189, in setRTC
31 May 2017, 09:21:52
Action Group Front Door Lock Wrong Code Set Limit & Timeout
Z-Wave Lock Manager Debug setWrongLimit action called
Z-Wave Lock Manager Setting incorrect code limit to 3 attempts with 60 second timeout:
File "plugin.py", line 224, in setWrongLimit
CliveS
PS You really should get a lock just to appreciate the great plugin you have done "blindfolded"... Thank you!
CliveS
Wed May 31, 2017 11:22 pm
Hi Clive.
Believe me, if I had any doors that were suitable for locks, I'd have one by now - a fellow plugin user offered to buy me one just to say thank you - but we have uPVC doors with multipoint locks on (UK) for which there's only one Zwave lock on the market and they cost a fortune vs most keypads/locks that you guys are using!
I hadn't realised how poorly I'd written these routines in the beta (I think I must have broken off half way through changing direction) which is why they're now popping up in the live releases.
I'll get it sorted.
Thu Jun 01, 2017 1:44 am
CliveS offline
I must admit to gatecrashing the thread as I have one of those expensive locks (Yale) fitted here in Consett but the bugs are agnostic when they bite.
CliveS
Thu Jun 01, 2017 8:23 am
Gelfin offline
howartp wrote:
1.0.37 now live.
That's got it. Thanks! Get/Set/Clear all behaving fine.
Not to hijack my own thread, but I had some thoughts I'd actually started to work on in the interim anyway (since, for want of a non-Indigo Z-Wave controller, I've been having to configure my locks via scripts anyway), but since you have a working plug-in already, it might appeal to you: I'd gone down the route of making a "lock user" device. For configuration each user would have a code and a multi-select list of locks the code would have access to. There are situations where the "indigo.zwave,indigo.relay" filter wouldn't be sufficiently narrow, so maybe let the user select a full list of actual locks as a matter of plug-in config. The plug-in could then watch for changes to users (e.g., a schedule that only enables the "Housekeeper" user at certain times) and, as a first pass, just crudely rewriting the the whole user set of each lock, but then maybe later figuring out a way to push smarter, more minimal deltas.
Then when a code is used, you can fire a trigger off the actual user device, so you get consistency for auditing purposes (the slot a given code occupies on a given lock may change, or vary from lock to lock).
Another nice security feature would be a utility to forcibly clear every slot that is not known to be claimed by an active user
Give a mouse a cookie, eh? ;-)
I may still work on this some myself, but like I said, I thought you might take interest.
Fri Jun 02, 2017 12:24 am
Great!
I've already got the concept of lock users in beta, but I'm not keen on how I've done it at the moment so I'll give your ideas some thought as well.
