Unable to select user 251
Thu Nov 23, 2017 12:19 pm
durosity offline
Re: Unable to select user 251
Don’t suppose you’ve had a chance to have a look at this have you? (Just to pre-empt.. I’m not demanding anything.. I’m just curious.. in every sense of the word. ;) )
Fri Nov 24, 2017 2:39 pm
Give 1.0.47 a go.
Fri Nov 24, 2017 5:01 pm
CliveS offline
howartp wrote:
Give 1.0.47 a go.
Tried but get red on all existing items and Lock Manager does not show up in drop down menus
CliveS
Fri Nov 24, 2017 5:08 pm
durosity offline
Alas same issue as Clive.. log results with debug on:
24 Nov 2017, 23:04:53
Reloading plugin "Z-Wave Lock Manager 1.0.47"
Starting plugin "Z-Wave Lock Manager 1.0.47" (pid 67578)
Z-Wave Lock Manager Error Events.xml has an error: mismatched tag: line 277, column 3
Z-Wave Lock Manager Error Events.xml is malformed
Stopping plugin "Z-Wave Lock Manager 1.0.47" (pid 67578)
Sat Nov 25, 2017 8:42 am
Sorry, I didn't actually test it before releasing. :)
v1.0.48 is tested to load ok, but I can't test 251.
Peter
Sat Nov 25, 2017 9:36 am
CliveS offline
Peter
Peter,
It works fine, and all the options are their to use Master Code, but I did find one problem.
If I copy a trigger then it retains the ID of the trigger (i.e. user 30) and is greyed out but a new trigger puts 251 in its place and is also greyed out as the code specifies.
The errors "Z-Wave Error no nonce reply (055) for setLockValue (re-sending)" I think are my Gen5 Aeotec Stick unless anyone can throw any light on the error.
25 Nov 2017, 14:44:32
   Stopping plugin Z-Wave Lock Manager (pid 693)
   Stopped plugin Z-Wave Lock Manager
   Upgrading plugin Z-Wave Lock Manager to newer version 1.0.48 (previous version moved to trash)
   Loading plugin "Z-Wave Lock Manager 1.0.48"
   Starting plugin "Z-Wave Lock Manager 1.0.48" (pid 67961)
   Started plugin "Z-Wave Lock Manager 1.0.48"
   Email Scanned                   from "support@indigodomo.com"; subject "Topic reply notification - "Unable to select user 251""
25 Nov 2017, 14:44:55
   Z-Wave                          received "055 - Front Door Keypad Lock" status update battery level 90%
25 Nov 2017, 14:45:21
   Z-Wave                          received "Front Door Keypad Lock" status update unlocked (manually)
   Z-Wave Lock Manager             Status: Door unlocked manually [Node: 55]
   Z-Wave                          received "Drive Front Door Motion Sensor" status update is on
   Z-Wave                          received "Front Door Keypad Lock" status update locked (manually)
   Z-Wave Lock Manager             Status: Door locked manually [Node: 55]
   Z-Wave                          received "Front Door Keypad Lock" status update unlocked by user 251 (via keypad)
   Z-Wave Lock Manager             Status: User 251 unlocked door [Node: 55]
   Z-Wave                          received "Drive Front Door Motion Sensor" status update is off
25 Nov 2017, 14:50:55
   Z-Wave                          sent "Front Door Keypad Lock" unlock
25 Nov 2017, 14:51:14
   Z-Wave                          sent "Front Door Keypad Lock" lock
25 Nov 2017, 14:52:11
   Z-Wave                          received "Front Door Keypad Lock" status update locked (via controller)
   Z-Wave Lock Manager             Status: Door locked by Indigo [Node: 55]
25 Nov 2017, 14:52:27
   Z-Wave                          received "Front Door Keypad Lock" status update unlocked (via controller)
   Z-Wave Lock Manager             Status: Door unlocked by Indigo [Node: 55]
25 Nov 2017, 14:52:59
   Z-Wave                          received "Front Door Keypad Lock" status update locked (via timer)
   Z-Wave Lock Manager             Status: Door re-locked automatically [Node: 55]
CliveS
Sun Nov 26, 2017 4:33 pm
durosity offline
Yeah I’m getting the same, but seems to work fine with brand new triggers I previously setup so I’m happy!
Mon Dec 11, 2017 9:23 am
durosity offline
So I’ve noticed occasionally that the plugin doesn’t fire the trigger its supposed to. Here’s the log from the most recent incident:
DSC Alarm Entry Delay. (Partition 1 'House')
DSC Alarm Alarm Zone 'Hall - Front Door Sensor' Opened.
Z-Wave Lock Manager Debug Node ID 38 (Hex 38) found in lockIDs
Z-Wave received "Hall - Front Door Lock" status update unlocked by user 251 (via keypad)
Z-Wave Lock Manager Debug Raw: 01 0A 00 04 00 26 04 71 05 13 FB FF
Z-Wave Lock Manager Status: User 251 unlocked door [Node: 38]
Z-Wave Lock Manager Debug triggerEvent called: unlockedByMasterCode
Z-Wave Lock Manager Debug ---
Z-Wave Lock Manager Debug dNodeID: #38#
Z-Wave Lock Manager Debug eventNode: #38#
Z-Wave Lock Manager Debug dUserNo: #251#
Z-Wave Lock Manager Debug userNo: #251#
Z-Wave Lock Manager Debug Executing trigger
Z-Wave Lock Manager Debug Updating state: lockState
Z-Wave Lock Manager Debug -----
Trigger Motion: Hall - Motion Detected (Turn On Ambient Lights)
Z-Wave received "Hall - Front Door Lock" status update locked (via timer)
Z-Wave Lock Manager Debug Raw: 01 0A 00 04 00 26 04 71 05 1B 01 FF
Z-Wave Lock Manager Status: Door re-locked automatically [Node: 38]
Z-Wave Lock Manager Debug triggerEvent called: relockedAuto
Now in there usually there’d be something about the trigger “Door: Front Door Unlocked By Mike” in there but intermittently it just doesn’t seem to fire. It’s not the trigger itself as its conditions are set to always run. Any ideas on what could be stopping it from the above? (FYI It does it for all users, not just the master one)
