Airfoil and Indigo 6.0.5
Fri Nov 15, 2013 8:54 am
Dewster35 offline
Getting the following issues after updating to Indigo 6.0.5. Have tried restarting the indigo server and restarting airfoil but I'm still seeing the same thing.
 Airfoil Error                   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 538, in runConcurrentThread
  File "plugin.py", line 488, in update
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\u2019' in position 594: ordinal not in range(128)
  Airfoil Error                   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Nov 15, 2013 9:49 am
Re: Airfoil and Indigo 6.0.5
I bet you have a unicode character in the name of a speaker…
I'll look at it for the next release but in the meantime you can just disable debug logging (it's in a debug log line).
Fri Nov 15, 2013 10:27 am
Dewster35 offline
Jay… The only odd character I have is an "_" underscore if that qualifies.
Also, debugging is already off, turning it on adds even more to the event log than this. I have disabled the airfoil plugin for now.
Fri Nov 15, 2013 10:37 am
nsheldon offline
Might you have a speaker name with a right single curly quote character in the name? (Which is what Unicode character 0x2019 is).
Fri Nov 15, 2013 12:18 pm
Yeah, disabling debugging wouldn't work since the error happens before it checks that. There is definitely a unicode character in one of the speaker names though - it's a single right quote character (a smart quote).
Sat Nov 16, 2013 1:39 am
Juju offline
Same issue here with character u'\xa0 ...
Sat Nov 16, 2013 10:43 am
Fix will be in the next release.
Thu Nov 21, 2013 6:45 pm
pperrot offline
Same issue, mine was solved by RESETTING the speaker list...
Sun Dec 08, 2013 6:41 pm
Dewster35 offline
Getting the following in my event log... the first are from a script I use to keep the status of an airfoil speaker state updated when I manually click on an airfoil speaker from my mac and the second is an action to turn on an airfoil speaker on a control page.
Any thoughts on what is going on with the plugin?
IndigoStatus Updater            AirFoilIsRunning Changed from "false" to "true"
  IndigoStatus Updater            AirFoilSpeakerMaster_BedroomConnected Changed from "false" to "true"
  IndigoStatus Updater            AirFoilSpeakerMaster_BedroomConnected Changed from "true" to "false"
  IndigoStatus Updater            AirFoilSpeakerLiving_RoomConnected Changed from "false" to "true"
  IndigoStatus Updater            AirFoilSpeakerLiving_RoomConnected Changed from "true" to "false"
  Airfoil Error                   Speaker Living_Room is not available to toggle
  Airfoil Error                   Speaker Master_Bedroom is not available to toggle
  Received INSTEON                "Motion Detector - Great Room" off (button 1)
  Airfoil Error                   Speaker Deck is not available to toggle
Mon Dec 09, 2013 4:31 pm
Airfoil is telling the plugin that those speakers don't exist any more. Turn on debugging and then reset the speaker list. Copy/paste the details.
There was also a report that Airfoil was changing the IDs it assigns to speakers so that may be the issue. Try reselecting the speaker in the Action Config dialog for those actions and see if that fixes it. Hopefully that's a one-time change and not a bug in Airfoil that randomly changes the IDs...
Mon Dec 09, 2013 4:40 pm
Dewster35 offline
Interesting… turned on debugging and reloaded the plugin. Also restarted airfoil during this with no changes.
  Reloading plugin "Airfoil 1.1.2"
  Stopping plugin "Airfoil 1.1.2" (pid 5347)
  Stopped plugin "Airfoil 1.1.2"
  Starting plugin "Airfoil 1.1.2" (pid 26949)
  Started plugin "Airfoil 1.1.2"
  Airfoil                         Turning on debug logging
  Airfoil Debug                   runConcurrentThread: Airfoil isn't running
  Disabling plugin "Airfoil 1.1.2"
  Stopping plugin "Airfoil 1.1.2" (pid 26949)
  Airfoil Debug                   Stop processing trigger 108740328
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x26f5eb0>, 652305472: <indigo.PluginEventTrigger object at 0x26f5ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x26f5f30>, 855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>, 491290901: <indigo.PluginEventTrigger object at 0x26f5e70>, 395508631: <indigo.PluginEventTrigger object at 0x26f5df0>}, 'becomesUnavailable': {1185865169: <indigo.PluginEventTrigger object at 0x26f5e30>, 915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 395508631
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x26f5eb0>, 652305472: <indigo.PluginEventTrigger object at 0x26f5ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x26f5f30>, 855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>, 491290901: <indigo.PluginEventTrigger object at 0x26f5e70>}, 'becomesUnavailable': {1185865169: <indigo.PluginEventTrigger object at 0x26f5e30>, 915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 1185865169
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x26f5eb0>, 652305472: <indigo.PluginEventTrigger object at 0x26f5ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x26f5f30>, 855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>, 491290901: <indigo.PluginEventTrigger object at 0x26f5e70>}, 'becomesUnavailable': {915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 491290901
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x26f5eb0>, 652305472: <indigo.PluginEventTrigger object at 0x26f5ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x26f5f30>, 855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 1994914208
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {652305472: <indigo.PluginEventTrigger object at 0x26f5ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x26f5f30>, 855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 652305472
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1552943500: <indigo.PluginEventTrigger object at 0x26f5f30>, 855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 1552943500
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {915493848: <indigo.PluginEventTrigger object at 0x26f5f70>, 131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 915493848
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x26f5fb0>, 104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 1269546834
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {855566261: <indigo.PluginEventTrigger object at 0x26f5db0>, 40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 855566261
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {131682289: <indigo.PluginEventTrigger object at 0x27df070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 131682289
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {104683501: <indigo.PluginEventTrigger object at 0x27df0b0>}, 'becomesUnavailable': {}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 104683501
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {40935532: <indigo.PluginEventTrigger object at 0x27df0f0>}, 'becomesDisconnected': {}, 'becomesUnavailable': {}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Stop processing trigger 40935532
  Airfoil Debug                   Stop trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {}, 'becomesDisconnected': {}, 'becomesUnavailable': {}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
Update:
Latest version of airfoil 4.8.2
Running Mountain Lion 10.8.5
Indigo 6.0.6
Mon Dec 09, 2013 5:09 pm
Restart the plugin now that you have debugging turned on - I suspect we'll see an error right when it starts up...
Mon Dec 09, 2013 5:32 pm
Dewster35 offline
As requested
Enabling plugin "Airfoil 1.1.2"
  Starting plugin "Airfoil 1.1.2" (pid 27294)
  Airfoil Debug                   Start processing trigger 108740328
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {}, 'becomesDisconnected': {}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 395508631
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {}, 'becomesDisconnected': {395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 1185865169
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {}, 'becomesDisconnected': {395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 491290901
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {}, 'becomesDisconnected': {491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 1994914208
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>}, 'becomesDisconnected': {491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 652305472
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>}, 'becomesDisconnected': {491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 1552943500
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>}, 'becomesDisconnected': {491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 915493848
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>}, 'becomesDisconnected': {491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>, 915493848: <indigo.PluginEventTrigger object at 0x27c6f70>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 1269546834
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x27c6fb0>, 491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>, 915493848: <indigo.PluginEventTrigger object at 0x27c6f70>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 855566261
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>, 855566261: <indigo.PluginEventTrigger object at 0x27c6db0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x27c6fb0>, 491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>, 915493848: <indigo.PluginEventTrigger object at 0x27c6f70>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 131682289
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>, 855566261: <indigo.PluginEventTrigger object at 0x27c6db0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x27c6fb0>, 491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>, 915493848: <indigo.PluginEventTrigger object at 0x27c6f70>, 131682289: <indigo.PluginEventTrigger object at 0x4c1f070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 104683501
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>, 855566261: <indigo.PluginEventTrigger object at 0x27c6db0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x27c6fb0>, 104683501: <indigo.PluginEventTrigger object at 0x4c1f0b0>, 491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>, 915493848: <indigo.PluginEventTrigger object at 0x27c6f70>, 131682289: <indigo.PluginEventTrigger object at 0x4c1f070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
  Airfoil Debug                   Start processing trigger 40935532
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {1994914208: <indigo.PluginEventTrigger object at 0x27c6eb0>, 652305472: <indigo.PluginEventTrigger object at 0x27c6ef0>, 1552943500: <indigo.PluginEventTrigger object at 0x27c6f30>, 855566261: <indigo.PluginEventTrigger object at 0x27c6db0>, 40935532: <indigo.PluginEventTrigger object at 0x4c1f0f0>}, 'becomesDisconnected': {1269546834: <indigo.PluginEventTrigger object at 0x27c6fb0>, 104683501: <indigo.PluginEventTrigger object at 0x4c1f0b0>, 491290901: <indigo.PluginEventTrigger object at 0x27c6e70>, 395508631: <indigo.PluginEventTrigger object at 0x27c6df0>}, 'becomesUnavailable': {108740328: <indigo.PluginEventTrigger object at 0x27c6d70>, 1185865169: <indigo.PluginEventTrigger object at 0x27c6e30>, 915493848: <indigo.PluginEventTrigger object at 0x27c6f70>, 131682289: <indigo.PluginEventTrigger object at 0x4c1f070>}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
Also, I have not reset the speaker list as of yet.
Mon Dec 09, 2013 6:24 pm
Interesting. Run this AppleScript in the script editor and tell me what happens:
tell application "Airfoil"
    speakers
end tell
Pay close attention to any processes launching/quitting immediately after you run the script. My suspicion is that something in the OS (one of those blasted security "features") has decided that Airfoil can't be trusted or something so apple events aren't work right.
Mon Dec 09, 2013 6:41 pm
Dewster35 offline
Do you want me to try running this script with the plugin enabled or disabled?
